Продается коммутатор Extreme X650-24x
Продается коммутатор Extreme X650-24x.
Полностью в рабочем состоянии.
Работал в датацентре, продается в связи с апгрейдом.
Возможет торг.
Цена 2500$.
Дополнительный блок VIM1-SS-1 (VIM1-SummitStack) для:
1) 4-х включений 1гбит/с с использованием SFP: "The VIM1-SummitStack versatile interface module provides four cages for installed 1000-BASE SFP optical modules"
2) объединения коммутатора с другими в стэк: "provides two high-performance stacking ports that allow you to combine multiple units into a single SummitStack management entity"
При необходимости можем организовать второй блок питания.
ПО на свиче:
ExtremeXOS version 15.3.1.4 v1531b4-patch1-14 by release-manager on Thu Jun 6 14:48:14 EDT 2013
# sh version
Switch      : 800395-00-01 1040G-01086 Rev 1.0 BootROM: 1.0.5.5    IMG:15.3.1.4
VIM1-SS-1   : 450238-00-05 1039G-01578 Rev 5.0
PSU-1       : Internal PSU-1 800285-00-06 1108W-80540
PSU-2       :
Image   : ExtremeXOS version 15.3.1.4 v1531b4-patch1-14 by release-manager
BootROM : 1.0.5.5
# sh switch detail
SysName:
SysLocation:
SysContact:
System MAC:
System Type:      X650-24x(SSns)
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Tue Nov 19 17:13:48 2019
Timezone:         [Auto DST Enabled] GMT Offset: 120 minutes, name is
not set.
                  DST of 60 minutes is currently not in effect, name is
not set.
                  DST begins every last Saturday March at 3:00
                  DST ends every last Saturday October at 3:00
Boot Time:        Tue Sep 24 18:32:23 2019
Boot Count:       32
Next Reboot:      None scheduled
System UpTime:    55 days 23 hours 41 minutes 24 seconds
Current State:    OPERATIONAL
Image Selected:   primary
Image Booted:     primary
Primary ver:      15.3.1.4
                  patch1-14
Secondary ver:    15.2.1.5
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 15.3.1.4
                  819705 bytes saved on Tue Nov 12 08:32:46 2019
# sh licenses
Enabled License Level:
    Core
Enabled Feature Packs:
    None
    • Від bosyak
      Продам комутатори Extreme X650-24x  2шт
      по два блока живлення в кожному, передні і задні вуха в комплекті, ліцуха максимальна CORE
      ціна за кожний 600уе
      готівка, безготівка
      аргументований торг в ПМ
    • Від Dogerty
      Цена 1200 у.е.
      Кому интересно, пишите в ЛС.
    • Від eugene2006
      продам комутатор Extreme Networks Х670V-48X c 2 шт AC power, rack kit, стан - вживаний, повністю робочий, ціна 45650 грн
    • Від scaran
      Приветствую еще раз. Кто может поделится прошивкой 15.3.1.4 или ниже для summit x250e.  На свитче стоит 12.5.4.5, при попытке зашить 15.3.5.2 patch 1-19 ругается, что нужна промежуточная. А какая именно промежуточная инфы не нашел.
    • Від scaran
      Интересует какие существуют свитчи 1U формата с 48sfp и аплинками по 10G
      Единственное пока нашел у экстрима summit x460-48x с модулем XGM3-2sf. Если edge лицензия на нем, там же все должно работь и 10г дырки и обычные?
      Есть ли такое у хуавея или дела?
