проблемы со сборкой
freebsd 6.0
stg-2.405.9.8
при сборке ругается:
Building STG 2.4 for FreeBSD 6
Checking for -lexpat... yes
Checking for -lfbclient... no
Checking for -lmysqlclient... no
Makefile:136: deps: No such file or directory
gmake -C /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../stglibs includes
gmake[1]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs'
gmake includes -C stg_logger.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/stg_logger.lib'
cp -p stg_logger.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/stg_logger.lib'
gmake includes -C stg_locker.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/stg_locker.lib'
cp -p stg_locker.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/stg_locker.lib'
gmake includes -C crypto.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/crypto.lib'
cp -p ag_md5.h blowfish.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/crypto.lib'
gmake includes -C common.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/common.lib'
cp -p debug.h stg_error.h common.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/common.lib'
gmake includes -C script_executer.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/script_executer.lib'
cp -p script_executer.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/script_executer.lib'
gmake includes -C conffiles.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/conffiles.lib'
cp -p conffiles.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/conffiles.lib'
gmake includes -C hostallow.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/hostallow.lib'
cp -p hostallow.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/hostallow.lib'
gmake includes -C pinger.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/pinger.lib'
cp -p pinger.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/pinger.lib'
gmake includes -C dotconfpp.lib
gmake[2]: Entering directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/dotconfpp.lib'
cp -p dotconfpp.h mempool.h /usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/projects/stargazer/../../include
gmake[2]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs/dotconfpp.lib'
gmake[1]: Leaving directory `/usr/home/asphix/distr/stargazer/standart/stg-2.405.9.8/stglibs'
Invalid null command.
gmake: *** [deps] Error 1
Подскажите, что не так?
тчорт, никакой универсальности :argh:
да, /bin/csh
Придёццо ставить башу :)
Ничего, я уже от этого избавляюсь. В следующей версии, скорее всего, этой зависимости не будет.
ну это радывает нас :)
билд сраборал, но при попытке сделать make install выдал:
root@router# make install
"Makefile", line 29: Missing dependency operator
"Makefile", line 33: Need an operator
"Makefile", line 35: Missing dependency operator
"Makefile", line 39: Need an operator
"Makefile", line 41: Missing dependency operator
"Makefile", line 45: Need an operator
"Makefile", line 55: Need an operator
Error expanding embedded variable.
Это нормально?
только теперь проблема со сборкой модуля mysql_store 0.67
# ./build
Building STG Mysql Module 0.62 for FreeBSD 6
^^^ версия не поправлена
g++ -c mysql_store.cpp -g3 -Wall -fPIC -I ../../../../../include -I /usr/local/mysql/include/mysql -DFREE_BSD5
mysql_store.cpp: In member function `virtual int MYSQL_STORE::GetMessage(uint64_t, STG_MSG*, const std::string&) const':
mysql_store.cpp:1867: error: `strtou2' undeclared (first use this function)
mysql_store.cpp:1867: error: (Each undeclared identifier is reported only once for each function it appears in.)
mysql_store.cpp:1899: error: `strtoi2' undeclared (first use this function)
mysql_store.cpp: In member function `virtual int MYSQL_STORE::GetMessageHdrs(std::vector<STG_MSG_HDR, std::allocator<STG_MSG_HDR> >*, const std::string&) const':
mysql_store.cpp:1967: error: `strtoull2' undeclared (first use this function)
mysql_store.cpp:1972: error: `strtou2' undeclared (first use this function)
mysql_store.cpp:1988: error: `strtoi2' undeclared (first use this function)
gmake: *** [mysql_store.o] Error 1
а с этим что делать? :)
З.Ы.: со старым модулем при запуске выдаёт:
2008-06-08 19:01:32 -- Storage plugin loading failed: /usr/lib/stg/mod_store_mysql.so: Undefined symbol "_Z9strtoull2PKcRy"
# ./build
приведите полные версии сервера и модулей которые вы пользуете
такс..
сам стг качал с http://www.stg.dp.ua/download/server/2.405...405.9.8.src.tgz
мускл-модуль отсюдда: http://v-lan.ru/projects/stargazer-2.4/Mod...sql_0.67.tar.gz
