Аукцион - Cisco WS-C3750-24TS-S
Продам Cisco WS-C3750-24TS-S
+ кабель стекирования
Полностью рабочая!
Стартовая цена 100 грн.
Шаг 50 грн.
Окончание 20/05 в 12:00
sh ver:
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:32 by sasyamal
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Switch uptime is 1 minute
System returned to ROM by power-on
System image file is "flash:/c3750-ipservicesk9-mz.122-52.SE/c3750-ipservicesk9-mz.122-52.SE.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3750-24TS (PowerPC405) processor (revision L0) with 131072K bytes of memory.
Processor board ID CAT1015Z2Z9
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:17:95:73:50:00
Motherboard assembly number     : 73-9677-10
Power supply part number        : 341-0034-01
Motherboard serial number       : CAT10150635
Power supply serial number      : PHI0945B0VY
Model revision number           : L0
Motherboard revision number     : A0
Model number                    : WS-C3750-24TS-S
System serial number            : CAT1015Z2Z9
Top Assembly Part Number        : 800-25857-02
Top Assembly Revision Number    : D0
Version ID                      : V05
CLEI Code Number                : CNMV100CRE
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    2 26    WS-C3750-24TS      12.2(52)SE            C3750-IPSERVICESK9-M
Configuration register is 0xF
sh run:
Building configuration...
Current configuration : 1460 bytes
version 12.2
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Switch
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
switch 2 provision ws-c3750-24ts
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree extend system-id
vlan internal allocation policy ascending
interface FastEthernet2/0/1
interface FastEthernet2/0/2
interface FastEthernet2/0/3
interface FastEthernet2/0/4
interface FastEthernet2/0/5
interface FastEthernet2/0/6
interface FastEthernet2/0/7
interface FastEthernet2/0/8
interface FastEthernet2/0/9
interface FastEthernet2/0/10
interface FastEthernet2/0/11
interface FastEthernet2/0/12
interface FastEthernet2/0/13
interface FastEthernet2/0/14
interface FastEthernet2/0/15
interface FastEthernet2/0/16
interface FastEthernet2/0/17
interface FastEthernet2/0/18
interface FastEthernet2/0/19
interface FastEthernet2/0/20
interface FastEthernet2/0/21
interface FastEthernet2/0/22
interface FastEthernet2/0/23
interface FastEthernet2/0/24
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface Vlan1
 no ip address
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 5 15
end
Куда отправлять?? :) Отправлено с моего GT-I9502 через Tapatalk
Если g106u5 до вечера не отзовется Cisco уедит к tamazian - если он не откажется :)
    • Автор: xserver
      Software
      BIOS: version 07.69
      BIOS compile time: 04/07/2021
    • Автор: sys.and.networks
      Чистые. Не запароленные.
      Цена - 2499 грн/шт.
    • Автор: Oleh B
      Для связи, можете писать сюда
    • Автор: demiduk
      В наявності:
    • Автор: kotqq
      Характеристики:
      Модель: Cisco Nexus 3548-X
      Кількість портів: 48 x 10GbE
      Затримка: < 250 нс
      Підтримка VXLAN: Так
      Управління:  CLI, SNMP, API
      Форм-фактор: 1U
      Енергоспоживання: ~250 Вт
      Розміри: 43.9 x 43.2 x 4.4 см
      Вага: 7.9 кг
