Sorvi_Golova 0 Опубликовано: 2008-02-01 17:37:37 Share Опубликовано: 2008-02-01 17:37:37 Стоит у меня стг версии 2.404.9.7, все работало, но мне захотелось воспользоваться готовой сборкой Apache + php + mysql. Называется XAMPP Выключил старый мускул и апач, установил и запускаю XAMPP - работает. Пробую запускать стг - не работает. Вот лог 2008-02-01 18:49:44 -- Stg v. Stg 2.404 2008-02-01 18:49:44 -- Message queue created successfully. msgKey=5555 msgID=196608 2008-02-01 18:49:44 -- Timer thread started successfully. 2008-02-01 18:49:44 -- Parse 'mysql_store v.0.67' module settings error: Couldn't connect to mysql engine! With error: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) 2008-02-01 18:49:45 -- Queue removed successfully. 2008-02-01 18:49:45 -- StgTimer: Stop successfull. 2008-02-01 18:49:45 -- Stg stopped successfully. Глянул в настройки мускула, вот # Example MySQL config file for medium systems. # The following options will be passed to all MySQL clients [client] #password = your_password port = 3306 socket = /opt/lampp/var/mysql/mysql.sock # Here follows entries for some specific programs # The MySQL server [mysqld] port = 3306 socket = /opt/lampp/var/mysql/mysql.sock skip-locking key_buffer = 16M max_allowed_packet = 1M table_cache = 64 sort_buffer_size = 512K net_buffer_length = 8K read_buffer_size = 256K read_rnd_buffer_size = 512K myisam_sort_buffer_size = 8M # Don't listen on a TCP/IP port at all. This can be a security enhancement, # if all processes that need to connect to mysqld run on the same host. # All interaction with mysqld must be made via Unix sockets or named pipes. # Note that using this option without enabling named pipes on Windows # (via the "enable-named-pipe" option) will render mysqld useless! # #skip-networking # Replication Master Server (default) # binary logging is required for replication # log-bin deactivated by default since XAMPP 1.4.11 #log-bin=mysql-bin # required unique id between 1 and 2^32 - 1 # defaults to 1 if master-host is not set # but will not function as a master if omitted server-id = 1 Я понимаю, что это больше к мускулу относится но все же, что делать ? Ссылка на сообщение Поделиться на других сайтах
Sorvi_Golova 0 Опубликовано: 2008-02-02 18:07:01 Автор Share Опубликовано: 2008-02-02 18:07:01 Эх линукс........ Я сделал символическую ссылку, куда просил стг, сокета и все Ссылка на сообщение Поделиться на других сайтах
