BDCOM GP3600-08B настройка onu как роутер
olimpikys
Помогите разобраться с настройкой ону как роутера на BDCOM. Есть ont терминал zte F660 . После регистрации данной ону, нет возможности настроить ей wan порт, BDCOM пишет:
Switch_config_gpon0/1:1#gpon onu wan ?
This onu has no wan port!
Вот конфиг BDCOM a:
!version 10.3.0D build 71377
service timestamps log date
service timestamps debug date
logging buffered 10000
port-protected 1
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
gpon profile onu-rate-limit ratelimit-default id 1
 gpon-profile pir 1000000 cir 1000000
gpon profile onu-uni MTU id 2
 gpon-profile max-frame-size 1550
gpon profile onu-tcont tcont-default id 1
 gpon-profile tcont-type 3 pir 1024000 cir 512
gpon profile onu-virtual-port virtual-port-default id 1
 gpon-profile encryption disable
 gpon-profile upstream queue 8
 gpon-profile downstream queue 8
gpon profile onu-tcont-virtual-port-bind tvbind-default id 1
 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default
gpon profile onu-flow-mapping flow-mapping-default id 1
 gpon-profile entry 1 uni type eth-uni all
 gpon-profile entry 1 virtual-port 1
gpon profile onu-flow-mapping flow-mapping-default-hgu id 2
 gpon-profile entry 1 uni type veip all
 gpon-profile entry 1 vlan 1127
gpon profile onu-flow-mapping vlan20 id 3
 gpon-profile entry 1 vlan 20
gpon profile onu-flow-mapping 1001 id 4
 gpon-profile entry 1 vlan 1001
gpon profile onu-flow-mapping 1128 id 5
 gpon-profile entry 1 vlan 1128
gpon profile onu-flow-mapping 1127 id 6
gpon profile onu-flow-mapping wan id 7
 gpon-profile entry 1 uni type veip 1
gpon profile onu-vlan vlan20 id 3
 gpon-profile vlan mode trunk
 gpon-profile vlan pvid 20 0
 gpon-profile vlan trunk vlan-allowed 20
gpon profile onu-vlan 1001 id 4
 gpon-profile vlan pvid 1001 0
 gpon-profile vlan trunk vlan-allowed 1001
gpon profile onu-vlan 1128 id 5
 gpon-profile vlan pvid 1128 0
 gpon-profile vlan trunk vlan-allowed 1128
gpon profile onu-vlan 1127 id 6
 gpon-profile vlan pvid 1127 0
 gpon-profile vlan trunk vlan-allowed 1127
gpon onutype-template onutype-default-hgu
 gpon-onutype match ctc-onu-type HGU
 gpon-onutype config tcont-virtual-port-bind-profile tvbind-default
 gpon-onutype config flow-mapping-profile flow-mapping-default-hgu
interface Null0
interface GigaEthernet0/0
 ip address 192.168.0.1 255.255.0.0
!!slot 0 1 GP3600-08B mother card
interface GigaEthernet0/1
 switchport trunk vlan-allowed 245,3201
 switchport mode dot1q-tunnel-uplink
interface GPON0/1
 gpon bind-onutype onutype-default-hgu precedence 127
 gpon bind-onutype onutype-default precedence 128
 gpon bind-onu sn 5A544547C02151CF 1
 switchport trunk vlan-allowed 1001-1128,3201
 switchport mode dot1q-translating-tunnel
 switchport dot1q-translating-tunnel mode QinQ translate 1001-1128 3201 0
 switchport protected 1
interface GPON0/1:1
 gpon onu equipment-id F660V2.1
 gpon onu tcont-virtual-port-bind-profile tvbind-default
 gpon onu flow-mapping-profile 1127
 gpon onu virtual-port 1 gem-port 256
 gpon onu tcont 1 alloc-id 256
interface VLAN245
 ip address 10.0.11.35 255.255.255.0
 no ip directed-broadcast
interface VLAN3201
 no ip address
vlan 1,1001-1128,245,3201
ip route default 10.0.11.1
ip exf
ipv6 exf
ip telnet attack-defense
ddm enable
!Pending configurations for absent linecards:
!No configurations pending global
А вот информация по онушке
Switch_config#show gpon interface gPON 0/1:1 onu basic-info
Serial number                  ZTEG:C02151CF (5A544547C02151CF)
VendorID                       ZTEG (5A544547)
Version                        V2.1           (56322E3100000000000000000000)
Traffic management option      Priority and rate (2)
Battery backup                 Enable monitoring (1)
Admin state                    Unlock (1)
Operational state              Enabled (1)
EquipmentID                    F660V2.1
OMCC version                   ITU-T G.988 (2010)(Baseline only)
Vendor product code            0
Security capability            AES-128 (1)
Security mode                  AES-128 (1)
Total priority queue number    32
Total traffic scheduler number 8
Total GEM port number          256
Total ethernet UNI number      4
Total VEIP UNI number          1
Total IpHost UNI number        5
Total POTS UNI number          2
Total CATV UNI number          0
Total Private CATV UNI number  0
Image #0 version               V2.21.20P7T2S  (56322E32312E3230503754325300)
Image #0 status                valid/inactive/uncommitted
Image #1 version               V2.21.20P7T11S (56322E32312E3230503754313153)
Image #1 status                valid/active/committed
Piggyback DBA reporting        Mode 0 only (0)
Whole ONU DBA reporting        Not supported (0)
Distance                       177.0 m
Image update state             None (0)
Operator ID
CTC SpecVersion                0
CTC Onu Type                   SFU (0)
TxPowerControl                 0
ONU Config                     Success (2)
Applied onutype template       onutype-default
ONU Description                N/A
Online Duration                0h 37m 42s
The current time: 1970-1-27 3:26:11
Seq  Active Time          Deactive Time        Deactive Reason
 01  1970-01-27 02:48:28
Switch_config#
Відредаговано olimpikys
  • 5 months later...
    • Від Haddy
    • Від LazukinIvan
      📦 Основні характеристики:
      Оптичний роз’єм: SC/UPC
      💰 Ціна:
      400 грн/шт
      Від 10 шт — 380 грн/шт
      Від 50 шт — 375 грн/шт
      ✅ Опт і дрібний гурт
      ✅ Тестуємо перед відправкою
      hsgq-x100dg-43166623 (2).pdf
    • Від Prodazha
      В наявності 150 шт
      ціна 300 грн за штуку
    • Від LIKO
      Продам нові XPON ONU EchoLife YT8310M з гарантією!!!
      Сумісні з усіма основними OLT C-Data, BDCom, Huawei, ZTE.
      В комплект входить ONU + БЖ 12В 1А
      370 грн/шт
      На кількості ціна оговорюється окремо.
      XPON 1GE ONU user manual (1).pdf
    • Від Prodazha
      Термінова продажа онушок Foxgate 1001mz.
      нові .Гарантія.
      кількість 360 шт
      ціна 299 грн за штуку
