smtp сервер для dude
Подскажите открытый smtp сервер для отправки месаг из dude.
Вы не поверите, но спамеров такое тоже дюже интересует.
Если оно умеет смтп авторизацию - то череж бесплатные типа жмыла с яндексом можно попробовать.
Requirements: blat + stunnel + dude server on windows machine + gmail account
1. Download and install stunnel
stunnel.conf
Quote:
socket = l:TCP_NODELAY=1
socket = r:TCP_NODELAY=1
debug = 7
output = stunnel.log
client = yes
[pop3s]
accept = 995
connect = pop.gmail.com:995
[ssmtp]
accept = 465
connect = smtp.gmail.com:465
Install stunnel as service:
Quote:
"C:\Program Files\stunnel\stunnel.exe" -install
or
Quote:
Start-->All Programms --> stunnel --> Service install
2. Download blat and unpack 3 file ..
Quote:
blat.dll
blat.exe
blat.lib
in
Quote:
c:\Program Files\Dude\blat
directory or other your Dude directory
3. In directory from p.2 create emailblat.cmd file with the following content
Quote:
set dir=c:\Program Files\Dude\blat
set smtpsender=gmailaccount@gmail.com
set smtpserver=127.0.0.1
set smtpport=465
set smtpuser=gmailaccount
set smtppwd=*********
set mailto=gmailaccount@gmail.com
"%dir%\blat.exe" -to %mailto% -f %smtpsender% -server %smtpserver% -port %smtpport% -u %smtpuser% -pw %smtppwd% -subject %1 -body %2
change in it smtpsendersmtpusersmtppwd
4. Create new Notification
Type:execute on server
Quote:
"c:\Program Files\Dude\blat\emailblat.cmd" "Service [Probe.Name] on [Device.Name] is now [service.Status]" "Service [Probe.Name] on [Device.Name] is now [service.Status] ([service.ProblemDescription])"
And test it.
5. Now you can use it.
It work for me !
http://forum.mikrotik.com/viewtopic.php?f=8&t=31779&start=0&hilit=gmail
