Sorvi_Golova 0 Опубликовано: 2010-08-08 21:39:49 Share Опубликовано: 2010-08-08 21:39:49 Подскажите, пожалуйста, что это за ошибка при компиляции? make[2]: Leaving directory `/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/plugins/capture/ipq_linux' make -C store/mysql make[2]: Entering directory `/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/plugins/store/mysql' make[2]: Leaving directory `/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/plugins/store/mysql' make[2]: Entering directory `/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/plugins/store/mysql' cc -c mysql_store.cpp -I/usr/local/include -DARCH_LE -I/usr/include/mysql -pipe -march=i586 -mtune=i686 -fomit-frame-pointer -D_FILE_OFFSET_BITS=64 -DHAVE_ERRNO_AS_DEFINE -DONE_THREAD -fPIC -I /opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/../../include -DNDEBUG -DLINUX cc mysql_store.o /opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/../../lib/libconffiles.so /opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/../../lib/libstg_common.so /opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/../../lib/libstg_crypto.so -L/usr/local/lib -shared -L/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/../../lib -Wl,-rpath,/usr/lib/stg -L/usr/lib -lmysqlclient_r -lz -lpthread -lcrypt -lnsl -lm -lpthread -L/usr/lib -lssl -lcrypto -o mod_store_mysql.so /usr/bin/ld: cannot find -lz collect2: ld returned 1 exit status make[2]: *** [mod_store_mysql.so] Error 1 make[2]: Leaving directory `/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/plugins/store/mysql' make[1]: *** [store/mysql] Error 2 make[1]: Leaving directory `/opt/install/stg-2.4-2010.04.16-15.33.33/projects/stargazer/plugins' make: *** [plugins] Error 2 [root@www stargazer]# Пытался в скрипте "build" запретить использовать модуль мускула CHECK_MYSQLCLIENT=no в 244 строку вставил. Компилится нормально и запускается. Если пытаюсь с модулем мускула запустить то пишет, что либы нету, подсунуть с старой версии не удалось. 2010-08-09 00:28:13 -- Storage plugin: 'Error loading plugin '/usr/lib/stg/mod_store_mysql.so': '/usr/lib/stg/mod_store_mysql.so: undefined symbol: _Z12DecodeStringPcPKcP12BLOWFISH_CTX'' Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-08-09 07:06:09 Share Опубліковано: 2010-08-09 07:06:09 Очевидно же, нет библиотеки libz.so Логику не понял: запретить компиляцию модуля и тут-же его использовать. Это как-то... противоестественно Ссылка на сообщение Поделиться на других сайтах
Sorvi_Golova 0 Опубліковано: 2010-08-09 09:31:09 Автор Share Опубліковано: 2010-08-09 09:31:09 Очевидно же, нет библиотеки libz.so Логику не понял: запретить компиляцию модуля и тут-же его использовать. Это как-то... противоестественно Спасибо, установка одного из пакетов с именем как то вот так zlib*****c++ помогла. Немогу ничего понять. У меня сейчас денег на счету 0, предоплаченный трафик 180грн, кредит 0. А в интернет всеравно пускает. Раньше если Денег на счету меньше чем предоплаченных то отключало. Это в конфиге что-то не правильно? Почему не отключает интернет? Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-08-10 07:03:24 Share Опубліковано: 2010-08-10 07:03:24 Очевидно же, нет библиотеки libz.so Логику не понял: запретить компиляцию модуля и тут-же его использовать. Это как-то... противоестественно Спасибо, установка одного из пакетов с именем как то вот так zlib*****c++ помогла. Немогу ничего понять. У меня сейчас денег на счету 0, предоплаченный трафик 180грн, кредит 0. А в интернет всеравно пускает. Раньше если Денег на счету меньше чем предоплаченных то отключало. Это в конфиге что-то не правильно? Почему не отключает интернет? Если денег ровно 0 (или больше чем "-кредит") - пускает. И так было всегда, была тайга, жыли в ней белка Карамон, лисица Хулаки и птица Кукша. Условие отключение: счет меньше 0. А еще в настройках есть параметр FreeMbAllowInet позволяющий выпускать в инет если есть бесплатные мегабайты. Ссылка на сообщение Поделиться на других сайтах
