rntf 0 Posted 2005-06-13 23:41:57 Share Posted 2005-06-13 23:41:57 У меня Фрибздя 5.1 Настраиваю по мануалу! Делал уже все что угодно...не могу пингонуть шлюз провайдера 10.2.0.1, а узел 192.168.100.1 пингует без проблем! хелп плиз! И не могу зайти в и-нет! Собственно сабж в студию: ipfw: #!/bin/sh fwcmd="/sbin/ipfw" natdcmd="/sbin/natd" int_if="rl1" ext_if="rl0" ${fwcmd} -f flush ${natdcmd} -s -m -u -a 10.2.4.193 ${fwcmd} add 10 allow icmp from any to any #${fwcmd} add 300 deny ip from any to 192.168.0.0/16 out via ${ext_if} #${fwcmd} add 301 deny ip from any to 10.0.0.0/16 out via ${ext_if} #${fwcmd} add 302 deny ip from any to 172.16.0.0/12 out via ${ext_if} ${fwcmd} add 306 allow tcp from 10.10.10.1 to 10.10.10.10 5555 via ${int_if} ${fwcmd} add 307 allow tcp from 10.10.10.10 5555 to 10.10.10.1 via ${int_if} ${fwcmd} add 308 allow udp from any to 10.10.10.10 8888 via ${int_if} ${fwcmd} add 309 allow udp from 10.10.10.10 to any via ${int_if} ${fwcmd} add 310 allow tcp from 10.10.10.1 to 10.10.10.10 22 via ${int_if} #${fwcmd} add 311 allow tcp from 10.10.10.2 to 10.10.10.10 22 via ${int_if} #${fwcmd} add 312 allow tcp from 10.10.10.3 to 10.10.10.10 22 via ${int_if} ${fwcmd} add 313 allow tcp from 10.10.10.10 to any via ${int_if} ${fwcmd} add 320 deny log ip from 10.10.10.0/23 to 10.10.10.10 via ${int_if} ${fwcmd} add 321 deny log ip from 10.10.10.0/23 to 10.2.4.193 via ${int_if} ${fwcmd} add 50024 divert natd all from any to any via ${ext_if} ${fwcmd} add 50029 allow tcp from any to any out via ${ext_if} setup ${fwcmd} add 50030 allow tcp from any to any via ${ext_if} established ${fwcmd} add 50031 allow udp from any to any out via ${ext_if} ${fwcmd} add 50032 allow udp from any 53 to any in via ${ext_if} ${fwcmd} add 50033 allow udp from any to any via any ${fwcmd} add 65534 deny log ip from any to any скрипт OnConnect fwcmd=”/sbin/ipfw” int_if="rl1" # Login LOGIN=$1 #user IP #echo $2 ip=$2 #user ID id=$4 ${fwcmd} add `expr $id '*' 10 + 29001` allow ip from $2 to any via ${int_if} echo "connected `date +%Y.%m.%d_______%H:%M:%S` $1 $2" >> /var/log/connect.log ХЕЛП ПЛИЗ!! Link to post Share on other sites
rntf 0 Posted 2005-06-14 12:36:56 Author Share Posted 2005-06-14 12:36:56 Отвечу сам! ВОТ ПРАВИЛЬНЫЙ ФАЕРВОЛ...ТОТ, КОТОРЫЙ работает при этих скриптах он коннект и дисконнект! #!/bin/sh fwcmd="/sbin/ipfw" natdcmd="/sbin/natd" int_if="rl1" ext_if="rl0" ${fwcmd} -f flush ${natdcmd} -s -m -u -a 10.2.4.193 ${fwcmd} add 1 divert natd ip from any to any via ${ext_if} ${fwcmd} add 10 allow icmp from any to any #${fwcmd} add 300 deny ip from any to 192.168.0.0/16 out via ${ext_if} #${fwcmd} add 301 deny ip from any to 10.0.0.0/16 out via ${ext_if} #${fwcmd} add 302 deny ip from any to 172.16.0.0/12 out via ${ext_if} ${fwcmd} add 306 allow tcp from 10.10.10.1 to 10.10.10.10 5555 via ${int_if} ${fwcmd} add 307 allow tcp from 10.10.10.10 5555 to 10.10.10.1 via ${int_if} ${fwcmd} add 308 allow udp from any to 10.10.10.10 8888 via ${int_if} ${fwcmd} add 309 allow udp from 10.10.10.10 to any via ${int_if} ${fwcmd} add 310 allow tcp from 10.10.10.1 to 10.10.10.10 22 via ${int_if} #${fwcmd} add 311 allow tcp from 10.10.10.2 to 10.10.10.10 22 via ${int_if} #${fwcmd} add 312 allow tcp from 10.10.10.3 to 10.10.10.10 22 via ${int_if} ${fwcmd} add 313 allow tcp from 10.10.10.10 to any via ${int_if} ${fwcmd} add 320 deny log ip from 10.10.10.0/23 to 10.10.10.10 via ${int_if} ${fwcmd} add 321 deny log ip from 10.10.10.0/23 to 10.2.4.193 via ${int_if} ${fwcmd} add 50029 allow tcp from 10.10.10.0/23 to any out via ${ext_if} ${fwcmd} add 50030 allow tcp from any to 10.10.10.0/23 in via ${ext_if} ${fwcmd} add 50031 allow tcp from any to any out xmit ${ext_if} setup ${fwcmd} add 50032 allow tcp from any to any via ${ext_if} established ${fwcmd} add 50035 allow udp from any to any out via ${ext_if} ${fwcmd} add 50036 allow udp from any 53 to any in via ${ext_if} ${fwcmd} add 50037 allow udp from any to any via any ${fwcmd} add 65534 deny log ip from any to any теперь скрипт OnConnect fwcmd="/sbin/ipfw" int_if="rl1" LOGIN=$1 ip=$2 id=$4 ${fwcmd} add `expr $id '*' 10 + 29000` allow ip from $ip to any via ${int_if} ${fwcmd} add `expr $id '*' 10 + 29001` allow ip from any to $ip via ${int_if} echo "connected `date +%Y.