vavilonua 4 Опубликовано: 2012-03-12 07:49:14 Share Опубликовано: 2012-03-12 07:49:14 Здраствуйте, подскажите в какую сторону копать есть каталист 6500 его конфиг : ip vrf local_vrf rd 1:1 ! ip multicast-routing ip multicast-routing vrf local_vrf ... vlan 309 name iptv_21210 ! vlan 310 name iptv_Ch13a ! ... ip access-list standard sky_iptv permit 239.255.1.0 0.0.0.255 permit 239.255.2.0 0.0.0.255 deny any ! ... interface GigabitEthernet3/16 description servernaya2 switchport switchport trunk encapsulation dot1q switchport trunk native vlan 61 switchport trunk allowed vlan 50,61,310,554-556,560 switchport mode trunk end ... interface GigabitEthernet2/10 description servernaya3 switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 1,3,31,58,180,309,555 switchport mode trunk access-group mode prefer port end ... interface Vlan310 description Link_toMR2 ip vrf forwarding local_vrf ip address 192.168.11.1 255.255.255.0 no ip redirects no ip unreachables ip pim sparse-mode end interface Vlan309 description source mcast ip vrf forwarding local_vrf ip address 192.168.10.4 255.255.255.0 ip pim sparse-mode ip sap listen end ip pim vrf local_vrf rp-address 192.168.10.4 sky_iptv override в него включены клиентские свичи 2950 на них настроен MVR, все работает также в него в порт Gi3/16 включен раенный свич Catalyst 3550, его конфиг: ip multicast-routing ... vlan 310 name Link_to_MR1 ! vlan 315 name house_iptv ! ... interface GigabitEthernet0/8 description house switchport trunk encapsulation dot1q switchport mode trunk switchport protected ! interface GigabitEthernet0/10 description Uplink switchport trunk encapsulation dot1q switchport mode trunk ip dhcp relay information trusted ip dhcp snooping trust ! ... interface Vlan310 description link_to_MR2 ip address 192.168.11.2 255.255.255.0 ip pim sparse-mode ! interface Vlan315 description house iptv_vlan ip address 192.168.16.1 255.255.255.0 ip pim sparse-mode ! ... ip route 192.168.10.0 255.255.255.0 192.168.11.1 ip pim rp-address 192.168.10.4 sky_iptv override ... ip access-list standard sky_iptv permit 239.255.1.0 0.0.0.255 permit 239.255.2.0 0.0.0.255 ! #sh ip pim neighbor PIM Neighbor Table Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority, P - Proxy Capable, S - State Refresh Capable Neighbor Interface Uptime/Expires Ver DR Address Prio/Mode 192.168.11.1 Vlan310 01:14:13/00:01:17 v2 1 / S P Simonenko# ну а за етим маршрутизатором все както мутно работает, причем когда тестили то у чаловека через 5-10 мин только звук появился и на домовой циске вяло от него идут запросы. Как можно продиагностировать в чем трабла? еще вопрос в следующем, второй PIM должен маршруты сразу строить к источнику или по запросу igmp с дома? MR2 #sh ip mroute IP Multicast Routing Table Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected, L - Local, P - Pruned, R - RP-bit set, F - Register flag, T - SPT-bit set, J - Join SPT, M - MSDP created entry, X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement, U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel, z - MDT-data group sender, Y - Joined MDT-data group, y - Sending to MDT-data group V - RD & Vector, v - Vector Outgoing interface flags: H - Hardware switched, A - Assert winner Timers: Uptime/Expires Interface state: Interface, Next-Hop or VCD, State/Mode (*, 239.255.255.100), 22:24:17/00:02:42, RP 0.0.0.0, flags: SJC Incoming interface: Null, RPF nbr 0.0.0.0 Outgoing interface list: Vlan315, Forward/Sparse, 22:24:17/00:02:42 (*, 224.0.1.40), 1w0d/00:02:54, RP 0.0.0.0, flags: DCL Incoming interface: Null, RPF nbr 0.0.0.0 Outgoing interface list: Vlan310, Forward/Sparse, 1w0d/00:02:54 на MR1 #sh ip mroute vrf local_vrf IP Multicast Routing Table Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected, L - Local, P - Pruned, R - RP-bit set, F - Register flag, T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet, X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement, U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel, z - MDT-data group sender, Y - Joined MDT-data group, y - Sending to MDT-data group V - RD & Vector, v - Vector Outgoing interface flags: H - Hardware switched, A - Assert winner Timers: Uptime/Expires Interface state: Interface, Next-Hop or VCD, State/Mode (*, 239.255.1.17), 6d16h/stopped, RP 192.168.10.4, flags: SJC Incoming interface: Null, RPF nbr 0.0.0.0 Outgoing interface list: Vlan309, Forward/Sparse, 6d16h/00:02:22 (192.168.10.2, 239.255.1.17), 6d16h/00:02:57, flags: PT Incoming interface: Vlan309, RPF nbr 0.0.0.0, RPF-MFD Outgoing interface list: Null (*, 239.255.1.16), 6d16h/stopped, RP 192.168.10.4, flags: SJC Incoming interface: Null, RPF nbr 0.0.0.0 Outgoing interface list: Vlan309, Forward/Sparse, 6d16h/00:02:28 (192.168.10.2, 239.255.1.16), 6d16h/00:02:57, flags: PT Incoming interface: Vlan309, RPF nbr 0.0.0.0, RPF-MFD Outgoing interface list: Null Ссылка на сообщение Поделиться на других сайтах
