Freebsd 7
Здравствуйте!
Имеется фря 7. Был аптайм в 38 дней и внезапно ребутнулсо на следующий день опять.
крутится bind,stargazer, apache,mysql, ntp
В чем может быть проблема?
Вот мессагес
Oct 9 00:11:59 billing-host kernel: 65534 Deny UDP 62.67.45.10:3724 212.111.196.219:8450 in via nfe0
Oct 9 00:23:06 billing-host kernel: 1 212.111.196.217:41212 in via nfe0
Oct 9 01:00:00 billing-host kernel: <01:00:001 1s0y>isp
Oct 9 01:00:00 billing-host kernel: f<w: 118>logd: /va
Oct 9 01:00:00 billing-host kernel: r</log/imapd1.1l0o>g65
Oct 9 01:00:00 billing-host kernel: 5<34 Den11y8 >T:
Oct 9 01:00:00 billing-host kernel: <No such file1 1o0r> CP
Oct 9 01:00:00 billing-host kernel: <92.112.2281.118>1d
Oct 9 01:00:00 billing-host kernel: i<rectory
Oct 9 01:00:00 billing-host kernel: 110>:2322 212.111.196.217:41212 in via nfe0
Oct 9 02:18:03 billing-host kernel: 65534 Deny UDP 213.79.68.98:51308 212.111.196.219:27336 in via nfe0
Oct 9 02:50:54 billing-host kernel: 65534 Deny TCP 94.198.111.121:59156 212.111.196.219:27336 in via nfe0
Oct 9 08:02:28 billing-host kernel:
Oct 9 10:14:15 billing-host kernel: 65534 Deny UDP 95.30.108.224:26931 212.111.196.219:27336 in via nfe0
Oct 9 10:26:42 billing-host kernel: arp: 10.10.10.40 moved from 00:1d:72:27:c9:c1 to 00:1b:38:ca:07:a1 on rl0
Oct 9 11:33:28 billing-host kernel: n
Oct 9 11:52:07 billing-host kernel: 60161 in via nfe0
Oct 9 12:15:31 billing-host kernel: Limiting closed port RST response from 505 to 200 packets/sec
Oct 9 12:26:16 billing-host kernel: Limiting closed port RST response from 484 to 200 packets/sec
Oct 9 12:26:30 billing-host kernel: U
Oct 9 13:21:27 billing-host syslogd: kernel boot file is /boot/kernel/kernel
Oct 9 13:21:27 billing-host kernel: Copyright © 1992-2008 The FreeBSD Project.
Oct 9 13:21:27 billing-host kernel: Copyright © 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Oct 9 13:21:27 billing-host kernel: The Regents of the University of California. All rights reserved.
Oct 9 13:21:27 billing-host kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Oct 9 13:21:27 billing-host kernel: FreeBSD 7.0-RELEASE #1: Wed Jul 30 22:58:30 EEST 2008
Oct 9 13:21:27 billing-host kernel: morfey@billing-host:/usr/obj/usr/src/sys/GENERIC
Oct 9 13:21:27 billing-host kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Oct 9 13:21:27 billing-host kernel: CPU: AMD Athlon 64 X2 Dual Core Processor 4600+ (2410.98-MHz 686-class CPU)
Oct 9 13:21:27 billing-host kernel: Origin = "AuthenticAMD" Id = 0x40f33 Stepping = 3
Oct 9 13:21:27 billing-host kernel: Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLU
SH,MMX,FXSR,SSE,SSE2,HTT>
Oct 9 13:21:27 billing-host kernel: Features2=0x2001<SSE3,CX16>
Oct 9 13:21:27 billing-host kernel: AMD Features=0xea500800<SYSCALL,NX,MMX+,FFXSR,RDTSCP,LM,3DNow!+,3DNow!>
Oct 9 13:21:27 billing-host kernel: AMD Features2=0x1f<LAHF,CMP,SVM,ExtAPIC,CR8>
Oct 9 13:21:27 billing-host kernel: Cores per package: 2
Oct 9 13:21:27 billing-host kernel: real memory = 2012938240 (1919 MB)
