mds 0 Опубликовано: 2018-05-28 13:48:50 Share Опубликовано: 2018-05-28 13:48:50 Edge-Core ES3528M, параметры и настройки следующие. ================================================== ACC-001# show version 1 Unit 1 Serial Number: 124001190 Hardware Version: R01 Chip Device ID: Marvell 98DX106-B0, 88E6095[F] EPLD Version: 0.07 Number of Ports: 28 Main Power Status: Up Redundant Power Status: Not present Agent (Master) Unit ID: 1 Loader Version: 1.0.4.0 Boot ROM Version: 1.2.1.2 Operation Code Version: 1.4.20.29 ACC-001#show mvr MVR Status : Enabled MVR Running Status : Active MVR Multicast VLAN : 998 MVR Priority : 4 MVR Max Multicast Groups : 255 MVR Current Learned Groups : 0 MVR Unspecified Source IP : Enabled MVR Receiver VLAN : 0 MVR Supported Receiver Group Ranges : 10 MVR Used Receiver Multicast Groups : 0 MVR Group Range: Start End --------------- --------------- 239.192.0.1 239.192.0.254 239.192.1.1 239.192.1.254 239.192.2.1 239.192.2.254 239.192.3.1 239.192.3.254 239.192.4.1 239.192.4.254 239.192.5.1 239.192.5.254 MVR Receiver Group Range: Multicast IP Mask --------------- --------------- ACC-001#show ip igmp snooping Service Status: Enabled Querier Status: Disabled Leave proxy status: Enabled Priority: 4 Query Count: 2 Query Interval: 125 sec Query Max Response Time: 10 sec Router Port Expire Time: 300 sec Immediate Leave Processing: Disabled on all VLAN IGMP Snooping Version: Version 2 ------------------------------------- VLAN 1: -------- IGMP snooping: Disabled VLAN 998: -------- IGMP snooping: Enabled -------- VLAN 1001: -------- IGMP snooping: Disabled SHAKH-ACC-001-0# show mvr interface Port Type Status Immediate Leave ------- -------- ------------- --------------- Eth1/1 Receiver Active/Up Enabled Eth1/2 Receiver Active/Up Enabled Eth1/3 Receiver Active/Up Enabled Eth1/4 Receiver Active/Up Enabled Eth1/5 Receiver Inactive/Down Enabled Eth1/6 Receiver Inactive/Down Enabled Eth1/7 Receiver Active/Up Enabled Eth1/8 Receiver Active/Down Enabled Eth1/9 Receiver Inactive/Up Enabled Eth1/11 Receiver Inactive/Down Enabled Eth1/12 Receiver Inactive/Down Enabled Eth1/13 Receiver Inactive/Down Enabled Eth1/14 Receiver Inactive/Down Enabled Eth1/15 Receiver Inactive/Down Enabled Eth1/16 Receiver Inactive/Down Enabled Eth1/17 Receiver Inactive/Down Enabled Eth1/18 Receiver Inactive/Down Enabled Eth1/19 Receiver Inactive/Down Enabled Eth1/21 Receiver Inactive/Down Enabled Eth1/22 Receiver Inactive/Down Enabled Eth1/23 Receiver Active/Up Enabled Eth1/25 Receiver Active/Up Enabled Eth1/27 Receiver Active/Up Enabled Eth1/28 Source Active/Up Disabled Фрагмент конфы: ! jumbo frame ! ! ip igmp filter ! vlan database vlan 1 name DefaultVlan media ethernet state active vlan 998 name iptv media ethernet state active vlan 1001 name CUSTOMERS media ethernet state active ! ! ! ! ! ! spanning-tree mst configuration ! ! ! ! ! ! ! ! ! ! ! ! mvr mvr group 239.192.0.1 239.192.0.254 mvr group 239.192.1.1 239.192.1.254 mvr group 239.192.2.1 239.192.2.254 mvr group 239.192.3.1 239.192.3.254 mvr group 239.192.4.1 239.192.4.254 mvr group 239.192.5.1 239.192.5.254 mvr vlan 998 mvr unspecified-source-ip mvr priority 4 ! ip igmp profile 4 permit range 239.192.0.1 239.192.0.254 range 239.192.1.1 