stereo 6 Опубликовано: 2019-11-28 09:40:36 Share Опубликовано: 2019-11-28 09:40:36 Продам маршрутизатор CISCO ASR 1002-X , в отличном состоянии, цена 4500$ дам время на проверку. Ниже выгрузка конфигурации и софта. При необходимости предоставлю доступ для удаленного подключения. Варианты оплаты обсуждаются, возможен наличный и безналичный расчет. ceom-asr1002>show inventory NAME: "Chassis", DESCR: "Cisco ASR1002-X Chassis" PID: ASR1002-X , VID: V01, SN: SSI170101RR NAME: "Power Supply Module 0", DESCR: "Cisco ASR1002 AC Power Supply" PID: ASR1002-PWR-AC , VID: V03, SN: ART1643U08F NAME: "Power Supply Module 1", DESCR: "Cisco ASR1002 AC Power Supply" PID: ASR1002-PWR-AC , VID: V02, SN: ART1621U0BR NAME: "module 0", DESCR: "Cisco ASR1002-X SPA Interface Processor" PID: ASR1002-X , VID: , SN: NAME: "SPA subslot 0/0", DESCR: "6-port Built-in GE SPA" PID: 6XGE-BUILT-IN , VID: , SN: NAME: "module R0", DESCR: "Cisco ASR1002-X Route Processor" PID: ASR1002-X , VID: V01, SN: JAE16510C9H NAME: "module F0", DESCR: "Cisco ASR1002-X Embedded Services Processor" PID: ASR1002-X , VID: , SN: ceom-asr1002>show version Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.3(1)S1, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2013 by Cisco Systems, Inc. Compiled Fri 08-Feb-13 10:26 by mcpre IOS XE Version: 03.08.01.S Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc. All rights reserved. Certain components of Cisco IOS-XE software are licensed under the GNU General Public License ("GPL") Version 2.0. The software code licensed under GPL Version 2.0 is free software that comes with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such GPL code under the terms of GPL Version 2.0. For more details, see the documentation or "License Notice" file accompanying the IOS-XE software, or the applicable URL provided on the flyer accompanying the IOS-XE software. ROM: IOS-XE ROMMON ceom-asr1002 uptime is 14 minutes Uptime for this control processor is 16 minutes System returned to ROM by reload at 01:47:58 UTC Fri Feb 21 2014 System image file is "bootflash:/asr1002x-universalk9.03.08.01.S.153-1.S1.SPA.bin" Last reload reason: PowerOn This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at:http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. License Level: advipservices License Type: RightToUse Next reload license Level: advipservices cisco ASR1002-X (2RU-X) processor with 1141078K/6147K bytes of memory. Processor board ID SSI170101RR 6 Gigabit Ethernet interfaces 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 6684671K bytes of eUSB flash at bootflash:. Configuration register is 0x2102 Ссылка на сообщение Поделиться на других сайтах
