Продам Cisco ASA5505 SE Plus
в идеальном-шикарном састоянии. почти не использовался.
комплектация---девайс,блок питания,консольный кабель,диск,коробка.
цена вопроса всего то 2000грн
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 7.0(2)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 20 mins 36 secs
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0 : address is 0021.55e5.3d78, irq 11
1: Ext: Ethernet0/0 : address is 0021.55e5.3d70, irq 255
2: Ext: Ethernet0/1 : address is 0021.55e5.3d71, irq 255
3: Ext: Ethernet0/2 : address is 0021.55e5.3d72, irq 255
4: Ext: Ethernet0/3 : address is 0021.55e5.3d73, irq 255
5: Ext: Ethernet0/4 : address is 0021.55e5.3d74, irq 255
6: Ext: Ethernet0/5 : address is 0021.55e5.3d75, irq 255
7: Ext: Ethernet0/6 : address is 0021.55e5.3d76, irq 255
8: Ext: Ethernet0/7 : address is 0021.55e5.3d77, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
The Running Activation Key feature: 2 security contexts exceed the limit on the platform, reduced to 0 security contexts.
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 20, DMZ Unrestricted
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
SSL VPN Peers : 2
Total VPN Peers : 25
Dual ISPs : Enabled
VLAN Trunk Ports : 8
Shared License : Disabled
AnyConnect for Mobile : Enabled
AnyConnect for Cisco VPN Phone : Enabled
AnyConnect Essentials : Enabled
Advanced Endpoint Assessment : Enabled
UC Phone Proxy Sessions : 2
Total UC Proxy Sessions : 2
Botnet Traffic Filter : Enabled
This platform has an ASA 5505 Security Plus license.
$(KGrHqRHJC!FJoHbfBhbBSc-kI7d-w~~60_12.J
