strellson 282 Опубликовано: 2010-12-17 17:38:54 Share Опубликовано: 2010-12-17 17:38:54 Продаю коммутатор Juniper EX4200-48T-DC Switch 48-port, цена $2950 Form Factor * Fixed platform (single switch) * Virtual Chassis configuration consisting of 10 switches Dimensions * (W x H x D) 17.4 x 1.7 x 16.4 in (44.2 x 4.3 x 41.7 cm) * 1 rack unit (single switch) Backplane Speed 128 Gbps (Virtual Chassis) Data Rate * EX4200-24P/24T/24F: 88 Gbps * EX4200-48P/48T: 136 Gbps Throughput * EX4200-24P/24T/24F: 65 Mpps (wire speed) * EX4200-48P/48T: 101 Mpps (wire speed) 10/100/1000BASE-T Port Densities * 24 / 48 per platform * Up to 480 in Virtual Chassis configuration 100BASE-FX / 1000BASE-X (SFP) Port Densities * 24 per switch; 28 with optional four-port GbE uplink module * Up to 280 in Virtual Chassis configuration 10GBASE-X Port Densities * 2 per switch (via optional two-port 10GbE uplink module) * Up to 20 in Virtual Chassis configuration Resiliency Internal, hot-swappable redundant power supply; field-replaceable fan tray with three fans; graceful Route Engine switchover (GRES) in Virtual Chassis configuration Power Options * AC: 320W, 600W and 930W autosensing; 100-120V / 200-240V; dual load-sharing hot-swappable internal redundant power supplies * DC: 190W: input voltage range 36V-72V; dual input feed, dual load-sharing hot-swappable internal redundant power supplies Operating System Junos Traffic Monitoring sFlow QoS Queues / Port 8 MAC Addresses 24,000 Jumbo Frames 9216 Bytes IPv4 Unicast / Multicast Routes 16,000 / 8,000 Number of VLANs 4,096 ARP Entries 16,000 Ссылка на сообщение Поделиться на других сайтах
