Кобринюк Юрій 0 Опубликовано: 2012-05-08 18:02:35 Share Опубликовано: 2012-05-08 18:02:35 Здравствуйте, запущен Ubilling 0.2.6 rev 1423 на убунте, насом стоит микротик , все нормально работает, но возникла проблема с подсчетом трафика с наса на билинг. Создано правило для отправки статистики на микротике, сервиса вроде так же все работают ps aux | grep stargazer root 27645 0.7 0.8 676428 8540 ? Ssl May07 18:10 stargazer ps aux | grep bandwidthd root 5244 0.0 0.0 0 0 pts/8 ZN 10:33 0:00 [bandwidthd] <defunct> root 12085 0.0 0.0 0 0 pts/8 ZN 20:33 0:00 [bandwidthd] <defunct> root 12159 0.2 0.0 0 0 pts/8 ZN 20:53 0:00 [bandwidthd] <defunct> root 12167 10.3 1.6 66856 16396 pts/8 SN 20:57 0:00 /usr/sbin/bandwidthd root 31935 0.1 1.0 56296 10128 pts/8 SN May07 3:12 /usr/sbin/bandwidthd root 31936 0.1 0.7 52060 8072 pts/8 SN May07 3:11 /usr/sbin/bandwidthd root 31937 0.1 0.6 50504 6760 pts/8 SN May07 3:11 /usr/sbin/bandwidthd root 31938 0.1 0.2 49516 2304 pts/8 SN May07 3:34 /usr/sbin/bandwidthd ps aux | grep softflowd nobody 9679 0.5 0.2 17532 2444 ? Ss 17:18 1:08 /usr/sbin/softflowd -i eth2 -n 127.0.0.1:42111 трафик слушается на eth2. Вопросы начались с аномальных ошибок на softflowd softflowctl statistics softflowd[9679]: Accumulated statistics since 2012-05-08T14:18:45 UTC: Number of active flows: 857 Packets processed: 934908 Fragments: 0 Ignored packets: 933907 (933907 non-IP, 0 too short) Flows expired: 31479 (0 forced) Flows exported: 48852 in 1764 packets (0 failures) Packets received by libpcap: 1868837 Packets dropped by libpcap: 0 Packets dropped by interface: 0 Expired flow statistics: minimum average maximum Flow bytes: 46 1322 18929872 Flow packets: 1 8 74521 Duration: 0.00s 28.31s 11684.96s Expired flow reasons: tcp = 18 tcp.rst = 14482 tcp.fin = 375 udp = 16359 icmp = 124 general = 121 maxlife = 0 over 2 GiB = 0 maxflows = 0 flushed = 0 Per-protocol statistics: Octets Packets Avg Life Max Life Unknown (1): 2706153 29419 1758.61s 11684.96s Unknown (2): 27502 597 201.99s 4931.22s Unknown (6): 29370267 123157 1.21s 2815.41s Unknown (17): 9508904 94709 38.57s 11653.56s Unknown (139): 72 1 0.00s 0.00s а именно - Ignored packets: 933907 (933907 non-IP, 0 too short) , но даже с учтением того что без них есть н-ое количество принятых трафик не считает. Подскажите что не так делаю, и как промонитерить или отдебажить отправку статы. Спасибо. Ссылка на сообщение Поделиться на других сайтах
nightfly 1 266 Опубліковано: 2012-05-08 18:13:05 Share Опубліковано: 2012-05-08 18:13:05 Как-то не вкурил концепт. Позвольте спросить - вы трафик пользователей таки на биллинговом хосте считаете или самом микротике как в оригинальном мануале нарисовано? Ссылка на сообщение Поделиться на других сайтах
Кобринюк Юрій 0 Опубліковано: 2012-05-08 19:58:21 Автор Share Опубліковано: 2012-05-08 19:58:21 Оказалось проблема в том что не отделил мух от супа, установил softflowd который висел на том же порте откуда поступала инфа с микротика. Спасибо разработчику обяснил что куда. Но интерестно другое, теперь считает только исходящий трафик... Ссылка на сообщение Поделиться на других сайтах
nightfly 1 266 Опубліковано: 2012-05-09 07:57:46 Share Опубліковано: 2012-05-09 07:57:46 Думаю одно из двух: 1. В тарифе выставлен подсчет трафика только по "up" 2. Подсчет трафика производиться где-то на интерфейсе на котором уже работает NAT, отсюда тоже могут расти ногами артефакты когда исходящий трафик еще "абонентский" а на входе уже принадлежит натящему интерфейсу. Посмотрите точно ли сенсор нетфлоу микротика, натравлен на интерфейс смотрящий в сторону пользователей. Ссылка на сообщение Поделиться на других сайтах
Кобринюк Юрій 0 Опубліковано: 2012-05-09 13:25:21 Автор Share Опубліковано: 2012-05-09 13:25:21 Методом тыка установлено что ( возможно только в моем случае , но скорее это микротик так считает ) нужно слушать оба интерфейса внешку и локаль, тогда все ок. Ссылка на сообщение Поделиться на других сайтах
SVD 6 Опубліковано: 2013-04-07 19:03:58 Share Опубліковано: 2013-04-07 19:03:58 А при cap_nf для подсчета трафика с микротика как то можно использовать bandwidthd. трафик считает. а вот за день или за неделю не выводиться. как то можно прикрутить. Ссылка на сообщение Поделиться на других сайтах
