sergeev 1 Опубликовано: 2012-02-06 15:12:57 Share Опубликовано: 2012-02-06 15:12:57 Quagga(10.31.255.212) не видит анонсы сетей с Alpine 3802(10.31.255.213). Альпина наоборот, все что не объявлю в Кваге, видит прекрасно. Т.е. на Кваге делаю network 35.0.0.0/8 В альпине Alpine: show bgp routes all Destination Peer Next-Hop LPref Weight MED AS-Path *i35.0.0.0 /8 10.31.255.212 10.31.255.212 100 1 0 65231 На Альпине анонсирую configure bgp add network 40.0.0.0 255.0.0.0 В Кваге show ip bgp neighbors 10.31.255.213 routes - ПУСТО Конфиг Кваги hostname bgpd password zebra log file /etc/quagga/bgpd.log log syslog ! router bgp 65231 bgp router-id 10.31.255.212 network 35.0.0.0/8 neighbor 10.31.255.213 remote-as 65530 ! line vty Конфиг Alpine 3802 # BGP Router Configuration configure bgp AS-number 65530 configure bgp routerid 10.31.255.213 configure bgp local-preference 100 configure bgp maximum-prefix 0 configure bgp med none disable bgp deterministic-med disable bgp always-compare-med enable bgp synchronization enable bgp advertise-inactive-route disable bgp community format AS-number : number disable bgp aggregation configure bgp add network 40.0.0.0 255.0.0.0 disable bgp export direct disable bgp export static disable bgp export rip disable bgp export ospf disable bgp export ospf-intra disable bgp export ospf-inter disable bgp export ospf-extern1 disable bgp export ospf-extern2 enable bgp export vip enable bgp export isis # BGP Neighbor Configuration create bgp neighbor 10.31.255.212 remote-AS-number 65231 configure bgp neighbor 10.31.255.212 source-interface vlan "Default" configure bgp neighbor 10.31.255.212 weight 1 configure bgp neighbor 10.31.255.212 timer keep-alive 60 hold-time 180 configure bgp neighbor 10.31.255.212 dont-send-community disable bgp neighbor 10.31.255.212 soft-in-reset disable bgp neighbor 10.31.255.212 fast-failover configure bgp neighbor 10.31.255.212 nlri-filter in None configure bgp neighbor 10.31.255.212 nlri-filter out None configure bgp neighbor 10.31.255.212 as-path-filter in None configure bgp neighbor 10.31.255.212 as-path-filter out None configure bgp neighbor 10.31.255.212 route-map-filter in None configure bgp neighbor 10.31.255.212 route-map-filter out None configure bgp neighbor 10.31.255.212 no-next-hop-self configure bgp neighbor 10.31.255.212 maximum-prefix 0 configure bgp neighbor 10.31.255.212 password none configure bgp neighbor 10.31.255.212 peer-group none disable bgp neighbor 10.31.255.212 remove-private-AS-numbers configure bgp neighbor 10.31.255.212 no-dampening enable bgp neighbor 10.31.255.212 enable bgp Ссылка на сообщение Поделиться на других сайтах
supportod 1 Опубликовано: 2012-02-19 15:24:18 Share Опубликовано: 2012-02-19 15:24:18 покажите версию quagga и sh ip bgp sum Ссылка на сообщение Поделиться на других сайтах
