Продам Cisco WS-C3750-48TS-S
Продам Cisco Catalyst WS-C3750-48TS-S с ушами в отличном состоянии (ничего не отломано, не помято, не потрескано), все порты рабочие, удален конфиг.
Цена $500.
Реальные фото:
post-4093-0-24012800-1364840719_thumb.jpgpost-4093-0-62866600-1364840735_thumb.jpgpost-4093-0-37297100-1364840750_thumb.jpgpost-4093-0-20396500-1364840765_thumb.jpg
Консоль:
*Mar  1 00:05:58.168: %SYS-5-RELOAD: Reload requested by console. Reload reason:
 Reload command
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:17:5a:23:1d:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 419 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 13903360
flashfs[0]: Bytes available: 2095616
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
done.
Loading "flash:c3750-ipbasek9-mz.122-52.SE/c3750-ipbasek9-mz.122-52.SE.bin"...@@
File "flash:c3750-ipbasek9-mz.122-52.SE/c3750-ipbasek9-mz.122-52.SE.bin" uncompr
essed and installed, entry point: 0x1000000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(52)SE, RELEA
SE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:32 by sasyamal
Image text-base: 0x01000000, data-base: 0x02B00000
Initializing flashfs...
flashfs[1]: 419 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 13903360
flashfs[1]: Bytes available: 2095616
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 1
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3750-48TS (PowerPC405) processor (revision M0) with 131072K bytes of m
emory.
Processor board ID CAT1010R0UD
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:17:5A:23:1D:80
Motherboard assembly number     : 73-9680-09
Power supply part number        : 341-0028-02
Motherboard serial number       : CAT10090FXP
Power supply serial number      : LIT100705PX
Model revision number           : M0
Motherboard revision number     : A0
Model number                    : WS-C3750-48TS-S
System serial number            : CAT1010R0UD
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT100601KW
Top Assembly Part Number        : 800-25854-02
Top Assembly Revision Number    : C0
Version ID                      : V05
CLEI Code Number                : CNMV300CRE
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750-48TS      12.2(52)SE            C3750-IPBASEK9-M
%Error opening tftp://255.255.255.255/network-confg (Timed out)
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
%Error opening tftp://255.255.255.255/switch-confg (Timed out)
%Error opening tftp://255.255.255.255/ciscortr.cfg (Timed out)
Press RETURN to get started!
*Mar  1 00:00:31.792: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the s
tack
*Mar  1 00:00:33.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to down
*Mar  1 00:00:34.745: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for typ
e vlan
*Mar  1 00:00:38.453: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:38.663: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:00:38.663: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has c
hanged to state DOWN
*Mar  1 00:00:38.663: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has c
*Mar  1 00:00:40.005: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:00:41.875: %LINK-3-UPDOWN: Interface FastEthernet1/0/48, changed stat
e to up
*Mar  1 00:00:42.882: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et1/0/48, changed state to up
*Mar  1 00:01:17.418: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/network-confg) failed
*Mar  1 00:01:55.452: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/cisconet.cfg) failed
*Mar  1 00:02:33.469: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/switch-confg) failed
*Mar  1 00:03:03.475: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
*Mar  1 00:03:11.486: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/ciscortr.cfg) failed
*Mar  1 00:03:11.486: %SYS-5-RESTART: System restarted --
SE SOFTWARE (fc3)
*Mar  1 00:03:11.503: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:03:27.576: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to up
Switch>
*Mar  1 00:03:37.508: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
Switch>
    • Від Oleh B
      DS-C9396T-48EK9|96x32GFC SFP28 (48xAP)
      Маємо на складі 2 штуки. Нові. Надаємо гарантію
      Хочемо 15 000 еро))) Але можемо поговорити)))
    • Від defence_k
      Продам Маршрутизатор Cisco ISR C1121-8PLTEP 7000
    • Від ilja
      Илья, 28 лет, родом с Украины. Ищу своих в Польше (Краков/Познань/Варшава). Имею актуальные сертификации Cisco CCNA, ищу работу Сетевым Админом. Открыт к сотрудничеству, почта: gricanillya@gmail.com
      Cisco Certified Cybersecurity Associate certificate.pdf Cisco Certified Network Associate certificate.pdf
    • Від mch412
      Вітаю товариство!
      Маємо проблему не піднімається DMVPN для всіх Абонентів підключених до PON OLT ZTE C300 v1.2.5p3.
      Головне пакети 1520 з тестового ноута через ПОН пролазать без проблем, а DMVPN не піднімається.
    • Від rusol
      ПРОДАМ Cisco 7206VXR/NPE-G1
      Комплект:
      шассі
      npe/g1
      блок живлення
      блок живлення
      $500