Oct 9 13:21:27 billing-host kernel: avail memory = 1959743488 (1868 MB)
Oct 9 13:21:27 billing-host kernel: ACPI APIC Table: <A_M_I_ OEMAPIC >
Oct 9 13:21:27 billing-host kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Oct 9 13:21:27 billing-host kernel: cpu0 (BSP): APIC ID: 0
Oct 9 13:21:27 billing-host kernel: cpu1 (AP): APIC ID: 1
Oct 9 13:21:27 billing-host kernel: ioapic0 <Version 1.1> irqs 0-23 on motherboard
Oct 9 13:21:27 billing-host kernel: kbd1 at kbdmux0
Oct 9 13:21:27 billing-host kernel: ath_hal: 0.9.20.3 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413)
Oct 9 13:21:27 billing-host kernel: hptrr: HPT RocketRAID controller driver v1.1 (Jul 30 2008 22:58:16)
Oct 9 13:21:27 billing-host kernel: acpi0: <A_M_I_ OEMRSDT> on motherboard
Oct 9 13:21:27 billing-host kernel: acpi0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: acpi0: Power Button (fixed)
Oct 9 13:21:27 billing-host kernel: unknown: I/O range not supported
Oct 9 13:21:27 billing-host kernel: acpi0: reservation of 0, a0000 (3) failed
Oct 9 13:21:27 billing-host kernel: acpi0: reservation of 100000, 77f00000 (3) failed
Oct 9 13:21:27 billing-host kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
Oct 9 13:21:27 billing-host kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x508-0x50b on acpi0
Oct 9 13:21:27 billing-host kernel: acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Oct 9 13:21:27 billing-host kernel: Timecounter "HPET" frequency 25000000 Hz quality 900
Oct 9 13:21:27 billing-host kernel: cpu0: <ACPI CPU> on acpi0
Oct 9 13:21:27 billing-host kernel: powernow0: <PowerNow! K8> on cpu0
Oct 9 13:21:27 billing-host kernel: cpu1: <ACPI CPU> on acpi0
Oct 9 13:21:27 billing-host kernel: powernow1: <PowerNow! K8> on cpu1
Oct 9 13:21:27 billing-host kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Oct 9 13:21:27 billing-host kernel: pci0: <ACPI PCI bus> on pcib0
Oct 9 13:21:27 billing-host kernel: pci0: <memory, RAM> at device 0.0 (no driver attached)
Oct 9 13:21:27 billing-host kernel: isab0: <PCI-ISA bridge> port 0x900-0x9ff at device 1.0 on pci0
Oct 9 13:21:27 billing-host kernel: isa0: <ISA bus> on isab0
Oct 9 13:21:27 billing-host kernel: pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
Oct 9 13:21:27 billing-host kernel: pci0: <memory, RAM> at device 1.2 (no driver attached)
Oct 9 13:21:27 billing-host kernel: ohci0: <OHCI (generic) USB controller> mem 0xdfeff000-0xdfefffff irq 21 at device 2.0 on pci0
Oct 9 13:21:27 billing-host kernel: ohci0: [GIANT-LOCKED]
Oct 9 13:21:27 billing-host kernel: ohci0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: usb0: OHCI version 1.0, legacy support
Oct 9 13:21:27 billing-host kernel: usb0: <OHCI (generic) USB controller> on ohci0
Oct 9 13:21:27 billing-host kernel: usb0: USB revision 1.0
Oct 9 13:21:27 billing-host kernel: uhub0: <nVidia OHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb0
Oct 9 13:21:27 billing-host kernel: uhub0: 8 ports with 8 removable, self powered
Oct 9 13:21:27 billing-host kernel: ehci0: <EHCI (generic) USB 2.0 controller> mem 0xdfefec00-0xdfefecff irq 22 at device 2.1 on pci0
