NETOS 137 Опубликовано: 2012-03-06 08:04:41 Share Опубликовано: 2012-03-06 08:04:41 Привет админам! Помогите решить проблему. Три дня назад запустил сервер, каждый день пользовался ним, ставил биллинг. Много раз перезагружал, РРРоЕ подымалось без проблем. Сегодня утром пришел включил и не подключилось. Прикладываю настройки и логи. /usr/local/etc/mpd5/mpd.conf startup: set user login parol admin set console self 127.0.0.1 5005 default: load pppoe_client pppoe_client: create bundle static B1 set iface route default set ipcp ranges 0.0.0.0/0 0.0.0.0/0 set ipcp enable req-pri-dns set ipcp enable req-sec-dns create link static L1 pppoe set link action bundle B1 set auth authname name set auth password pass set link max-redial 0 set link mtu 1460 set link keep-alive 20 75 set pppoe iface rl1 set pppoe service "" open /etc/tc.conf gateway_enable="YES" inetd_enable="YES" keymap="ru.koi8-r" sshd_enable="YES" ifconfig_rl1="DHCP" ifconfig_rl0="DHCP" ifconfig_ng0="DHCP" hostname="server" mpd_enable="YES" webmin_enable="YES" mysql_enable="YES" apache22_enable="YES" Mar 6 09:56:16 server mpd: [b1] IPCP: SendConfigReq #42 Mar 6 09:56:16 server mpd: [b1] IPADDR МОЙ ИП Mar 6 09:56:16 server mpd: [b1] PRIDNS ПРИМАРИ ДНС Mar 6 09:56:16 server mpd: [b1] SECDNS СЕКОНДАРИ ДНС Mar 6 09:56:18 server mpd: [b1] IPCP: parameter negotiation failed Mar 6 09:56:18 server mpd: [b1] IPCP: state change Req-Sent --> Stopped Mar 6 09:56:18 server mpd: [b1] IPCP: LayerFinish Mar 6 09:56:18 server mpd: [b1] Bundle: No NCPs left. Closing links... Mar 6 09:56:18 server mpd: [b1] Bundle: closing link "L1"... Mar 6 09:56:18 server mpd: [L1] Link: CLOSE event Mar 6 09:56:18 server mpd: [L1] LCP: Close event Mar 6 09:56:18 server mpd: [L1] LCP: state change Opened --> Closing Mar 6 09:56:18 server mpd: [L1] Link: Leave bundle "B1" Mar 6 09:56:18 server mpd: [b1] Bundle: Status update: up 0 links, total bandwidth 9600 bps Mar 6 09:56:18 server mpd: [b1] IPCP: Close event Mar 6 09:56:18 server mpd: [b1] IPCP: state change Stopped --> Closed Mar 6 09:56:18 server mpd: [b1] IPCP: Down event Mar 6 09:56:18 server mpd: [b1] IPCP: state change Closed --> Initial Mar 6 09:56:18 server mpd: [L1] LCP: SendTerminateReq #10 Mar 6 09:56:18 server mpd: [L1] LCP: LayerDown Mar 6 09:56:20 server mpd: [L1] LCP: SendTerminateReq #11 Mar 6 09:56:22 server mpd: [L1] LCP: state change Closing --> Closed Mar 6 09:56:22 server mpd: [L1] LCP: LayerFinish Mar 6 09:56:22 server mpd: [L1] Link: DOWN event Mar 6 09:56:22 server mpd: [L1] LCP: Down event Mar 6 09:56:22 server mpd: [L1] LCP: state change Closed --> Initial Еще заметил что в файле /etc/resolv.conf когда РРРоЕ работал то DHCP там писал search xxx.xxx.xxx.xxx. А сейчас прописывает конкретно два DNS сервера nameserver xxx.xxx.xxx.xxx Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубліковано: 2012-03-06 08:26:39 Share Опубліковано: 2012-03-06 08:26:39 какой биллинг ? нужно от этого исходит, у каждого биллинга свои настройки и конфиги радиуса и мпд, Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-06 08:30:23 Автор Share Опубліковано: 2012-03-06 08:30:23 Биллинг MikBill http://www.celteh.com/dokumentatsiya/mikbill-freebsd.html настройку завершил на пункте Создаем сертификат. Но не думаю что в этом проблема. Перед созданием сертификата работало, но сертификат создал непонятно как. Что то наклацал. Если в этом проблема как его удалить? Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубліковано: 2012-03-06 08:52:31 Share Опубліковано: 2012-03-06 08:52:31 В 06.03.2012 в 08:30, Tooreagen сказав: Биллинг MikBill http://www.celteh.co...ll-freebsd.html настройку завершил на пункте Создаем сертификат. Но не думаю что в этом проблема. Перед созданием сертификата работало, но сертификат создал непонятно как. Что то наклацал. Если в этом проблема как его удалить? на форуме у них отписался с проблемой ? Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-06 08:55:27 Автор Share Опубліковано: 2012-03-06 08:55:27 нет сразу сюда... но замечу что еще до установки биллинга как-то было такое. не мог понять в чем проблема, просто переставил ОС и заработало. Ссылка на сообщение Поделиться на других сайтах
kvirtu 315 Опубліковано: 2012-03-06 09:03:29 Share Опубліковано: 2012-03-06 09:03:29 В 06.03.2012 в 08:55, Tooreagen сказав: нет сразу сюда... но замечу что еще до установки биллинга как-то было такое. не мог понять в чем проблема, просто переставил ОС и заработало. Думаю там тебе помогут быстрее, ну и если что то поломалось, имхо сразу ось переустанавливать - не выход. Нужно причину искать , очень много можно из логов системы найти. Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-06 10:30:56 Автор Share Опубліковано: 2012-03-06 10:30:56 Ну вот я и прошу вас помочь. Вот простоял 1,5 часа, перезагрузил и подключилось. Что не так может быть? Ссылка на сообщение Поделиться на других сайтах
