Продам свичи Planet GsD-802S б/у
Характеристики:
Количество слотов для доп интерфейсов - 2
Консольный порт
Веб-интерфейс
Поддержка SNMP
Базовые порты: 8 портов 10/100/1000 Мб/с
Пропускная способность 16 Гбит/с
Размер таблицы МАС-адресов: 8192
Свичи б/у, но в отличном качестве. Сняты с использования по причине тотального перехода на оптику.
Ориентировочная цена - 500грн/шт
    • Від avdept
      Продам свіч, 24 порти, ПОЕ до 400вт комбіновано. Все працює, екран, віддалений доступ. Хочу 18000грн
    • Від Alina1989
      Hey, fellows, our S6865-56YC switch is a high-performance and high-density uplink switch with 25Gigabit Downlink & 100Gigabit Uplink, which is designed and developed by our company independently. The whole switch adopts advanced hardware structure design and pluggable power redundancy design.
      It can support a maximum of 48 *25Gigabit ports, 8*100G uplink ports, provide full port L2/L3 line speed forwarding capability, and support IPV6. This device provides rich service features and powerful functions, such as ACL policies, flexible Q-in-Q, and network security protection.
      Meanwhile, the product has the highest 10 Gigabit port density and the largest switching capacity of the same grade equipment in the industry, and supports full-port line speed forwarding. The elastic stack function virtualizes multiple devices into a logical entity, which can expand port and switching capacity, manage, upgrade, and maintain multiple devices in a unified manner.
      To meet the requirements of large data traffic and non-blocking transmission in data centers, the product provides powerful cache capabilities and supports advanced cache scheduling mechanisms to ensure the maximum effective utilization of the device's cache capabilities. It is designed to meet the requirements of high-density and high-bandwidth network applications in next-generation enterprise networks, data centers and metropolitan area networks.
      It can be applied to the Ethernet aggregation layer or access layer of network operators or campuses, as well as the access layer of data centers and the core layer of small and medium-sized enterprises, and provides rich server access solutions for data centers.
        S6865-56YC (1+1 modular redundant power supply)
      More details, contact me directly!
      Whatsapp/ Viber/ Wehcat : +86 18086327779
      Skype: alinaquan14@hotmail.com
    • Від Diter_ua
      Продам управляемый коммутатор.
      4 сфп порт
      24 медных гигабитных
      без пароля.
      Хотелка 2500 грн. Торг
    • Від scaran
      Приветствую еще раз. Кто может поделится прошивкой 15.3.1.4 или ниже для summit x250e.  На свитче стоит 12.5.4.5, при попытке зашить 15.3.5.2 patch 1-19 ругается, что нужна промежуточная. А какая именно промежуточная инфы не нашел.
    • Від apels1n
      Всім привіт, на днях знадобився шаблон під zxr10 2928e, на просторах інтернету не знайшов, тому вирішив поділитися самостійно зробленим. Може комусь буде потрібно. Підходить до 6 заббіксу, на інших не тестував.
      zbx_export_templates.xml
