Продам LSI 9260-8i
Продам LSI MegaRAID SAS 9260-8i в исполнении IBM ServeRAID M5014.
Таблица с описанием:
Solution Provided Eight-port internal SATA+SAS solution for high-density servers and workstations using up to 128 devices with the flexibility to use both SATA and SAS hard drives and solid state
drives (SSDs). Physical Dimensions MD2 Low profile (6.6" X 2.536") Connectors Two Mini-SAS SFF-8087 internal connectors Device Support Up to 128 SATA and/or SAS devices Host Bus Type x8 lane PCI Express 2.0 Compliant Data Transfer Rates Up to 6Gb/s per port I/O Processor/SAS Controller LSISAS2108 RAID-on-Chip (ROC) Cache Memory 512MB 800MHz DDR II SDRAM Battery Backup Unit LSIiBBU07 or LSIiBBU08, an intelligent battery backup module option that directly or remotely connects to the controller Key RAID Data Protection Features
  • RAID levels 0, 1, 5 and 6
  • RAID spans 10, 50 and 60
  • Online Capacity Expansion (OCE)
  • Online RAID Level Migration (RLM)
  • Auto resume after loss of system power during array
    rebuild or reconstruction (RLM)
  • Single controller Multipathing
  • I/O Load Balancing
  • Configurable stripe size up to 1MB
  • Fast initialization for quick array setup
  • Check Consistency for background data integrity
  • SSD Support with SSD Guard™
  • Patrol read for media scanning and repairing
  • 64 logical drive support
  • Up to 64TB LUN support
  • DDF compliant Configuration on Disk (COD)
  • S.M.A.R.T support
  • Global and dedicated Hot Spare with Revertible Hot Spare support
    – Automatic rebuild
    – Enclosure affinity
    – Emergency SATA hot spare for SAS arrays
  • Enclosure management
    – SES (inband)
    – SGPIO (sideband)
Operating Temperature Maximum ambient: 60°C (44.5°C w/iBBU) Operating Voltage +3.3V Warranty 3 years, free advanced technical support, advanced replacement option Regulatory Certifications EN55022, EN55024, EN60950, EN 61000-3-2, EN 61000-3-3; FCC Class A, Class B; UL1950; UL; CSA C22.2; VCCI; RRL for MIC; BSMI;C-tick RAID Management MegaRAID Management Suite
  • MegaRAID Storage Manager™
  • MegaCLI (command-line interface)
  • WebBIOS
OS Support Extensive support includes Microsoft® Windows® Vista/Server 2008R2/2008/2003/2000/XP,
Linux® and more. Visit the LSI download Center for the most complete list of
supported operating systems: lsi.com/support. MTBF 1,093,393 Hours
В комплекте: контроллер, 2U планка, диск с драйверами.
$450.
Продано. Удалите, плиз.
    • By hardware_all
      довжина 0.5 м
      2700грн
      посилання на спек
    • By Viper999
      Продам SAS/Sata контролери RAID масивів LSI 9361-8i, в наявності є кілька штук. Повністю справні.
      3000грн/шт
    • By a_n_h
          Вопрос к гуру форума, есть ли возможность как-то увидеть/посмотреть smart SAS диска  установленного в raid-контроллер?
    • By OstapenkoAlexey
      Итак, собственно начнем, лоты:
      1)
      LSI L3-25121-86b SAS MegaRAID Pci-e 2.0 X8 RAID Controller с райзером супермикро под 90 градусов
      ценник - 600 грн
      2)
      1u supermicro cpu kit (2 шт)
      TW-0T4MPW-41360-029-1771-A00
      DP/N: 0T4MPW
      ценник за 2 шт - 200 грн
      3 )
      d-link des-1005d + блок питания
      старый надежный неуправляемый коммутатор полностью рабочий, в свое время поменял на тп-линк дома
      ценник за свич и бп - 75 грн
      4)
      Контроллер RAID Dell PERC H310 6Gb/s 0HV52W + провод SAS - Sata+питание
      Рабочий, снят с работающего сервера в свое время по причине замены на 700 серию перка.
      ценник за контроллер и кабель - 500 грн
      5)
      2 блока питания для устройств уровня свич выше
      hitron hes18-120125-3, dc output 12V 1,25A
      panasonic pqlvz19ce, dc output 6,5V 0,8A
      6)
      оперативная память для ноутбука ддр2
      1GB 2Rx16 PC2-5300S-555-12 hynix x2
      ценник за 2 шт - 100 грн
      Локация - возле Берегово Закарпатье, отправка НП только либо приезжайте
      Кто возьмёт всё скопом, сам запакую идеально, дам скидку 20% на всё и за мой счет доставка.
      Фото всего добра [url=https://drive.google.com/drive/folders/1-16Rl4jipk4-8hbwqimuQmsIYsUrgcZV?usp=sharing]здесь[/url]
    • By alpaer
      Вітаю!
      Треба HP 460499-001 /  462976-001 Raid Controller Battery  - як на фото.
      Інше не пропонувати.
      Кількість = 3шт
      Пропонуйте в особистий кабінет.
      Дякую.