Mobil 68 Опубліковано: 2012-03-06 11:08:57 Share Опубліковано: 2012-03-06 11:08:57 Какая сетевая карточка стоит у тебя? Тюнинг карты делал ? Пробовал пересобрать ядро без flowtable ? Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-06 12:15:14 Автор Share Опубліковано: 2012-03-06 12:15:14 Ядро не пробовал пересобрать. Сетевуха обычная D-Link это для пробы просто, дальше куплю лучше. На другом серваке такие стоят пока хватает. Ссылка на сообщение Поделиться на других сайтах
maxx 202 Опубліковано: 2012-03-06 12:23:32 Share Опубліковано: 2012-03-06 12:23:32 Авторизация радиусом? Сертификаты апача абсолютно не причем судя по логам грабли таки в настройке связки радиус мпд. Ссылка на сообщение Поделиться на других сайтах
Mobil 68 Опубліковано: 2012-03-06 12:55:50 Share Опубліковано: 2012-03-06 12:55:50 В 06.03.2012 в 12:15, Tooreagen сказав: Ядро не пробовал пересобрать. Сетевуха обычная D-Link это для пробы просто, дальше куплю лучше. На другом серваке такие стоят пока хватает. Сетевую бери Intel хотя бы самую обычную, но все равно разницу потом сам почувствуешь. А ядро обязательно пересобрать нужно, в этом 100% проблема. Для пппое протокола может мешать flowtable по этому пересобери ядро без этой опции, ну и в принципе все остальное лишнее что тебе не нужно в работе тоже убери. Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-06 12:58:17 Автор Share Опубліковано: 2012-03-06 12:58:17 Д В 06.03.2012 в 12:23, maxx сказав: Авторизация радиусом? Сертификаты апача абсолютно не причем судя по логам грабли таки в настройке связки радиус мпд. дело в том что радиус я даже еще и не настраивал. Ссылка на сообщение Поделиться на других сайтах
jack 25 Опубліковано: 2012-03-06 14:07:18 Share Опубліковано: 2012-03-06 14:07:18 выложите полный лог mpd и настройки фаервола Ссылка на сообщение Поделиться на других сайтах
maxx 202 Опубліковано: 2012-03-06 14:33:57 Share Опубліковано: 2012-03-06 14:33:57 В 06.03.2012 в 12:58, Tooreagen сказав: дело в том что радиус я даже еще и не настраивал. вопрос нумбер ван а откуда оно берет логин и пасс? нумбер цвай полный лог одного подключения от начала авторизации то разрыва линка. startup: log +ALL log +PPTP +AUTH +bund + ccp +iface +ipcp +lcp +link +phys set user admin bla bla set console self 127.0.0.1 5005 set console open set web self bla.bla.bla.bla 5006 set web open включи полный лог в конфиге мпд и на 1 тестовом соединении рой логи. нумбер драй. Что происходит на стороне клиента когда он пытается законектиться на "нерабочий" мпд. Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-06 15:33:20 Автор Share Опубліковано: 2012-03-06 15:33:20 В 06.03.2012 в 14:07, jack сказав: выложите полный лог mpd и настройки фаервола Полный лог ОК. Фаервол вообще еще не установлен даже. В 06.03.2012 в 14:33, maxx сказав: В 06.03.2012 в 12:58, Tooreagen сказав: дело в том что радиус я даже еще и не настраивал. вопрос нумбер ван а откуда оно берет логин и пасс? нумбер цвай полный лог одного подключения от начала авторизации то разрыва линка. startup: log +ALL log +PPTP +AUTH +bund + ccp +iface +ipcp +lcp +link +phys set user admin bla bla set console self 127.0.0.1 5005 set console open set web self bla.bla.bla.bla 5006 set web open включи полный лог в конфиге мпд и на 1 тестовом соединении рой логи. нумбер драй. Что происходит на стороне клиента когда он пытается законектиться на "нерабочий" мпд. 1. Как откуда? mpd.conf гласит: set auth authname name set auth password pass 2. Полный лог ОК. 3. Это не сервер РРРоЕ это я так подключаюсь к провайдеру. ЛОГ: Mar 6 17:29:24 server mpd: Multi-link PPP daemon for FreeBSD Mar 6 17:29:24 server mpd: Mar 6 17:29:24 server mpd: process 885 started, version 5.5 (root@server.bb.slav.dn.ua 14:34 3-Mar-2012) Mar 6 17:29:25 server mpd: [b1] Bundle: Interface ng0 created Mar 6 17:29:25 server mpd: [L1] Link: OPEN event Mar 6 17:29:25 server mpd: [L1] LCP: Open event Mar 6 17:29:25 server mpd: [L1] LCP: state change Initial --> Starting Mar 6 17:29:25 server mpd: [L1] LCP: LayerStart Mar 6 17:29:25 server mpd: [L1] PPPoE: Connecting to '' Mar 6 17:29:25 server mpd: PPPoE: rec'd ACNAME "bb-core.slav.dn.ua" Mar 6 17:29:25 server mpd: [L1] PPPoE: connection successful Mar 6 17:29:25 server mpd: [L1] Link: UP event Mar 6 17:29:25 server mpd: [L1] LCP: Up event Mar 6 17:29:25 server mpd: [L1] LCP: state change Starting --> Req-Sent Mar 6 17:29:25 server mpd: [L1] LCP: SendConfigReq #1 Mar 6 17:29:25 server mpd: [L1] PROTOCOMP Mar 6 17:29:25 server mpd: [L1] MRU 1492 Mar 6 17:29:25 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:27 server mpd: [L1] LCP: SendConfigReq #2 Mar 6 17:29:27 server mpd: [L1] PROTOCOMP Mar 6 17:29:27 server mpd: [L1] MRU 1492 Mar 6 17:29:27 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:27 server mpd: [L1] LCP: rec'd Configure Reject #2 (Req-Sent) Mar 6 17:29:27 server mpd: [L1] PROTOCOMP Mar 6 17:29:27 server mpd: [L1] LCP: SendConfigReq #3 