anatom 0 Опубліковано: 2010-09-13 16:48:11 Share Опубліковано: 2010-09-13 16:48:11 помогите!!! не могу установить stargazer. при вводе команды ./build выбивает такое Checking endianess... Little Endian Checking for -lexpat... no Checking for -lfbclient... no Checking for mysql_config... no Checking for -lmysqlclient... no Checking for pg_config... no Checking for -lpq... no -lexpat not found! при продолжении make install выбивает такое Makefile:5: ../../Makefile.conf: Нет такого файла или каталога make: Попытка пересобрать make-файл `../../Makefile.conf' неуспешна. mkdir -m -p /usr/sbin mkdir: неверный режим «-p» make: *** [install-bin] Ошибка 1 версия програмы stg-2,406 в чем проблема??? Ссылка на сообщение Поделиться на других сайтах
Neelix 33 Опубліковано: 2010-09-13 17:00:01 Share Опубліковано: 2010-09-13 17:00:01 в чем проблема??? в прокладке между стулом и клавиатурой Checking endianess... Little Endian Checking for -lexpat... no Checking for -lfbclient... no Checking for mysql_config... no Checking for -lmysqlclient... no Checking for pg_config... no Checking for -lpq... no -lexpat not found! я х.... Ссылка на сообщение Поделиться на других сайтах
nightfly 1 255 Опубліковано: 2010-09-13 17:57:16 Share Опубліковано: 2010-09-13 17:57:16 шо, вообще никаких хидеров? Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-09-13 18:06:54 Share Опубліковано: 2010-09-13 18:06:54 помогите!!! не могу установить stargazer. при вводе команды ./build выбивает такое Checking endianess... Little Endian Checking for -lexpat... no Checking for -lfbclient... no Checking for mysql_config... no Checking for -lmysqlclient... no Checking for pg_config... no Checking for -lpq... no -lexpat not found! при продолжении make install выбивает такое Makefile:5: ../../Makefile.conf: Нет такого файла или каталога make: Попытка пересобрать make-файл `../../Makefile.conf' неуспешна. mkdir -m -p /usr/sbin mkdir: неверный режим «-p» make: *** [install-bin] Ошибка 1 версия програмы stg-2,406 в чем проблема??? Поставить expat как минимум и expat-dev (или как он там в вашем дистрибутиве называется). Ну и да - не стоит пытаться установить то что не смогл собраться шо, вообще никаких хидеров? К сожалению, я не по хидерам проверяю. А надо бы... Ссылка на сообщение Поделиться на других сайтах
yKpon 8 Опубліковано: 2010-09-14 05:41:40 Share Опубліковано: 2010-09-14 05:41:40 скажу по секрету всему свету, чтобы собрать stargazer нужно установить gcc g++ make libexpat libexpat1-dev expat libmysqlclient15-dev Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-09-14 06:54:43 Share Опубліковано: 2010-09-14 06:54:43 скажу по секрету всему свету, чтобы собрать stargazer нужно установить gcc g++ make libexpat libexpat1-dev expat libmysqlclient15-dev Из expat/libexpat одно явно лишнее, и libmysqlclient не нужен. Ссылка на сообщение Поделиться на других сайтах
anatom 0 Опубліковано: 2010-10-02 14:20:32 Share Опубліковано: 2010-10-02 14:20:32 люди подскажите как старгейзер на авто запуск ставить,при в ключении компа он не запускаеться,только через sudo stargazer.но такой возможности писать это каждый раз нету!!! Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-10-04 07:56:13 Share Опубліковано: 2010-10-04 07:56:13 люди подскажите как старгейзер на авто запуск ставить,при в ключении компа он не запускаеться,только через sudo stargazer.но такой возможности писать это каждый раз нету!!! Linux? Быстро и грязно - прописать в rc.local Правильно - написать rc-скрипт или взять готовый из projects/stargazer/int/linux/etc/init.d Ссылка на сообщение Поделиться на других сайтах
anatom 0 Опубліковано: 2010-11-06 22:09:42 Share Опубліковано: 2010-11-06 22:09:42 люди подскажите как старгейзер на авто запуск ставить,при в ключении компа он не запускаеться,только через sudo stargazer.но такой возможности писать это каждый раз нету!!! Linux? Быстро и грязно - прописать в rc.local Правильно - написать rc-скрипт или взять готовый из projects/stargazer/int/linux/etc/init.d а можно поточнее о том как прописать в rc.local потому что стандартный скрипт выдает ошибки Ссылка на сообщение Поделиться на других сайтах
