dnk80 1 Опубликовано: 2012-03-01 20:55:41 Share Опубликовано: 2012-03-01 20:55:41 Продам маршрутизатор Cisco 3640 128D/16F & NM-1E2W & WIC-1B-S/T 650грн Все рабочее, внешний вид на 3 (есть царапины и помятости на крышке корпуса), нет декоративной пластиковой панели. Router#sh ver Cisco Internetwork Operating System Software IOS 3600 Software (C3640-IK9S-M), Version 12.2(10b), RELEASE SOFTWARE (fc1) Copyright © 1986-2002 by cisco Systems, Inc. Compiled Thu 11-Jul-02 14:58 by pwade Image text-base: 0x60008930, data-base: 0x61236000 ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Router uptime is 1 minute System returned to ROM by power-on System image file is "flash:c3640-ik9s-mz.122-10b" cisco 3640 (R4700) processor (revision 0x00) with 126976K/4096K bytes of memory. Processor board ID 07674636 R4700 CPU at 100Mhz, Implementation 33, Rev 1.0 Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). Basic Rate ISDN software, Version 1.1. 1 Ethernet/IEEE 802.3 interface(s) 1 ISDN Basic Rate interface(s) DRAM configuration is 64 bits wide with parity disabled. 125K bytes of non-volatile configuration memory. 16384K bytes of processor board System flash (Read/Write) Configuration register is 0x2102 Router#sh diag Slot 1: Combo 1E, 2W Port adapter, 3 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.2 Board revision B0 Serial number 11396679 Part number 800-01789-05 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 37 01 02 00 AD E6 47 50 06 FD </span> </span> </span>05 00 00 00 00</span></span> </span></span> </span> 0x30: 58 00 00 00 98 12 19 17 FF FF FF FF FF FF FF FF WIC Slot 0: BRI S/T - 2186 WAN daughter card Hardware revision 1.3 Board revision A0 Serial number 10391885 Part number 800-01833-02 Test history 0x0 RMA number 00-00-00 Connector type Wan Module EEPROM format version 1 EEPROM contents (hex): 0x20: 01 07 01 03 00 9E 91 4D 50 07 29 02 00 00 00 00 0x30: 50 00 00 00 98 09 04 01 FF FF FF FF FF FF FF FF Ссылка на сообщение Поделиться на других сайтах
