Щоб скинути Cisco WS-C3560-48TS потрібно затиснути Mode (знаходиться попереду свічта) й тримати доки в консолі не з'явиться
Switch#
00:04:17: %SYS-7-NV_BLOCK_INIT: Initalized the geometry of nvram
00:04:17: %EXPRESS_SETUP-6-CONFIG_IS_RESET: The configuration is reset and the system will now reboot
00:04:18: %SYS-5-RELOAD: Reload requested Reload Reason: power-on.
Приблизно 10 секунд.
Після цього світч перезавантажиться й буде з дефолтною конфігурацією.
Base ethernet MAC Address: 00:16:9d:22:22:22
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 352 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 7021568
flashfs[0]: Bytes available: 25492480
flashfs[0]: flashfs fsck took 12 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.SEB4.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.SEB4.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00C71990
Initializing flashfs...
flashfs[1]: 352 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 7021568
flashfs[1]: Bytes available: 25492480
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
cisco WS-C3560-48TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID CAT0950Z2T2
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:9D:22:22:22
Motherboard assembly number : 73-2222-22
Power supply part number : 341-0022-22
Motherboard serial number : CAT09522222
Power supply serial number : AZS09422222
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-48TS-S
System serial number : CAT0950Z2T2
SFP Module assembly part number : 73-7222-22
SFP Module revision Number : A0
SFP Module serial number : CAT09522KSE
Top Assembly Part Number : 800-26222-22
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMJ00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560-48TS 12.2(25)SEB4 C3560-IPBASE-M
Press RETURN to get started!
00:00:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
00:00:46: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:01:08: %SYS-5-RESTART: System restarted --
Would you like to terminate autoinstall? [yes]: yes
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Switch>ena
Switch#
00:01:33: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
Switch#