Mar 6 17:29:27 server mpd: [L1] MRU 1492 Mar 6 17:29:27 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:27 server mpd: [L1] LCP: rec'd Configure Ack #3 (Req-Sent) Mar 6 17:29:27 server mpd: [L1] MRU 1492 Mar 6 17:29:27 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:27 server mpd: [L1] LCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:29 server mpd: [L1] LCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:29 server mpd: [L1] LCP: SendConfigReq #4 Mar 6 17:29:29 server mpd: [L1] MRU 1492 Mar 6 17:29:29 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:29 server mpd: [L1] LCP: rec'd Configure Ack #4 (Req-Sent) Mar 6 17:29:29 server mpd: [L1] MRU 1492 Mar 6 17:29:29 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:29 server mpd: [L1] LCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:31 server mpd: [L1] LCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:31 server mpd: [L1] LCP: SendConfigReq #5 Mar 6 17:29:31 server mpd: [L1] MRU 1492 Mar 6 17:29:31 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:33 server mpd: [L1] LCP: SendConfigReq #6 Mar 6 17:29:33 server mpd: [L1] MRU 1492 Mar 6 17:29:33 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:33 server mpd: [L1] LCP: rec'd Configure Ack #6 (Req-Sent) Mar 6 17:29:33 server mpd: [L1] MRU 1492 Mar 6 17:29:33 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:33 server mpd: [L1] LCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:35 server mpd: [L1] LCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:35 server mpd: [L1] LCP: SendConfigReq #7 Mar 6 17:29:35 server mpd: [L1] MRU 1492 Mar 6 17:29:35 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:35 server mpd: [L1] LCP: rec'd Configure Ack #7 (Req-Sent) Mar 6 17:29:35 server mpd: [L1] MRU 1492 Mar 6 17:29:35 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:35 server mpd: [L1] LCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:37 server mpd: [L1] LCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:37 server mpd: [L1] LCP: SendConfigReq #8 Mar 6 17:29:37 server mpd: [L1] MRU 1492 Mar 6 17:29:37 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:37 server mpd: [L1] LCP: rec'd Configure Ack #8 (Req-Sent) Mar 6 17:29:37 server mpd: [L1] MRU 1492 Mar 6 17:29:37 server mpd: [L1] MAGICNUM 7a1c9b5c Mar 6 17:29:37 server mpd: [L1] LCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:37 server mpd: [L1] LCP: rec'd Configure Request #1 (Ack-Rcvd) Mar 6 17:29:37 server mpd: [L1] AUTHPROTO CHAP MD5 Mar 6 17:29:37 server mpd: [L1] MAGICNUM 86048ae6 Mar 6 17:29:37 server mpd: [L1] LCP: SendConfigAck #1 Mar 6 17:29:37 server mpd: [L1] AUTHPROTO CHAP MD5 Mar 6 17:29:37 server mpd: [L1] MAGICNUM 86048ae6 Mar 6 17:29:37 server mpd: [L1] LCP: state change Ack-Rcvd --> Opened Mar 6 17:29:37 server mpd: [L1] LCP: auth: peer wants CHAP, I want nothing Mar 6 17:29:37 server mpd: [L1] LCP: LayerUp Mar 6 17:29:37 server mpd: [L1] CHAP: rec'd CHALLENGE #237 len: 41 Mar 6 17:29:37 server mpd: [L1] Name: "bb-core.slav.dn.ua" Mar 6 17:29:37 server mpd: [L1] CHAP: Using authname "semen-wifi" Mar 6 17:29:37 server mpd: [L1] CHAP: sending RESPONSE #237 len: 31 Mar 6 17:29:39 server mpd: [L1] CHAP: sending RESPONSE #237 len: 31 Mar 6 17:29:39 server mpd: [L1] CHAP: rec'd SUCCESS #237 len: 12 Mar 6 17:29:39 server mpd: [L1] MESG: Login OK Mar 6 17:29:39 server mpd: [L1] LCP: authorization successful Mar 6 17:29:39 server mpd: [L1] Link: Matched action 'bundle "B1" ""' Mar 6 17:29:39 server mpd: [L1] Link: Join bundle "B1" Mar 6 17:29:39 server mpd: [b1] Bundle: Status update: up 1 link, total bandwidth 64000 bps Mar 6 17:29:39 server mpd: [b1] IPCP: Open event Mar 6 17:29:39 server mpd: [b1] IPCP: state change Initial --> Starting Mar 6 17:29:39 server mpd: [b1] IPCP: LayerStart Mar 6 17:29:39 server mpd: [b1] IPCP: Up event Mar 6 17:29:39 server mpd: [b1] IPCP: state change Starting --> Req-Sent Mar 6 17:29:39 server mpd: [b1] IPCP: SendConfigReq #1 Mar 6 17:29:39 server mpd: [b1] IPADDR 0.0.0.0 Mar 6 17:29:39 server mpd: [b1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Mar 6 17:29:39 server mpd: [b1] PRIDNS 0.0.0.0 Mar 6 17:29:39 server mpd: [b1] SECDNS 0.0.0.0 Mar 6 17:29:39 server mpd: [b1] IPCP: rec'd Configure Reject #1 (Req-Sent) Mar 6 17:29:39 server mpd: [b1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Mar 6 17:29:39 server mpd: [b1] IPCP: SendConfigReq #2 Mar 6 17:29:39 server mpd: [b1] IPADDR 0.0.0.0 Mar 6 17:29:39 server mpd: [b1] PRIDNS 0.0.0.0 Mar 6 17:29:39 server mpd: [b1] SECDNS 0.0.0.0 Mar 6 17:29:39 server mpd: [b1] IPCP: rec'd Configure Nak #2 (Req-Sent) Mar 6 17:29:39 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:39 server mpd: [b1] 188.239.193.21 is OK Mar 6 17:29:39 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:39 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:39 server mpd: [b1] IPCP: SendConfigReq #3 Mar 6 17:29:39 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:39 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:39 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:39 server mpd: [b1] IPCP: rec'd Configure Ack #3 (Req-Sent) Mar 6 17:29:39 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:39 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:39 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:39 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:41 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:41 server mpd: [b1] IPCP: SendConfigReq #4 Mar 6 17:29:41 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:41 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:41 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:43 server mpd: [b1] IPCP: SendConfigReq #5 Mar 6 17:29:43 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:43 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:43 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:43 server mpd: [b1] IPCP: rec'd Configure Ack #5 (Req-Sent) Mar 6 17:29:43 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:43 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:43 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:43 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:45 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:45 server mpd: [b1] IPCP: SendConfigReq #6 Mar 6 17:29:45 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:45 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:45 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:45 server mpd: [b1] IPCP: rec'd Configure Ack #6 (Req-Sent) Mar 6 17:29:45 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:45 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:45 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:45 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:47 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:47 server mpd: [b1] IPCP: SendConfigReq #7 Mar 6 17:29:47 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:47 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:47 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:47 server mpd: [b1] IPCP: rec'd Configure Ack #7 (Req-Sent) Mar 6 17:29:47 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:47 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:47 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:47 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:49 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:49 server mpd: [b1] IPCP: SendConfigReq #8 Mar 6 17:29:49 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:49 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:49 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:49 server mpd: [b1] IPCP: rec'd Configure Ack #8 (Req-Sent) Mar 6 17:29:49 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:49 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:49 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:49 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:51 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:51 server mpd: [b1] IPCP: SendConfigReq #9 Mar 6 17:29:51 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:51 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:51 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:51 server mpd: [b1] IPCP: rec'd Configure Ack #9 (Req-Sent) Mar 6 17:29:51 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:51 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:51 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:51 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:53 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:53 server mpd: [b1] IPCP: SendConfigReq #10 Mar 6 17:29:53 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:53 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:53 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:53 server mpd: [b1] IPCP: rec'd Configure Ack #10 (Req-Sent) Mar 6 17:29:53 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:53 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:53 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:53 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:55 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:55 server mpd: [b1] IPCP: SendConfigReq #11 Mar 6 17:29:55 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:55 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:55 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:57 server mpd: [b1] IPCP: SendConfigReq #12 Mar 6 17:29:57 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:57 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:57 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:57 server mpd: [b1] IPCP: rec'd Configure Ack #12 (Req-Sent) Mar 6 17:29:57 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:57 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:57 