Продам Cisco ASA 5510
Приветствую!
В связи со сменной вендора в сети, в продаже Cisco ASA 5510 Security Plus license
Установлена последняя стабильная версия софта, на текущий момент: 8.4.7
Лицензия максимальная:  Security Plus license. Вывод show version ниже.
В устройство установлены аналоги Китов:
Cisco MEM-CF-4GB=              1шт.
Cisco ASA5510-MEM-1GB=     2шт. (8.4.7 требует 1GB, 2 GB стоит с запасом для 9 версии, обещают к концу года стейбл версию. )
Устройство Made in Mexico
"Уши" для крепления в стойку в комплекте.
# show version
Cisco Adaptive Security Appliance Software Version 8.4(7)
Compiled on Fri 30-Aug-13 19:48 by builders
System image file is "disk0:/asa847-k8.bin"
Config file at boot was "startup-config"
everest up 47 mins 2 secs
Hardware:   ASA5510, 2048 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 4096MB
BIOS Flash AT49LW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.06
                             Number of accelerators: 1
 0: Ext: Ethernet0/0         : address is 0016.4687.****, irq 9
 1: Ext: Ethernet0/1         : address is 0016.4687.****, irq 9
 2: Ext: Ethernet0/2         : address is 0016.4687.****, irq 9
 3: Ext: Ethernet0/3         : address is 0016.4687.****, irq 9
 4: Ext: Management0/0       : address is 0016.4687.****, irq 11
 5: Int: Not used            : irq 11
 6: Int: Not used            : irq 5
The Running Activation Key feature: 10000 AnyConnect Premium sessions exceed the limit on the platform, reduced to 250 AnyConnect Premium sessions.
The Running Activation Key feature: 10000 UC Proxy sessions exceed the limit on the platform, reduced to 100 UC Proxy sessions.
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 100            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Enabled        perpetual
Security Contexts                 : 5              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 250            perpetual
AnyConnect Essentials             : 250            perpetual
Other VPN Peers                   : 250            perpetual
Total VPN Peers                   : 250            perpetual
Shared License                    : Enabled        perpetual
AnyConnect for Mobile             : Enabled        perpetual
AnyConnect for Cisco VPN Phone    : Enabled        perpetual
Advanced Endpoint Assessment      : Enabled        perpetual
UC Phone Proxy Sessions           : 100            perpetual
Total UC Proxy Sessions           : 100            perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
This platform has an ASA 5510 Security Plus license.
Serial Number: ******
Running Permanent Activation Key: *********
Configuration register is 0x10001
Версия асикса не урезанная 2 порта 1Gb/s
# show interface stats | i BW
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
  Hardware is i82546GB rev03, BW 100 Mbps, DLY 100 usec
  Hardware is i82557, BW 100 Mbps, DLY 100 usec
Описание для тех кто не знает что это
Межсетевой экран Cisco ASA 5510 обеспечивает усовершенствованную безопасность и сетевые службы для бизнеса и филиалов офисов, при этом являясь простым решением с эффективной стоимостью. Эти службы могут легко управляться при помощи встроенного приложения Cisco ASDM, тем самым облегчая установку и уменьшая стоимость операций по обеспечению высокой безопасности. Межсетевой экран Cisco ASA 5510 обеспечивает высокую производительность межсетевого экрана и служб VPN, имеет 5 встроенных интерфейсов 10/100 Fast Ethernet. Опционально доступны высокопроизводительная система предотвращения вторжений и служба блокирования сетевых червей при использовании AIP SSM, а также всеобъемлющая служба защиты от вредоносного программного обеспечения при использовании CSC SSM. Эта уникальная комбинация служб в одной платформе делает Cisco ASA 5510 идеальным решением для предпринимателей, требующих рентабельное решение с поддержкой DMZ и возможностью дальнейшего расширения.
При увеличении потребностей бизнеса предприниматели могут обновить лицензию до Security Plus, тем самым превратив 2 интерфейса межсетевого экрана Cisco ASA 5510 в интерфейсы Gigabit Ethernet и включив интеграцию в коммутируемую сеть при помощи поддержки виртуальных сетей. Это обновление лицензии поможет максимизировать эффективность бизнеса путем включения служб высокой доступности - активность/активность и активность/режим ожидания. Использование опциональной возможности контекстной безопасности межсетевого экрана Cisco ASA 5510 позволяет установить до 5 виртуальных межсетевых экранов для разобщенного контроля политик безопасности на высоком уровне. Эта виртуализация усиливает безопасность, упрощает общее управление и уменьшает стоимость обслуживания и одновременно позволяет централизованно управлять несколькими устройствами.
Предприниматели могут расширить возможности SSL и IPsec VPN для поддержки большего количества дистанционных работников, удаленных объектов и бизнес партнеров. Можно увеличить количество пользователей SSL VPN до 250 на каждом межсетевом экране Cisco ASA 5510 при помощи установки обновления лицензии SSL VPN; базовая платформа поддерживает до 250 пользователей IPsec VPN.
Возможности VPN и отказоустойчивость могут быть увеличены для полного использования интегрированного стекирования Cisco ASA 5510 и возможностей балансировки нагрузки (доступно с лицензией Security Plus). Межсетевой экран Cisco ASA 5510 поддерживает до 10 комплексов в стеке, обеспечивая поддержку 2500 пользователей SSL VPN или 2500 пользователей IPsec VPN одним кластером. Для обеспечения бесперебойной работы и планирования Cisco ASA 5510 также может использовать преимущества лицензий Cisco VPN FLEX, которые дают администратору возможность своевременно реагировать и планировать очереди дистанционных пользователей на период до 2 месяцев.
Живые фото:
Манибек 3 дня на потестить.
Цена с 12 000 грн. Торг.
    • Від Alex_Chu
      Вітаю панове. Може хто щось підкаже:
      1. Маємо від провайдера ОНУ TP-Link TL-EP110
      2. Далі Cisco ASA
      Налаштування зовнішньої ip адреси - DHCP (але на порт привязаний конкретний іР, чому так не знаю, вимога провайдера)
      Після відновлення живлення ціска не отримує ір. як що підключений  замість неї дешевий роутер або ноут то все ок, адресу отримує одразу.
      провайдер каже що час аренди адреси на його дхцп - 5 хв. але ціска все одно не отримає адресу поки рандомно ону і ціску не відправиш в перезагруз.
      Може хтось вже мав таку траблу? чекаю поради.
    • Від rusol
      ПРОДАМ Cisco 7206VXR/NPE-G1
      Комплект:
      шассі
      npe/g1
      блок живлення
      блок живлення
      $500
    • Від Oleh B
      Ціна 8900 грн за 1 шт с 2 БЖ.
      Можемо зробити сервери
    • Від xserver
      Software
      BIOS: version 07.69
      BIOS compile time: 04/07/2021
    • Від sys.and.networks
      Чистые. Не запароленные.
      Цена - 2499 грн/шт.
