Продам Cisco 3550-12T
Собственно, продам Cisco 3550-12T
Цена - 2500 грн
Отправлю Новой Поштой, Деливери, Интаймом, Автолюксом - на ваше усмотрение.
Оплата наложенным платежом либо на карту приватбанка.
Причина продажи - не хватало гигабитных портов. Коммутатор в отличном состоянии
Тел. 095 9181043 , либо в ЛС
Фото добавлю в следующем посте
#sh version [/size]
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)[/size]
Copyright © 1986-2008 by Cisco Systems, Inc.[/size]
Compiled Thu 21-Aug-08 16:13 by nachen[/size]
Image text-base: 0x00003000, data-base: 0x012B5D98[/size]
ROM: Bootstrap program is C3550 boot loader[/size]
core-c3550 uptime is 8 minutes[/size]
System returned to ROM by power-on[/size]
System image file is "flash:c3550-ipservicesk9-mz.[/size]122-46.SE.bin"[/size]
This product contains cryptographic features and is subject to United[/size]
States and local country laws governing import, export, transfer and[/size]
use. Delivery of Cisco cryptographic products does not imply[/size]
third-party authority to import, export, distribute or use encryption.[/size]
Importers, exporters, distributors and users are responsible for[/size]
compliance with U.S. and local country laws. By using this product you[/size]
agree to comply with applicable laws and regulations. If you are unable[/size]
to comply with U.S. and local laws, return this product immediately.[/size]
A summary of U.S. laws governing Cisco cryptographic products may be found at:[/size]
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to[/size]
export@cisco.com.[/size]
Cisco WS-C3550-12T (PowerPC) processor (revision M0) with 65526K/8192K bytes of memory.[/size]
Processor board ID FAA0538S08B[/size]
Last reset from warm-reset[/size]
Running Layer2/3 Switching Image[/size]
Ethernet-controller 1 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 2 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 7 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 8 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 9 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 10 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 11 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
Ethernet-controller 12 has 1 Gigabit Ethernet/IEEE 802.3 interface[/size]
12 Gigabit Ethernet interfaces[/size]
The password-recovery mechanism is enabled.[/size]
384K bytes of flash-simulated NVRAM.[/size]
Base ethernet MAC Address: 00:05:DD:C3:CF:00[/size]
Motherboard assembly number: 73-5527-15[/size]
Power supply part number: 34-0967-01[/size]
Motherboard serial number: FAA0538HDOL[/size]
Power supply serial number: DAB061407T6[/size]
Model revision number: M0[/size]
Motherboard revision number: A0[/size]
Model number: WS-C3550-12T[/size]
System serial number: FAA0538S08B[/size]
Configuration register is 0x10F[/size]
Если еще не нашли замену, то у меня есть WS-C3750G-24TS-S на 24 гигабитных порта + 4 независимых SFP.
См. в подписи.
    • By ilja
      Илья, 28 лет, родом с Украины. Ищу своих в Польше (Краков/Познань/Варшава). Имею актуальные сертификации Cisco CCNA, ищу работу Сетевым Админом. Открыт к сотрудничеству, почта: gricanillya@gmail.com
      Cisco Certified Cybersecurity Associate certificate.pdf Cisco Certified Network Associate certificate.pdf
    • By mch412
      Вітаю товариство!
      Маємо проблему не піднімається DMVPN для всіх Абонентів підключених до PON OLT ZTE C300 v1.2.5p3.
      Головне пакети 1520 з тестового ноута через ПОН пролазать без проблем, а DMVPN не піднімається.
    • By rusol
      ПРОДАМ Cisco 7206VXR/NPE-G1
      Комплект:
      шассі
      npe/g1
      блок живлення
      блок живлення
      $500
    • By Oleh B
      Ціна 8900 грн за 1 шт с 2 БЖ.
      Можемо зробити сервери
    • By xserver
      Software
      BIOS: version 07.69
      BIOS compile time: 04/07/2021