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:57 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:29:59 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:29:59 server mpd: [b1] IPCP: SendConfigReq #13 Mar 6 17:29:59 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:59 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:59 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:59 server mpd: [b1] IPCP: rec'd Configure Ack #13 (Req-Sent) Mar 6 17:29:59 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:29:59 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:29:59 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:29:59 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:30:01 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:30:01 server mpd: [b1] IPCP: SendConfigReq #14 Mar 6 17:30:01 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:01 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:01 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:01 server mpd: [b1] IPCP: rec'd Configure Ack #14 (Req-Sent) Mar 6 17:30:01 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:01 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:01 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:01 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:30:03 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:30:03 server mpd: [b1] IPCP: SendConfigReq #15 Mar 6 17:30:03 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:03 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:03 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:03 server mpd: [b1] IPCP: rec'd Configure Ack #15 (Req-Sent) Mar 6 17:30:03 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:03 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:03 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:03 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:30:05 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:30:05 server mpd: [b1] IPCP: SendConfigReq #16 Mar 6 17:30:05 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:05 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:05 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:05 server mpd: [b1] IPCP: rec'd Configure Ack #16 (Req-Sent) Mar 6 17:30:05 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:05 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:05 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:05 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 6 17:30:07 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 6 17:30:07 server mpd: [b1] IPCP: SendConfigReq #17 Mar 6 17:30:07 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:07 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:07 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:09 server mpd: [b1] IPCP: SendConfigReq #18 Mar 6 17:30:09 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:09 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:09 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:11 server mpd: [b1] IPCP: SendConfigReq #19 Mar 6 17:30:11 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:11 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:11 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:13 server mpd: [b1] IPCP: SendConfigReq #20 Mar 6 17:30:13 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:13 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:13 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:15 server mpd: [b1] IPCP: SendConfigReq #21 Mar 6 17:30:15 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:15 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:15 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:17 server mpd: [b1] IPCP: SendConfigReq #22 Mar 6 17:30:17 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:17 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:17 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:19 server mpd: [b1] IPCP: SendConfigReq #23 Mar 6 17:30:19 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:19 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:19 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:21 server mpd: [b1] IPCP: SendConfigReq #24 Mar 6 17:30:21 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:21 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:21 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:23 server mpd: [b1] IPCP: SendConfigReq #25 Mar 6 17:30:23 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:23 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:23 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:25 server mpd: [b1] IPCP: SendConfigReq #26 Mar 6 17:30:25 server mpd: [b1] IPADDR 188.239.193.21 Mar 6 17:30:25 server mpd: [b1] PRIDNS 193.228.2.2 Mar 6 17:30:25 server mpd: [b1] SECDNS 193.228.2.1 Mar 6 17:30:27 server mpd: [b1] IPCP: parameter negotiation