Oct 9 13:21:27 billing-host kernel: ehci0: [GIANT-LOCKED]
Oct 9 13:21:27 billing-host kernel: ehci0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: usb1: EHCI version 1.0
Oct 9 13:21:27 billing-host kernel: usb1: companion controller, 10 ports each: usb0
Oct 9 13:21:27 billing-host kernel: usb1: <EHCI (generic) USB 2.0 controller> on ehci0
Oct 9 13:21:27 billing-host kernel: usb1: USB revision 2.0
Oct 9 13:21:27 billing-host kernel: uhub1: <nVidia EHCI root hub, class 9/0, rev 2.00/1.00, addr 1> on usb1
Oct 9 13:21:27 billing-host kernel: uhub1: 8 ports with 8 removable, self powered
Oct 9 13:21:27 billing-host kernel: pcib1: <ACPI PCI-PCI bridge> at device 4.0 on pci0
Oct 9 13:21:27 billing-host kernel: pci1: <ACPI PCI bus> on pcib1
Oct 9 13:21:27 billing-host kernel: rl0: <RealTek 8139 10/100BaseTX> port 0xe800-0xe8ff mem 0xdffffc00-0xdffffcff irq 16 at device 6.0 on pci1
Oct 9 13:21:27 billing-host kernel: miibus0: <MII bus> on rl0
Oct 9 13:21:27 billing-host kernel: rlphy0: <RealTek internal media interface> PHY 0 on miibus0
Oct 9 13:21:27 billing-host kernel: rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
Oct 9 13:21:27 billing-host kernel: rl0: Ethernet address: 00:e0:4c:50:34:d3
Oct 9 13:21:27 billing-host kernel: rl0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: pci0: <multimedia> at device 5.0 (no driver attached)
Oct 9 13:21:27 billing-host kernel: atapci0: <nVidia nForce MCP61 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xffa0-0xffaf at device 6.0 on pci0
Oct 9 13:21:27 billing-host kernel: ata0: <ATA channel 0> on atapci0
Oct 9 13:21:27 billing-host kernel: ata0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: ata1: <ATA channel 1> on atapci0
Oct 9 13:21:27 billing-host kernel: ata1: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: nfe0: <NVIDIA nForce MCP61 Networking Adapter> port 0xd480-0xd487 mem 0xdfefd000-0xdfefdfff irq 20 at device 7.0 on pci0
Oct 9 13:21:27 billing-host kernel: miibus1: <MII bus> on nfe0
Oct 9 13:21:27 billing-host kernel: ukphy0: <Generic IEEE 802.3u media interface> PHY 1 on miibus1
Oct 9 13:21:27 billing-host kernel: ukphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
Oct 9 13:21:27 billing-host kernel: nfe0: Ethernet address: 00:1e:8c:66:47:08
Oct 9 13:21:27 billing-host kernel: nfe0: [FILTER]
Oct 9 13:21:27 billing-host last message repeated 7 times
Oct 9 13:21:27 billing-host kernel: atapci1: <nVidia nForce MCP61 SATA300 controller> port 0xd400-0xd407,0xd080-0xd083,0xd000-0xd007,0xcc00-0xcc03,0xc880-0xc88f mem 0xdfefc000-0xdfefcfff irq 21 at device 8.0 on pci0
Oct 9 13:21:27 billing-host kernel: atapci1: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: ata2: <ATA channel 0> on atapci1
Oct 9 13:21:27 billing-host kernel: ata2: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: ata3: <ATA channel 1> on atapci1
Oct 9 13:21:27 billing-host kernel: ata3: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: pcib2: <ACPI PCI-PCI bridge> at device 9.0 on pci0