anatom 0 Опубліковано: 2010-11-07 09:45:20 Share Опубліковано: 2010-11-07 09:45:20 и еше вопрос при запущеном старгейзере поидее основная машина не должна выходить в интернет без авторизатора? и что сделать чтоб все остальные ходили в инет через старгейзер? Ссылка на сообщение Поделиться на других сайтах
Небесный 26 Опубліковано: 2010-11-07 10:52:07 Share Опубліковано: 2010-11-07 10:52:07 Ну, не поленитесь, прочитайте до конца документацию по старгейзеру. Вот она, если вы вдруг не знаете где ее брать - http://stg.dp.ua/download/other/stargazer_help_v2.13.pdf Там, не так уж и много читать, и у вас после прочтения этого документа сразу половина вопросов отпадет, что вы задавали. Через rc.local запускаем стж - отриваем сам файл, вписываем туда строчку sudo stargazer и вуаля - стж запускается сам после перезагрузки. После прочтения документации прочитать следующие темы, я уже наперед знаю какие будут вопросы: 1. Там же есть настьройка iptables(фаервола). 2. Там же есть как настроить скрипты OnConnect, OnDisconect. Читаем: http://stargazer.dp.ua/doc20/conf_server.html http://stargazer.dp.ua/doc20/conf_example_linux.html Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-11-07 17:03:27 Share Опубліковано: 2010-11-07 17:03:27 люди подскажите как старгейзер на авто запуск ставить,при в ключении компа он не запускаеться,только через sudo stargazer.но такой возможности писать это каждый раз нету!!! Linux? Быстро и грязно - прописать в rc.local Правильно - написать rc-скрипт или взять готовый из projects/stargazer/int/linux/etc/init.d а можно поточнее о том как прописать в rc.local потому что стандартный скрипт выдает ошибки Берем любимый текстовый редактор и открываем им /etc/rc.local. Там пишем такую строчку: /usr/sbin/stargazer /etc/stargazer Это быстрое и грязное решение. Правильное решение будет зависеть от того что у вас за дистрибутив. Не все скрипты из указанного каталога вам подойдут. А может нужного там и нету вовсе - тогда имеет смысл его написать самому и прислать мне, я его включу в стандартную поставку. Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-11-07 17:06:04 Share Опубліковано: 2010-11-07 17:06:04 и еше вопрос при запущеном старгейзере поидее основная машина не должна выходить в интернет без авторизатора? и что сделать чтоб все остальные ходили в инет через старгейзер? Основная машина - это какая машина? Чтобы управлять доступом нужно настроить файрвол и скрипты OnConnect/OnDisconnect. Задавайте более четкие вопросы, оперируя понятиями "роутер", "локальная сеть", "канал", "интерфейс" и т.д. А то не очень понятно о чем именно спрашиваете. Ссылка на сообщение Поделиться на других сайтах
madf 279 Опубліковано: 2010-11-07 17:08:10 Share Опубліковано: 2010-11-07 17:08:10 Ну, не поленитесь, прочитайте до конца документацию по старгейзеру. Вот она, если вы вдруг не знаете где ее брать - http://stg.dp.ua/download/other/stargazer_help_v2.13.pdf Там, не так уж и много читать, и у вас после прочтения этого документа сразу половина вопросов отпадет, что вы задавали. Через rc.local запускаем стж - отриваем сам файл, вписываем туда строчку sudo stargazer и вуаля - стж запускается сам после перезагрузки. После прочтения документации прочитать следующие темы, я уже наперед знаю какие будут вопросы: 1. Там же есть настьройка iptables(фаервола). 2. Там же есть как настроить скрипты OnConnect, OnDisconect. Читаем: http://stargazer.dp.ua/doc20/conf_server.html http://stargazer.dp.ua/doc20/conf_example_linux.html Зачем sudo в /etc/rc.local? Оно и так от рута запустит. А если цель запускать не от рута - он не будет работать. Ссылка на сообщение Поделиться на других сайтах
Небесный 26 Опубліковано: 2010-11-07 18:07:43 Share Опубліковано: 2010-11-07 18:07:43 Зачем sudo в /etc/rc.local? Оно и так от рута запустит. А если цель запускать не от рута - он не будет работать. Угумсь, только сейчас понял это, я раньше вообще просто писал в рц.локал просто stargazer. ))) Ссылка на сообщение Поделиться на других сайтах