239.192.1.254 range 239.192.2.1 239.192.2.254 range 239.192.3.1 239.192.3.254 range 239.192.4.1 239.192.4.254 range 239.192.5.1 239.192.5.254 ! ip igmp profile 5 permit ! ! ip dhcp snooping no ip dhcp snooping verify mac-address ip dhcp snooping vlan 1001 ip dhcp snooping information option ! no lldp ! ! ! ! ! ! ! ip arp inspection ip arp inspection vlan 1001 ip arp inspection validate src-mac ! ! ! ! ! interface vlan 1 interface vlan 998 interface vlan 1001 ! ! loopback-detection loopback-detection recover-time 0 ! ! interface ethernet 1/7 no spanning-tree loopback-detection no switchport broadcast ip arp inspection limit rate 10 switchport allowed vlan add 1001 untagged switchport native vlan 1001 switchport allowed vlan remove 1 spanning-tree spanning-disabled spanning-tree bpdu-filter queue cos-map 2 6 queue cos-map 3 4 5 7 ip igmp filter 4 ip igmp max-groups 3 loopback-detection mvr type receiver mvr immediate ! ! interface ethernet 1/28 description ---# Uplink ip dhcp snooping trust ip arp inspection trust switchport allowed vlan add 1 untagged switchport acceptable-frame-types tagged switchport allowed vlan add 1,761,767,998-1001 tagged switchport mode trunk switchport gvrp garp timer leave 120 garp timer join 40 queue cos-map 2 6 queue cos-map 3 4 5 7 ip igmp filter 4 mvr type source ! ! ! ! ! ! ! ! ! ! no ip http server ! no ip http secure-server ! ! no spanning-tree ! ! no ip igmp snooping vlan 1 no ip igmp snooping vlan 1001 ip igmp snooping vlan 998 mrouter ethernet 1/28 ip igmp snooping leave-proxy ip igmp snooping priority 4 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! pvlan uplink-to-uplink forwarding pvlan session 1 ! ! ! ! ! ! ! line console exec-timeout 0 silent-time 0 ! ! line VTY exec-timeout 65535 ! end ======================== На коммутаторе я вижу квери-пакет. Receive Query from port 28, src ip 10.254.254.254, group 0.0.0.0 Forward packet to VLAN 998, portbitmap ffffeea0 Абонент на 7 порту не получает IPTV. Куда копать? Заранее СПАСИБО! Ссылка на сообщение Поделиться на других сайтах
logic 523 Опубликовано: 2018-05-28 14:05:52 Share Опубликовано: 2018-05-28 14:05:52 Перейти на юникаст Ссылка на сообщение Поделиться на других сайтах
mds 0 Опубликовано: 2018-05-28 14:11:32 Автор Share Опубликовано: 2018-05-28 14:11:32 Хорошо бы.)) Но сейчас нужен мультикаст). Ссылка на сообщение Поделиться на других сайтах
wantmore 30 Опубликовано: 2018-05-28 19:11:47 Share Опубликовано: 2018-05-28 19:11:47 Добавить на 7 порт влан 998? Ссылка на сообщение Поделиться на других сайтах
mds 0 Опубликовано: 2018-05-28 19:24:42 Автор Share Опубликовано: 2018-05-28 19:24:42 Так он же и так receiver. Ссылка на сообщение Поделиться на других сайтах
wantmore 30 Опубликовано: 2018-05-29 06:12:06 Share Опубликовано: 2018-05-29 06:12:06 (изменено) Покажите( после перезагрузки свича) show mvr , show mvr interface, show mvr members Изменено 2018-05-29 06:13:04 пользователем wantmore Ссылка на сообщение Поделиться на других сайтах
