Реальні ІР , dhcp сервер?
Від stepnet
Я новачок, так що відразу палками не бийте, ткніть носом в правильне місце
Все працює на одному сервері FreeBSD Ubilling 1.3.8 rev 8894
Читав
та
мої налаштування
rc.conf
hostname="miso"
ifconfig_vmx0="inet 172.16.0.1/24" - мережа абонів
ifconfig_vmx1="inet 62.80.138.131/29" - вихід в світ (іп видумана)
ifconfig_vmx2="inet 192.168.11.3/24 -arp" - мережа адміна
defaultrouter="62.80.138.129"
sshd_enable="YES"
gateway_enable="YES"
firewall.conf
#!/bin/sh
# firewall command
FwCMD="/sbin/ipfw -q"
${FwCMD} -f flush
# Interfaces setup
LAN_IF="vmx0"
WAN_IF="vmx1"
WANFG_IF="vmx2"
# Networks defines
# Users
${FwCMD} table 2 add 172.16.150.0/24
${FwCMD} table 10 add 62.80.138.134/32
#${FwCMD} add 65531 deny all from table\(10\) to any via vmx0
#${FwCMD} add 65532 deny all from any to table\(10\) via vmx0
# Safe zones
${FwCMD} table 22 add 127.0.0.1
# Safe zones allow policy
${FwCMD} add 45 allow ip from table\(22\) to me
${FwCMD} add 45 allow ip from me to table\(22\)
# ssh access.
#${FwCMD} add 46 deny ip from any to me dst-port 22
#${FwCMD} add 46 deny ip from me to any src-port 22
# mysql access
${FwCMD} add 47 deny ip from any to me dst-port 3306
${FwCMD} add 47 deny ip from me to any src-port 3306
# sgconf access
${FwCMD} add 48 deny ip from any to me dst-port 5555
${FwCMD} add 48 deny ip from me to any src-port 5555
# NAT
${FwCMD} nat 1 config log if ${WAN_IF} reset same_ports
${FwCMD} add 6000 nat 1 ip from table\(2\) to not table\(10\) out xmit ${WAN_IF}
${FwCMD} add 6001 nat 1 ip from any to me in recv ${WAN_IF}
# Pass traffic for the specific subscriber without NAT
${FwCMD} add 6010 allow ip from table\(10\) to any out xmit ${WAN_IF}
${FwCMD} add 6011 allow ip from any to table\(10\) in recv ${WAN_IF}
# Shaper - table 4 download speed, table 3 - upload speed
${FwCMD} add 12001 pipe tablearg ip from any to table\(4\) via ${LAN_IF} out
${FwCMD} add 12000 pipe tablearg ip from table\(3\) to any via ${LAN_IF} in
# default block policy
${FwCMD} add 65533 deny all from table\(2\) to any via ${LAN_IF}
${FwCMD} add 65534 deny all from any to table\(2\) via ${LAN_IF}
${FwCMD} add 65535 allow all from any to any
В вебці добавив мережу, налаштував dhcp, абонент отримує іп 62.80.138.134 з гейтом 62.80.138.129
Як абоненту налаштувати білу іп 62.80.138.134?