Oct 9 13:21:27 billing-host kernel: pci2: <ACPI PCI bus> on pcib2
Oct 9 13:21:27 billing-host kernel: pcib3: <ACPI PCI-PCI bridge> at device 11.0 on pci0
Oct 9 13:21:27 billing-host kernel: pci3: <ACPI PCI bus> on pcib3
Oct 9 13:21:27 billing-host kernel: pcib4: <ACPI PCI-PCI bridge> at device 12.0 on pci0
Oct 9 13:21:27 billing-host kernel: pci4: <ACPI PCI bus> on pcib4
Oct 9 13:21:27 billing-host kernel: vgapci0: <VGA-compatible display> mem 0xde000000-0xdeffffff,0xc0000000-0xcfffffff,0xdd000000-0xddffffff irq 22 at device 13.0 on pci0
Oct 9 13:21:27 billing-host kernel: acpi_button0: <Power Button> on acpi0
Oct 9 13:21:27 billing-host kernel: atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Oct 9 13:21:27 billing-host kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Oct 9 13:21:27 billing-host kernel: kbd0 at atkbd0
Oct 9 13:21:27 billing-host kernel: atkbd0: [GIANT-LOCKED]
Oct 9 13:21:27 billing-host kernel: atkbd0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Oct 9 13:21:27 billing-host kernel: sio0: type 16550A
Oct 9 13:21:27 billing-host kernel: sio0: [FILTER]
Oct 9 13:21:27 billing-host kernel: pmtimer0 on isa0
Oct 9 13:21:27 billing-host kernel: orm0: <ISA Option ROM> at iomem 0xc0000-0xcefff pnpid ORM0000 on isa0
Oct 9 13:21:27 billing-host kernel: ppc0: <Parallel port> at port 0x378-0x37f irq 7 on isa0
Oct 9 13:21:27 billing-host kernel: ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
Oct 9 13:21:27 billing-host kernel: ppbus0: <Parallel port bus> on ppc0
Oct 9 13:21:27 billing-host kernel: ppbus0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: plip0: <PLIP network interface> on ppbus0
Oct 9 13:21:27 billing-host kernel: lpt0: <Printer> on ppbus0
Oct 9 13:21:27 billing-host kernel: lpt0: Interrupt-driven port
Oct 9 13:21:27 billing-host kernel: ppi0: <Parallel I/O> on ppbus0
Oct 9 13:21:27 billing-host kernel: ppc0: [GIANT-LOCKED]
Oct 9 13:21:27 billing-host kernel: ppc0: [iTHREAD]
Oct 9 13:21:27 billing-host kernel: sc0: <System console> at flags 0x100 on isa0
Oct 9 13:21:27 billing-host kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Oct 9 13:21:27 billing-host kernel: sio1: configured irq 3 not in bitmap of probed irqs 0
Oct 9 13:21:27 billing-host kernel: sio1: port may not be enabled
Oct 9 13:21:27 billing-host kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Oct 9 13:21:27 billing-host kernel: Timecounters tick every 1.000 msec
Oct 9 13:21:27 billing-host kernel: IP Filter: v4.1.28 initialized. Default = pass all, Logging = enabled
Oct 9 13:21:27 billing-host kernel: ipfw2 (+ipv6) initialized, divert enabled, rule-based forwarding enabled, default to accept, logging unlimited
Oct 9 13:21:27 billing-host kernel: hptrr: no controller detected.
Oct 9 13:21:27 billing-host kernel: ad4: 114473MB <WDC WD1200AAJS-00VTA0 01.01B01> at ata2-master SATA300
Oct 9 13:21:27 billing-host kernel: ad6: 114473MB <WDC WD1200AAJS-00VTA0 01.01B01> at ata3-master SATA300
Oct 9 13:21:27 billing-host kernel: SMP: AP CPU #1 Launched!