mds 0 Опубликовано: 2018-05-29 08:15:35 Автор Share Опубликовано: 2018-05-29 08:15:35 0#show mvr MVR Status : Enabled MVR Running Status : Active MVR Multicast VLAN : 998 MVR Priority : 4 MVR Max Multicast Groups : 255 MVR Current Learned Groups : 0 MVR Unspecified Source IP : Enabled MVR Receiver VLAN : 0 MVR Supported Receiver Group Ranges : 10 MVR Used Receiver Multicast Groups : 0 MVR Group Range: Start End --------------- --------------- 239.192.0.1 239.192.0.254 239.192.1.1 239.192.1.254 239.192.2.1 239.192.2.254 239.192.3.1 239.192.3.254 239.192.4.1 239.192.4.254 239.192.5.1 239.192.5.254 MVR Receiver Group Range: Multicast IP Mask --------------- --------------- #show mvr interface Port Type Status Immediate Leave ------- -------- ------------- --------------- Eth1/1 Receiver Active/Up Enabled Eth1/2 Receiver Active/Up Enabled Eth1/3 Receiver Active/Up Enabled Eth1/4 Receiver Active/Up Enabled Eth1/5 Receiver Active/Down Enabled Eth1/6 Receiver Active/Down Enabled Eth1/7 Receiver Active/Down Enabled Eth1/8 Receiver Active/Down Enabled Eth1/9 Receiver Active/Down Enabled Eth1/11 Receiver Active/Down Enabled Eth1/12 Receiver Active/Down Enabled Eth1/13 Receiver Active/Down Enabled Eth1/14 Receiver Active/Down Enabled Eth1/15 Receiver Active/Down Enabled Eth1/16 Receiver Active/Down Enabled Eth1/17 Receiver Active/Down Enabled Eth1/18 Receiver Active/Down Enabled Eth1/19 Receiver Active/Down Enabled Eth1/21 Receiver Active/Down Enabled Eth1/22 Receiver Active/Down Enabled Eth1/23 Receiver Active/Up Enabled Eth1/25 Receiver Active/Up Enabled Eth1/27 Receiver Active/Up Enabled Eth1/28 Source Active/Up Disabled #show mvr members MVR Group IP Status Receiver VLAN Members ---------------- -------- ------------- --------- Ссылка на сообщение Поделиться на других сайтах
wantmore 30 Опубликовано: 2018-05-29 08:26:19 Share Опубликовано: 2018-05-29 08:26:19 sh mvr members - должны быть ваши группы, а у вас ничего. Ссылка на сообщение Поделиться на других сайтах
mds 0 Опубликовано: 2018-05-29 08:30:17 Автор Share Опубликовано: 2018-05-29 08:30:17 2 минуты назад, wantmore сказал: sh mvr members - должны быть ваши группы, а у вас ничего. Т.е., на коммутаторе должны быть группы от источника? В любом случае, удаётся их пропихнуть в порт абоненту или нет? Ссылка на сообщение Поделиться на других сайтах
wantmore 30 Опубликовано: 2018-05-29 17:54:09 Share Опубликовано: 2018-05-29 17:54:09 Я полагаю, что да. Кстати, смотрел в вашу прошивку ченджлог, там бага с мвр. Желательно еще новую версию залить. Ссылка на сообщение Поделиться на других сайтах
khatgit 22 Опубликовано: 2018-05-29 20:53:17 Share Опубликовано: 2018-05-29 20:53:17 (изменено) Я бы еще настроил на клиентских портах ip igmp max-groups action replace и ip igmp query-drop. Первое нужно на случай, если абон начнет по плей-листу каналы переключать. Второе нужно для того, что бы querier-ом вдруг не стало абонентское оборудование. Так же не совсем понятно зачем отключили igmp snooping в клиентском влане и зачем на аплинке ip igmp filter. Я обычно через show ip igmp snooping groups проверял подписывается ли кто-то из абонентов на мультикаст группы. Ну и если есть подписка, то смотрел на коммутаторах выше - вплоть до оборудования где pim или igmp querier(это уже от вашей архитектуры зависит) доходят ли Membership Report-ты + идет ли в обратную сторону мультикаст. Изменено 2018-05-29 21:01:42 пользователем khatgit Ссылка на сообщение Поделиться на других сайтах
