maxmax 6 Опубликовано: 2009-09-18 22:29:01 Share Опубликовано: 2009-09-18 22:29:01 1. Cisco 3825 , ее конфигурация: Cisco 3825 (revision 1.0) with 1011712K/36864K bytes of memory. Processor board ID FCZ095370N0 2 Gigabit Ethernet interfaces 1 Virtual Private Network (VPN) Module DRAM configuration is 64 bits wide with parity enabled. 479K bytes of NVRAM. 250368K bytes of ATA System CompactFlash (Read/Write) 2. Cisco AS5300, ee конфигурация: cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory. Processor board ID 12998279 R4700 CPU at 150MHz, Implementation 33, Rev 1.0, 512KB L2 Cache Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). Primary Rate ISDN software, Version 1.1. Backplane revision 2 Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30, Board Hardware Version 1.80, Item Number 800-2544-03, Board Revision A0, Serial Number 12998279, PLD/ISP Version 0.0, Manufacture Date 16-Mar-1999. 1 Ethernet/IEEE 802.3 interface(s) 1 FastEthernet/IEEE 802.3 interface(s) 124 Serial network interface(s) 4 Channelized E1/PRI port(s) 60 DSP(s), 60 Voice resource(s) 128K bytes of non-volatile configuration memory. 16384K bytes of processor board System flash (Read/Write) 8192K bytes of processor board Boot flash (Read/Write) Кому интересно, предлагайте цены в личку или др контакты в профайле. Ссылка на сообщение Поделиться на других сайтах
