input errors TurboIron-X24
Господа подскажите советом, есть 2 коммутатора, #1 TurboIron-X24 #2 eltex mes2324fb. Соединены  оптикой 10г. проблема на стороне  TurboIron-X24 наблюдаю  input errors, 0 CRC, 0 frame, 0 ignored.  Cамое странное при подключений eltex mes2324fb наблюдаю рост ошибок и на других интерфейсах TurboIron-X24.
На стороне TurboIron-X24
  Quote
interface ethernet 3
 port-name *******
 no spanning-tree
 no flow-control both
 PORT-VLAN 21, Name , Priority level0, Spanning tree Off
 Untagged Ports: None
   Tagged Ports:   3
   Uplink Ports: None
 DualMode Ports: None
 PORT-VLAN 10, Name , Priority level0, Spanning tree Off
   Tagged Ports:   3
   Uplink Ports: None
Expand
  Quote
sh interfaces ethernet 3
10GigabitEthernet3 is up, line protocol is up
  Hardware is 10GigabitEthernet, address is 748e.f821.0578 (bia 748e.f821.057a)
  Configured speed 10Gbit, actual 10Gbit, configured duplex fdx, actual fdx
  Member of 3 L2 VLANs, port is tagged, port state is FORWARDING
  BPDU guard is Disabled, ROOT protect is Disabled
  Link Error Dampening is Disabled
  STP configured to OFF, priority is level0
  Flow Control is disabled
  Mirror disabled, Monitor disabled
  Not member of any active trunks
  Not member of any configured trunks
  Port name is *********
  IPG XGMII 96 bits-time
  MTU 1500 bytes, encapsulation ethernet
  300 second input rate: 39638824 bits/sec, 3930 packets/sec, 0.39% utilization
  300 second output rate: 28564736 bits/sec, 17114 packets/sec, 0.30% utilization
  17496405 packets input, 22960684542 bytes, 0 no buffer
  Received 339 broadcasts, 1837 multicasts, 17494228 unicasts
  4082 input errors, 0 CRC, 0 frame, 0 ignored
  0 runts, 0 giants
  50249599 packets output, 10906708806 bytes, 0 underruns
  Transmitted 6027 broadcasts, 120 multicasts, 50243452 unicasts
  0 output errors, 0 collisions
  Relay Agent Information option: Disabled
Expand
Сторона eltex mes2324fb
  Quote
interface tengigabitethernet1/0/1
 description lala
 spanning-tree disable
 switchport mode trunk
 switchport trunk allowed vlan add 10,21
 switchport forbidden default-vlan
exit
Expand
  Quote
sh interfaces TengigabitEthernet 1/0/1
tengigabitethernet1/0/1 is up (connected)
  Interface index is 105
  Hardware is tengigabitethernet, MAC address is e4:5a:d4:2d:ff:59
  Description: *********
  Interface MTU is 1500
  Full-duplex, 10000Mbps, link type is 10000Mbps full-duplex, media type is 10G- Fiber
  Link is up for 0 days, 0 hours, 49 minutes and 47 seconds
  Flow control is off, MDIX mode is normal
  FEC is disabled
  15 second input rate is 26782 Kbit/s
  15 second output rate is 38676 Kbit/s
      61088543 packets input, 14030194967 bytes received
      7160 broadcasts, 147 multicasts
      0 input errors, 0 FCS, 0 alignment
      0 oversize, 0 internal MAC
      0 pause frames received
      22107437 packets output, 28862277484 bytes sent
      493 broadcasts, 2175 multicasts
      0 excessive collisions, 0 late collisions
      0 pause frames transmitted
      0 symbol errors, 0 carrier, 0 SQE test error
  Output queues: (queue #: packets passed/packets dropped)
      1: 0/0
      2: 0/0
      3: 0/0
      4: 0/0
      5: 0/0
      6: 0/0
      7: 0/0
      8: 0/0
Expand
смотрю на TurboIron-X24
sh statistics brief
  Quote
Port            In Packets          Out Packets       In Errors      Out Errors
1                        0                    0                        0               0
2                  3802166              1801652            0               0
3                    30140                72921               29             0
4                    36403                17941               0              10
5                        0                    0                       0               0
6                        0                    0                       0               0
7                        0                    0                       0               0
8                        0                    0                       0               0
9                        0                    0                       0               0
10                       0                    0                      0               0
11                       0                    0                      0               0
12                       0                    0                      0               0
13                       0                    0                      0               0
14                       0                    0                      0               0
15                       0                    0                      0               0
16                       0                    0                      0               0
17                       0                    0                      0               0
18                       0                    0                      0               0
19                       0                    0                      0               0
20                       0                    0                      0               0
21                 1115950              2452093          0              25
22                  615760              1279106           0              10
23                     350                 7301                 0               0
24                       0                    0                      0               0
25                  116216               101340            0               0
26                    7428                12824               0               0
27                       0                    0                      0               0
28                       0                    0                      0               0
mgmt1               0                    0                      0               0
TOTAL              5724413       5745178              29            45
Expand
Отключаю линк с  TurboIron-X24 и clear statistics
sh statistics brief
  Quote
1                        0                    0               0               0
2                  3413229              1644473               0               0
3                        0                    0               0               0
4                     1659                    0               0               0
5                        0                    0               0               0
6                        0                    0               0               0
7                        0                    0               0               0
8                        0                    0               0               0
9                        0                    0               0               0
10                       0                    0               0               0
11                       0                    0               0               0
12                       0                    0               0               0
13                       0                    0               0               0
14                       0                    0               0               0
15                       0                    0               0               0
16                       0                    0               0               0
17                       0                    0               0               0
18                       0                    0               0               0
19                       0                    0               0               0
20                       0                    0               0               0
21                  988128              2184347               0               0
22                  560213              1153673               0               0
23                     313                 6541               0               0
24                       0                    0               0               0
25                  104069                91371               0               0
26                    6503                11402               0               0
27                       0                    0               0               0
28                       0                    0               0               0
mgmt1                    0                    0               0               0
TOTAL              5074114              5091807               0               0
Expand
    • Від skybetik
      sh statistics brief
      sh statistics brief