Oct 9 13:21:27 billing-host kernel: Trying to mount root from ufs:/dev/ad4s1a
Oct 9 13:21:27 billing-host kernel: WARNING: / was not properly dismounted
Oct 9 13:21:27 billing-host kernel: WARNING: /home was not properly dismounted
Oct 9 13:21:27 billing-host kernel: WARNING: /var was not properly dismounted
Oct 9 13:21:27 billing-host kernel: WARNING: /var/db was not properly dismounted
Oct 9 13:21:27 billing-host savecore: reboot after panic: page fault
Oct 9 13:21:27 billing-host savecore: writing core to vmcore.3
Oct 9 13:21:28 billing-host kernel: rl0: link state changed to UP
Oct 9 13:21:46 billing-host named[754]: starting BIND 9.4.2 -u bind -t /var/named -u bind
Oct 9 13:21:46 billing-host named[754]: command channel listening on 127.0.0.1#953
Oct 9 13:21:46 billing-host named[754]: logging channel 'default_ch' file '/var/log/dns/named.log': file not found
Oct 9 13:21:46 billing-host named[754]: logging channel 'security_ch' file '/var/log/dns/security.log': file not found
Oct 9 13:21:46 billing-host named[754]: isc_log_open '/var/log/dns/named.log' failed: file not found
Oct 9 13:21:46 billing-host kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Oct 9 13:21:46 billing-host ntpd: logging to file /var/log/ntpd.log
Oct 9 13:21:56 billing-host upsd[860]: /usr/local/etc/nut/upsd.conf is world readable
Oct 9 13:21:56 billing-host upsd[860]: ACL in upsd.conf is no longer supported - switch to LISTEN
Oct 9 13:21:56 billing-host upsd[860]: ACCEPT in upsd.conf is no longer supported - switch to LISTEN
Oct 9 13:21:56 billing-host upsd[860]: /usr/local/etc/nut/upsd.users is world readable
Oct 9 13:21:56 billing-host upsd[860]: allowfrom in upsd.users is no longer used
Oct 9 13:22:01 billing-host snmpd[973]: mibII/mta_sendmail.c:open_sendmailst: could not guess version of statistics file "/var/log/sendmail.st"
Oct 9 13:22:01 billing-host snmpd[973]: /usr/local/share/snmp/snmpd.conf: line 78: Error: Blank line following proc token.
Oct 9 13:22:01 billing-host snmpd[973]: net-snmp: 1 error(s) in config file(s)
Oct 9 13:22:02 billing-host snmpd[973]: /usr/local/share/snmp/snmpd.conf: line 78: Error: Blank line following proc token.
Oct 9 13:22:02 billing-host snmpd[973]: /usr/local/share/snmp/snmpd.conf: line 145: Error: example config COMMUNITY not properly configured
Oct 9 13:22:02 billing-host snmpd[973]: /usr/local/share/snmp/snmpd.conf: line 146: Error: example config COMMUNITY not properly configured
Oct 9 13:22:02 billing-host snmpd[973]: net-snmp: 3 error(s) in config file(s)
Oct 9 13:23:00 billing-host su: morfey to root on /dev/ttyp0
Oct 9 13:23:39 billing-host fsck: /dev/ad4s1d: 11644 files, 201740 used, 7413899 free (2307 frags, 926449 blocks, 0.0% fragmentation)
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: UNREF FILE I=919449 OWNER=mysql MODE=100600
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: SIZE=0 MTIME=Oct 8 13:19 2009 (CLEARED)
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: UNREF FILE I=919461 OWNER=mysql MODE=100600
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: SIZE=147 MTIME=Oct 9 04:00 2009 (CLEARED)
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: UNREF FILE I=919462 OWNER=mysql MODE=100600
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: UNREF FILE I=919463 OWNER=mysql MODE=100600
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: UNREF FILE I=919466 OWNER=mysql MODE=100600
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: UNREF FILE I=942111 OWNER=root MODE=140666
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: Reclaimed: 0 directories, 5 files, -9 fragments
Oct 9 13:24:03 billing-host fsck: /dev/ad4s1e: 97071 files, 1248758 used, 6258234 free (3594 frags, 781830 blocks, 0.0% fragmentation)
Oct 9 13:24:19 billing-host su: morfey to root on /dev/ttyp1
Oct 9 13:25:53 billing-host fsck: /dev/ad6s1d: 29289 files, 6226162 used, 50538833 free (27185 frags, 6313956 blocks, 0.0% fragmentation)