failed Mar 6 17:30:27 server mpd: [b1] IPCP: state change Req-Sent --> Stopped Mar 6 17:30:27 server mpd: [b1] IPCP: LayerFinish Mar 6 17:30:27 server mpd: [b1] Bundle: No NCPs left. Closing links... Mar 6 17:30:27 server mpd: [b1] Bundle: closing link "L1"... Mar 6 17:30:27 server mpd: [L1] Link: CLOSE event Mar 6 17:30:27 server mpd: [L1] LCP: Close event Mar 6 17:30:27 server mpd: [L1] LCP: state change Opened --> Closing Mar 6 17:30:27 server mpd: [L1] Link: Leave bundle "B1" Mar 6 17:30:27 server mpd: [b1] Bundle: Status update: up 0 links, total bandwidth 9600 bps Mar 6 17:30:27 server mpd: [b1] IPCP: Close event Mar 6 17:30:27 server mpd: [b1] IPCP: state change Stopped --> Closed Mar 6 17:30:27 server mpd: [b1] IPCP: Down event Mar 6 17:30:27 server mpd: [b1] IPCP: state change Closed --> Initial Mar 6 17:30:27 server mpd: [L1] LCP: SendTerminateReq #9 Mar 6 17:30:27 server mpd: [L1] LCP: LayerDown Mar 6 17:30:29 server mpd: [L1] LCP: SendTerminateReq #10 Mar 6 17:30:31 server mpd: [L1] LCP: state change Closing --> Closed Mar 6 17:30:31 server mpd: [L1] LCP: LayerFinish Mar 6 17:30:31 server mpd: [L1] Link: DOWN event Mar 6 17:30:31 server mpd: [L1] LCP: Down event Mar 6 17:30:31 server mpd: [L1] LCP: state change Closed --> Initial Ссылка на сообщение Поделиться на других сайтах
Mobil 68 Опубліковано: 2012-03-06 15:37:36 Share Опубліковано: 2012-03-06 15:37:36 Я вам еще раз повторяю - пересоберите ядро и будем вам счастье или вам нравится тут обсуждать давно уже пройденные проблемы других админов ? Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-07 08:33:57 Автор Share Опубліковано: 2012-03-07 08:33:57 Пересобрал ядро! И ситуация не поменялась. Логи те же... Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-12 11:43:09 Автор Share Опубліковано: 2012-03-12 11:43:09 Короче переустановил систему, сразу пересобрал ядро. Начал настраивать по инструкции биллинг и заметил что после установки и настройки апача, перестало подключатся. Подскажите пожалуйста в чем проблема может быть? Какие логи и конфиги показать? Ссылка на сообщение Поделиться на других сайтах
Demeo 29 Опубліковано: 2012-03-12 11:58:06 Share Опубліковано: 2012-03-12 11:58:06 У вас ругается на Mar 6 17:30:27 server mpd: [b1] IPCP: parameter negotiation failed Попробуйте убрать set ipcp enable req-pri-dns set ipcp enable req-sec-dns Ссылка на сообщение Поделиться на других сайтах
NETOS 137 Опубліковано: 2012-03-12 12:24:23 Автор Share Опубліковано: 2012-03-12 12:24:23 Не помогло... Лог: Mar 12 14:12:42 server mpd: caught fatal signal term Mar 12 14:12:42 server mpd: [b1] IFACE: Close event Mar 12 14:12:42 server mpd: [b1] IPCP: Close event Mar 12 14:12:44 server mpd: [b1] Bundle: Shutdown Mar 12 14:12:44 server mpd: [L1] Link: Shutdown Mar 12 14:12:44 server mpd: process 888 terminated Mar 12 14:14:02 server mpd: Multi-link PPP daemon for FreeBSD Mar 12 14:14:02 server mpd: Mar 12 14:14:02 server mpd: process 897 started, version 5.6 (root@server 12:21 10-Mar-2012) Mar 12 14:14:02 server mpd: [b1] Bundle: Interface ng0 created Mar 12 14:14:03 server mpd: [L1] Link: OPEN event Mar 12 14:14:03 server mpd: [L1] LCP: Open event Mar 12 14:14:03 server mpd: [L1] LCP: state change Initial --> Starting Mar 12 14:14:03 server mpd: [L1] LCP: LayerStart Mar 12 14:14:03 server mpd: [L1] PPPoE: Connecting to '' Mar 12 14:14:03 server mpd: PPPoE: rec'd ACNAME "bb-core.slav.dn.ua" Mar 12 14:14:03 server mpd: [L1] PPPoE: connection successful Mar 12 14:14:03 server mpd: [L1] Link: UP event Mar 12 14:14:03 server mpd: [L1] LCP: Up event Mar 12 14:14:03 server mpd: [L1] LCP: state change Starting --> Req-Sent Mar 12 14:14:03 server mpd: [L1] LCP: SendConfigReq #1 Mar 12 14:14:03 server mpd: [L1] PROTOCOMP Mar 12 14:14:03 server mpd: [L1] MRU 1492 Mar 12 14:14:03 server mpd: [L1] MAGICNUM 32252291 Mar 12 14:14:03 server mpd: [L1] LCP: rec'd Configure Request #1 (Req-Sent) Mar 12 14:14:03 server mpd: [L1] AUTHPROTO CHAP MD5 Mar 12 14:14:03 server mpd: [L1] MAGICNUM 1e9d41cf Mar 12 14:14:03 server mpd: [L1] LCP: SendConfigAck #1 Mar 12 14:14:03 server mpd: [L1] AUTHPROTO CHAP MD5 Mar 12 14:14:03 server mpd: [L1] MAGICNUM 1e9d41cf Mar 12 14:14:03 server mpd: [L1] LCP: state change Req-Sent --> Ack-Sent Mar 12 14:14:03 server mpd: [L1] LCP: rec'd Configure Reject #1 (Ack-Sent) Mar 12 14:14:03 server mpd: [L1] PROTOCOMP Mar 12 14:14:03 server mpd: [L1] LCP: SendConfigReq #2 Mar 12 14:14:03 server mpd: [L1] MRU 1492 Mar 12 14:14:03 server mpd: [L1] MAGICNUM 32252291 Mar 12 14:14:03 server mpd: [L1] LCP: rec'd Configure Ack #2 (Ack-Sent) Mar 12 14:14:03 server mpd: [L1] MRU 1492 Mar 12 14:14:03 server mpd: [L1] MAGICNUM 32252291 Mar 12 14:14:03 server mpd: [L1] LCP: state change Ack-Sent --> Opened Mar 12 14:14:03 server mpd: [L1] LCP: auth: peer wants CHAP, I want nothing Mar 12 14:14:03 server mpd: [L1] LCP: LayerUp Mar 12 14:14:03 server mpd: [L1] CHAP: rec'd CHALLENGE #199 len: 41 Mar 12 14:14:03 server mpd: [L1] Name: "bb-core.slav.dn.ua" Mar 12 14:14:03 server mpd: [L1] CHAP: Using authname "semen-wifi" Mar 12 14:14:03 server mpd: [L1] CHAP: sending RESPONSE #199 len: 31 Mar 12 14:14:05 server mpd: [L1] CHAP: sending RESPONSE #199 len: 31 Mar 12 14:14:05 server mpd: [L1] CHAP: rec'd SUCCESS #199 len: 12 Mar 12 14:14:05 server mpd: [L1] MESG: Login OK Mar 12 14:14:05 server mpd: [L1] LCP: authorization successful Mar 12 14:14:05 server mpd: [L1] Link: Matched action 'bundle "B1" ""' Mar 12 14:14:05 server mpd: [L1] Link: Join bundle "B1" Mar 12 14:14:05 server mpd: [b1] Bundle: Status update: up 1 link, total bandwidth 64000 bps Mar 12 14:14:05 server mpd: [b1] IPCP: Open event Mar 12 14:14:05 server mpd: [b1] IPCP: state change Initial --> Starting Mar 12 14:14:05 server mpd: [b1] IPCP: LayerStart Mar 12 14:14:05 server mpd: [b1] IPCP: Up event Mar 12 14:14:05 server mpd: [b1] IPCP: state change Starting --> Req-Sent Mar 12 14:14:05 server mpd: [b1] IPCP: SendConfigReq #1 Mar 12 14:14:05 server mpd: [b1] IPADDR 0.0.0.0 Mar 12 14:14:05 server mpd: [b1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Mar 12 14:14:05 server mpd: [b1] IPCP: rec'd Configure Reject #1 (Req-Sent) Mar 12 14:14:05 server mpd: [b1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Mar 12 14:14:05 server mpd: [b1] IPCP: SendConfigReq #2 Mar 12 14:14:05 server mpd: [b1] IPADDR 0.0.0.0 Mar 12 14:14:05 server mpd: [b1] IPCP: rec'd Configure Nak #2 (Req-Sent) Mar 12 14:14:05 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:05 server mpd: [b1] 188.239.193.21 is OK Mar 12 14:14:05 server mpd: [b1] IPCP: SendConfigReq #3 Mar 12 14:14:05 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:05 server mpd: [b1] IPCP: rec'd Configure Ack #3 (Req-Sent) Mar 12 14:14:05 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:05 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:07 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:07 server mpd: [b1] IPCP: SendConfigReq #4 Mar 12 14:14:07 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:07 server mpd: [b1] IPCP: rec'd Configure Ack #4 (Req-Sent) Mar 12 14:14:07 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:07 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:09 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:09 server mpd: [b1] IPCP: SendConfigReq #5 Mar 12 14:14:09 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:09 server mpd: [b1] IPCP: rec'd Configure Ack #5 (Req-Sent) Mar 12 14:14:09 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:09 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:11 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:11 server mpd: [b1] IPCP: SendConfigReq #6 Mar 12 14:14:11 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:11 server mpd: [b1] IPCP: rec'd Configure Ack #6 (Req-Sent) Mar 12 14:14:11 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:11 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:13 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:13 server mpd: [b1] IPCP: SendConfigReq #7 Mar 12 14:14:13 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:13 server mpd: [b1] IPCP: rec'd Configure Ack #7 (Req-Sent) Mar 12 14:14:13 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:13 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:15 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:15 server mpd: [b1] IPCP: SendConfigReq #8 Mar 12 14:14:15 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:15 server mpd: [b1] IPCP: rec'd Configure Ack #8 (Req-Sent) Mar 12 14:14:15 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:15 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:17 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:17 server mpd: [b1] IPCP: SendConfigReq #9 Mar 12 14:14:17 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:17 server mpd: [b1] IPCP: rec'd Configure Ack #9 (Req-Sent) Mar 12 14:14:17 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:17 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:19 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:19 server mpd: [b1] IPCP: SendConfigReq #10 Mar 12 14:14:19 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:19 server mpd: [b1] IPCP: rec'd Configure Ack #10 (Req-Sent) Mar 12 14:14:19 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:19 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:21 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:21 server mpd: [b1] IPCP: SendConfigReq #11 Mar 12 14:14:21 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:21 server mpd: [b1] IPCP: rec'd Configure Ack #11 (Req-Sent) Mar 12 14:14:21 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:21 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:23 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:23 server mpd: [b1] IPCP: