Не получаеться установить stg 2.402
Не получаеться поставить новый stg
переустановил gcc, expat - вообще процесс встал
раньше при компиляции выдавало
Makeing stg_logger.lib
../Makefile.in:74: deps: No such file or directory
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c stg_logger.cpp
ar rc libstg_logger.a stg_logger.o
ranlib libstg_logger.a
cp stg_logger.h ../../include/
cp libstg_logger.a ../../lib/
Makeing crypto.lib
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c ag_md5.c
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c blowfish.cpp
ar rc libcrypto.a ag_md5.o blowfish.o
ranlib libcrypto.a
cp ag_md5.h blowfish.h ../../include/
cp libcrypto.a ../../lib/
Makeing common.lib
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c debug.c
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c stg_error.c
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c common.cpp
ar rc libstg_common.a debug.o stg_error.o common.o
ranlib libstg_common.a
и т.д.
а теперь только это
[root@ns stargazer]# ./build
Building STG 2.4 for Linux
In file included from stg_logger.cpp:5:
stg_logger.h:5:18: error: string: No such file or directory
stg_logger.h:29: error: expected ',' or '...' before '&' token
stg_logger.h:29: error: ISO C++ forbids declaration of 'string' with no type
stg_logger.h:35: error: 'string' does not name a type
stg_logger.cpp: In constructor 'STG_LOGGER::STG_LOGGER()':
stg_logger.cpp:19: error: 'fileName' was not declared in this scope
stg_logger.cpp: At global scope:
stg_logger.cpp:28: error: expected ',' or '...' before '&' token
stg_logger.cpp:28: error: ISO C++ forbids declaration of 'string' with no type
stg_logger.cpp: In member function 'void STG_LOGGER::SetLogFileName(int)':
stg_logger.cpp:31: error: 'fileName' was not declared in this scope
stg_logger.cpp:31: error: 'fn' was not declared in this scope
stg_logger.cpp: In member function 'void STG_LOGGER::operator()(const char*, ...)':
stg_logger.cpp:46: error: 'fileName' was not declared in this scope
gmake: *** [stg_logger.o] Ошибка 1
в чем трабла ?
За ранее спасибо
подскажите где лежат файлы под Линукс скомпиленные
по ссылке http://shareua.com/files/5e410f/stg_2.402.tar.bz2.html- ничего нет
При старте система показывает вот это :
Linux version 2.6.9-1.667asp (build@pylesos.asp-linux.com.ua) (gcc version 3.3.3 20040412 (ASPLinux 3.3.3-7)) #1 Fri Nov
но дело в том что я устанавливал gcc и если смотреть установленные пакеты то пишет вот это :
gamin-devel-0.0.15-1.i386.rpm
gawk-3.1.3-7asp.i386.rpm
gcc-4.0.2-8.fc4.i386.rpm
gcc-c++-4.0.2-8.fc4.i386.rpm
gcc-gfortran-4.0.2-8.fc4.i386.rpm
gcc-gnat-3.3.3-7asp.i386.rpm
gcc-java-4.0.2-8.fc4.i386.rpm
gcc-objc-4.0.2-8.fc4.i386.rpm
GConf-1.0.9-13.1.i386.rpm
GConf2-2.8.1-1.i386.rpm
GConf2-devel-2.8.1-1.i386.rpm
GConf-devel-1.0.9-13.1.i386.rpm
gd-2.0.28-1.30.1.i386.rpm
gda-mysql-1.0.4-2.i386.rpm
Файлы конфигов, админов и пользователей находятся в /<каталог с сорцами>/projects/stargazer/inst/linux
Куда их копировать можно подсмотреть в скрипте install.
