Brandcomputers 23 Опубликовано: 2011-02-22 22:22:09 Share Опубликовано: 2011-02-22 22:22:09 Сверх навороченые свичи третьего уровня 48 портов два резервных питания . Один недостаток нету гигабитных модулей. Если достать бы .... ех. цены на Ebay там же есть и модуля. http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=+Matrix+1H582-51&_sacat=See-All-Categories заберёте все 5 шт. отдам по 85$ 1 шт. по 95 Приехали из Франции .В отл. состоянии. цена за 1 шт. Ports : Fourty-Eight (48) fixed 10/100 ports Management ports : One (1) DB-9 RJ45 serial console Management protocols : Industry-standard CLI or embedded web server, NetSight; RMON, SNMPv3, Telnet Access via SSHv2 encryption Firmware Version : 03.07.23 Power Supply : Dual AC power supplies Flash Size : 8MB DRAM : 64MB Rackmount Brackets : Not Included Model Number : 1H582-51 Part Number : 1H582-51 Condition : Used, tested, working, and sold with warranty. Missing three Module Slot covers Ideally suited to high-performance workgroup deployment, the Matrix E1 1H582-51 Workgroup Switch (WS) is wire-speed Layer 3 switch with full IP and IPX routing functionality. The 1H582-51 provides 48 fixed 10/100 Ethernet ports and three flexible expansion slots. In the Matrix WS switch, the expansion slots support 10/100 and Gigabit Ethernet connectivity. These switches feature a robust set of switching and routing features and built-in support for RMON, port-trunking and port-mirroring capability as well as redundant AC power supplies. Using advanced multilayer frameclassification, these switches allow network administrators to meet business needs by differentiating between business-critical and non business-critical traffic, without sacrificing performance. Additionally, the 1H582-51 offers wire-speed performance and industry-leading switching and routing features that allow it to seamlessly integrate into enterprise and service provider networks. Ссылка на сообщение Поделиться на других сайтах
Brandcomputers 23 Опубликовано: 2011-03-13 19:39:17 Автор Share Опубликовано: 2011-03-13 19:39:17 Инструкция . http://www.andovercg.com/datasheets/matrix-e1-series.pdf Ссылка на сообщение Поделиться на других сайтах