SendConfigReq #12 Mar 12 14:14:23 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:23 server mpd: [b1] IPCP: rec'd Configure Ack #12 (Req-Sent) Mar 12 14:14:23 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:23 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:25 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:25 server mpd: [b1] IPCP: SendConfigReq #13 Mar 12 14:14:25 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:25 server mpd: [b1] IPCP: rec'd Configure Ack #13 (Req-Sent) Mar 12 14:14:25 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:25 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:27 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:27 server mpd: [b1] IPCP: SendConfigReq #14 Mar 12 14:14:27 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:27 server mpd: [b1] IPCP: rec'd Configure Ack #14 (Req-Sent) Mar 12 14:14:27 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:27 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:29 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:29 server mpd: [b1] IPCP: SendConfigReq #15 Mar 12 14:14:29 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:29 server mpd: [b1] IPCP: rec'd Configure Ack #15 (Req-Sent) Mar 12 14:14:29 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:29 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:31 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:31 server mpd: [b1] IPCP: SendConfigReq #16 Mar 12 14:14:31 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:31 server mpd: [b1] IPCP: rec'd Configure Ack #16 (Req-Sent) Mar 12 14:14:31 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:31 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:33 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:33 server mpd: [b1] IPCP: SendConfigReq #17 Mar 12 14:14:33 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:33 server mpd: [b1] IPCP: rec'd Configure Ack #17 (Req-Sent) Mar 12 14:14:33 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:33 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd Mar 12 14:14:35 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent Mar 12 14:14:35 server mpd: [b1] IPCP: SendConfigReq #18 Mar 12 14:14:35 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:37 server mpd: [b1] IPCP: SendConfigReq #19 Mar 12 14:14:37 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:39 server mpd: [b1] IPCP: SendConfigReq #20 Mar 12 14:14:39 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:41 server mpd: [b1] IPCP: SendConfigReq #21 Mar 12 14:14:41 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:43 server mpd: [b1] IPCP: SendConfigReq #22 Mar 12 14:14:43 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:45 server mpd: [b1] IPCP: SendConfigReq #23 Mar 12 14:14:45 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:47 server mpd: [b1] IPCP: SendConfigReq #24 Mar 12 14:14:47 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:49 server mpd: [b1] IPCP: SendConfigReq #25 Mar 12 14:14:49 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:51 server mpd: [b1] IPCP: SendConfigReq #26 Mar 12 14:14:51 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:53 server mpd: [b1] IPCP: SendConfigReq #27 Mar 12 14:14:53 server mpd: [b1] IPADDR 188.239.193.21 Mar 12 14:14:55 server mpd: [b1] IPCP: parameter negotiation failed Mar 12 14:14:55 server mpd: [b1] IPCP: state change Req-Sent --> Stopped Mar 12 14:14:55 server mpd: [b1] IPCP: LayerFinish Mar 12 14:14:55 server mpd: [b1] Bundle: No NCPs left. Closing links... Mar 12 14:14:55 server mpd: [b1] Bundle: closing link "L1"... Mar 12 14:14:55 server mpd: [L1] Link: CLOSE event Mar 12 14:14:55 server mpd: [L1] LCP: Close event Mar 12 14:14:55 server mpd: [L1] LCP: state change Opened --> Closing Mar 12 14:14:55 server mpd: [L1] Link: Leave bundle "B1" Mar 12 14:14:55 server mpd: [b1] Bundle: Status update: up 0 links, total bandwidth 9600 bps Mar 12 14:14:55 server mpd: [b1] IPCP: Close event Mar 12 14:14:55 server mpd: [b1] IPCP: state change Stopped --> Closed Mar 12 14:14:55 server mpd: [b1] IPCP: Down event Mar 12 14:14:55 server mpd: [b1] IPCP: state change Closed --> Initial Mar 12 14:14:55 server mpd: [L1] LCP: SendTerminateReq #3 Mar 12 14:14:55 server mpd: [L1] LCP: LayerDown Mar 12 14:14:57 server mpd: [L1] LCP: SendTerminateReq #4 Mar 12 14:14:59 server mpd: [L1] LCP: state change Closing --> Closed Mar 12 14:14:59 server mpd: [L1] LCP: LayerFinish Mar 12 14:14:59 server mpd: [L1] Link: DOWN event Mar 12 14:14:59 server mpd: [L1] LCP: Down event Mar 12 14:14:59 server mpd: [L1] LCP: state change Closed --> Initial Ссылка на сообщение Поделиться на других сайтах
cobalt 1 Опубліковано: 2012-11-08 11:16:53 Share Опубліковано: 2012-11-08 11:16:53 Всем доброго дня! Топикстартеру, а что в итоге-то? Как решилась проблема? или не решилась? Ссылка на сообщение Поделиться на других сайтах
