OLT + ONU + D'Link + Multicast
voxlv
Есть такая схема D'Link DES3612G => OLT BDCOM P3310B => ONU BDCOM 3022 => D'Link 1228 => абонент
Задача получить мультикаст у абонента (IPTV)
Конфиги железа:
BDCOM P3310B Software, Version 10.1.0B Build 21324
Copyright by Shanghai Baud Data Communication CO. LTD.
Compiled: 2014-10-9 11:8:33 by SYS_21324, Image text-base: 0x80008000
ROM: System Bootstrap, Version 0.3.3, Serial num:00313001147
System image file is "BD3314_10.1.0B.bin"
(RISC) processor with 131072K bytes of memory, 8192K bytes of flash
Base ethernet MAC Address: fc:fa:f7:c9:19:36
snmp info:
  product_ID:228   system_ID:1.3.6.1.4.1.3320.1.228.0
els-pon-kluch uptime is 0:04:30:26, The current time: 2014-11-21 11:39:53
#Uplink port
interface GigaEthernet0/4
 description L3-Port11
 switchport trunk vlan-allowed 1,51,186,196,4000
 switchport trunk vlan-untagged none
 switchport mode trunk
 switchport pvid 4000
#EPON port
interface EPON0/3
 switchport pvid 1111
#ONU за ней D'Link
interface EPON0/3:24
 onu-configuration
 epon sla upstream pir 1000000 cir 1000
 epon sla downstream pir 1000000 cir 1000
  epon onu port 1 ctc vlan mode trunk 1111 1,196,4000
  epon onu port 1 ctc mcst mc-vlan add 4000
!!onu-configuration-end
show ip mcst
                Global multicast configuration:
Globally enable                         : Enabled
Multicast Compatible                    : Disabled
Multicast mode                          : IGMP Snooping
Dlf-frames filtering                    : Enabled
Querier                                 : Disabled
Querier address                         : 10.10.191.254
Router age                              : 260 s
Response time                           : 15 s
volum                                   : 512
double-tag-mode                 : Disabled
double-tag outer vlan id        : 0
Router Port PVID VLANMAP=4000
Router Port List:
GigaEthernet0/4(static)(querier);
vlan 4000
 name IPTV
vlan 1,51,71,138,149,165,186,196,1111,4000-4002
ip mcst enable
ip mcst querier address 10.10.191.254
ip mcst mrouter interface GigaEthernet0/4
ip mcst mc-vlan 4000 range 239.1.1.1 - 239.1.1.254
Настройка D'Link
# VLAN
disable asymmetric_vlan
enable pvid auto_assign
config vlan default delete 1-28
config vlan default advertisement disable
config vlan default add tagged 25-28
create vlan vlan51 tag 51
config vlan vlan51 add tagged 25-28# SNOOP
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 56
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan vlan4000 4000
config igmp_snooping multicast_vlan vlan4000 state enable
config igmp_snooping multicast_vlan vlan4000 replace_source_ip 10.10.191.250
config igmp_snooping multicast_vlan vlan4000 add member_port 1-24
config igmp_snooping multicast_vlan vlan4000 add source_port 25-28
config igmp_snooping multicast_vlan_group vlan4000 add  239.1.1.1-239.1.1.254
config igmp_snooping vlan_name default state disable fast_leave enable
config igmp_snooping data_driven_learning vlan_name default aged_out disable
config igmp_snooping querier all query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping vlan_name vlan51 state disable fast_leave enable
config igmp_snooping data_driven_learning vlan_name vlan51 aged_out disable
config igmp_snooping vlan_name vlan196 state disable fast_leave enable
config igmp_snooping data_driven_learning vlan_name vlan196 aged_out disable
config igmp_snooping vlan_name vlan4000 fast_leave enable
config igmp_snooping data_driven_learning vlan_name vlan4000 aged_out disable
config igmp access_authentication ports 1-28 state disable
config cpu_filter l3_control_pkt 1-24 rip ospf vrrp pim dvmrp igmp_query  state enable
config cpu_filter l3_control_pkt 25-28 rip ospf vrrp pim dvmrp  state enable
create vlan vlan196 tag 196
config vlan vlan196 add tagged 25-28
config vlan vlan196 add untagged 1-24
disable qinq
disable gvrp
config qinq ports 1-28 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1-24 state disable ingress_checking enable acceptable_frame admit_all pvid 196
config gvrp 25-26 state enable ingress_checking enable acceptable_frame admit_all pvid 1
config gvrp 27-28 state disable ingress_checking enable acceptable_frame admit_all pvid 1
Интернет у абонента работает. На ONU за которыми просто абонент
Попробуйте в конфиге ОНУ изменить эти каманды
mode на transparent
и вообще уберите epon onu port 1 ctc mcst mc-vlan add 4000
При этом конфиге ОНУ просто будет пропускать все что на нее приходит в том виде в каком это на нее приходит.
странно я тоже пробовал, и на свитч за ОНУшкой пришли маки во всех вланах которые проходили через epon порт и все работало гуд, но это не про мультикаст это про уникаст. Но я думаю разница не принципиальная.
Но при данном конфиге на ОНУ еще надо вланы посоздавать, я думаю такой конфиг не прокатит.
Это как?
Это как соображение. Точно не уверен, но команда вроде epon onu vlan ...
Но я всеже настаиваю что порт ОНУ должен работать как transparent.