%m.%d______%H:%M:%S` $1 $2" >> /var/log/connect.log А вот и OnDisconnect ##!/sbin/sh fwcmd="/sbin/ipfw" int_if="rl1" LOGIN=$1 ip=$2 CASH=$3 id=$4 ${fwcmd} delete `expr $id '*' 10 + 29000` ${fwcmd} delete `expr $id '*' 10 + 29001` echo "disconnected `date +%Y.%m.%d_____%H:%M:%S` $1 $2 " >> /var/log/connect.log Коментс: rl1 это внутрений интерфейс, который смотрит в мою сеть rl0 это внешний, который смотрит в и-нет Link to post Share on other sites
denz 0 Posted 2005-06-14 18:48:50 Share Posted 2005-06-14 18:48:50 Отвечу сам! ВОТ ПРАВИЛЬНЫЙ ФАЕРВОЛ...ТОТ, КОТОРЫЙ работает при этих скриптах он коннект и дисконнект! #!/bin/sh fwcmd="/sbin/ipfw" natdcmd="/sbin/natd" int_if="rl1" ext_if="rl0" ${fwcmd} -f flush ${natdcmd} -s -m -u -a 10.2.4.193 ${fwcmd} add 1 divert natd ip from any to any via ${ext_if} ${fwcmd} add 10 allow icmp from any to any #${fwcmd} add 300 deny ip from any to 192.168.0.0/16 out via ${ext_if} #${fwcmd} add 301 deny ip from any to 10.0.0.0/16 out via ${ext_if} #${fwcmd} add 302 deny ip from any to 172.16.0.0/12 out via ${ext_if} ${fwcmd} add 306 allow tcp from 10.10.10.1 to 10.10.10.10 5555 via ${int_if} ${fwcmd} add 307 allow tcp from 10.10.10.10 5555 to 10.10.10.1 via ${int_if} ${fwcmd} add 308 allow udp from any to 10.10.10.10 8888 via ${int_if} ${fwcmd} add 309 allow udp from 10.10.10.10 to any via ${int_if} ${fwcmd} add 310 allow tcp from 10.10.10.1 to 10.10.10.10 22 via ${int_if} #${fwcmd} add 311 allow tcp from 10.10.10.2 to 10.10.10.10 22 via ${int_if} #${fwcmd} add 312 allow tcp from 10.10.10.3 to 10.10.10.10 22 via ${int_if} ${fwcmd} add 313 allow tcp from 10.10.10.10 to any via ${int_if} ${fwcmd} add 320 deny log ip from 10.10.10.0/23 to 10.10.10.10 via ${int_if} ${fwcmd} add 321 deny log ip from 10.10.10.0/23 to 10.2.4.193 via ${int_if} ${fwcmd} add 50029 allow tcp from 10.10.10.0/23 to any out via ${ext_if} ${fwcmd} add 50030 allow tcp from any to 10.10.10.0/23 in via ${ext_if} ${fwcmd} add 50031 allow tcp from any to any out xmit ${ext_if} setup ${fwcmd} add 50032 allow tcp from any to any via ${ext_if} established ${fwcmd} add 50035 allow udp from any to any out via ${ext_if} ${fwcmd} add 50036 allow udp from any 53 to any in via ${ext_if} ${fwcmd} add 50037 allow udp from any to any via any ${fwcmd} add 65534 deny log ip from any to any теперь скрипт OnConnect fwcmd="/sbin/ipfw" int_if="rl1" LOGIN=$1 ip=$2 id=$4 ${fwcmd} add `expr $id '*' 10 + 29000` allow ip from $ip to any via ${int_if} ${fwcmd} add `expr $id '*' 10 + 29001` allow ip from any to $ip via ${int_if} echo "connected `date +%Y.%m.%d______%H:%M:%S` $1 $2" >> /var/log/connect.log А вот и OnDisconnect ##!/sbin/sh fwcmd="/sbin/ipfw" int_if="rl1" LOGIN=$1 ip=$2 CASH=$3 id=$4 ${fwcmd} delete `expr $id '*' 10 + 29000` ${fwcmd} delete `expr $id '*' 10 + 29001` echo "disconnected `date +%Y.%m.%d_____%H:%M:%S` $1 $2 " >> /var/log/connect.log Коментс: rl1 это внутрений интерфейс, который смотрит в мою сеть rl0 это внешний, который смотрит в и-нет разобрадся...? молодец... хочу подсказать, в 5-ой ветке фрибсд по дефолту собирается ipfw2... и еще, почитай внимательно в тех же манах что за правило у тебя 50032 (!) иначе долго будет стоять немой вопрос в глазах... что по фаеру... стучи 12107764 Link to post Share on other sites
