Продам ONU P1501C1
    • Від ThinkMaster
      Куплю ONU BDCOM P1501C1 або P1504C1. Нові чи б/у, ціна не вище 600 грн. Пропонуйте тут або ЛС.
      P.S. Ця тема задублювалась, прошу видалити модераторів.
    • Від kibalchish
      Продам ONU BDCOM P1501C1
      нові, не розпаковані
      600 грн
      в наявності 2 шт
      відправлю наложкою
    • Від loschikatilos
      При этом наблюдается shutdown аплинк порта:
      Apr 26 13:33:56 10.0.19.42  000342: sw1.prm45 %Apr 26 14:33:54 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to DOWN
      Apr 26 13:34:13 10.0.19.42  000343: sw1.prm45 %Apr 26 14:34:12 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to UP Apr 26 13:39:08 10.0.19.42  000349: sw1.prm45 %Apr 26 14:39:07 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to DOWN Apr 26 13:39:25 10.0.19.42  000350: sw1.prm45 %Apr 26 14:39:25 2016 MODULE_PORT[tphyDaemon]:%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/4, changed state to UP   И возможно (визуально не подтверждаю) ребут OLT:   Apr 26 14:29:40 olt1.prm45 %EPON-ONUREG: ONU 8479.7323.0437 is registered on EPON0/1:9.  Jan  1 00:00:40 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error  Apr 26 14:31:22 olt1.prm45 %EPON-ONUREG: ONU 8479.7323.0437 is registered on EPON0/1:9.  Jan  1 00:00:40 olt1.prm45 %OLT: Interface EPON0/1:9's CTC OAM extension negotiated successfully!  Apr 26 14:32:59 olt1.prm45 %OLT: Interface EPON0/1:9's OAM Operational Status: Operational  Jan  1 00:00:38 olt1.prm45 %239.0.10.1 add error, insufficient multicast VLAN xlate table space.  Apr 26 14:34:36 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error  Apr 26 14:38:11 olt1.prm45 %ONU-VLAN-CFGERR: onu_ctc_uni_vlan_set get LLID port DB error  Jan  1 00:00:41 olt1.prm45 %EPON-ONUAUTHEN: ONU 8479.7323.0375 is authenticated on EPON0/1:8.  Apr 26 14:39:52 olt1.prm45 User motivprm logged in from 192.168.156.100 on vty 1
      Подозреваю, так как сбивается дата.
      Так же криво накатываются шаблоны:
      interface EPON0/2:3
      epon onu port 1 ctc vlan mode tag 1600
      epon onu port 1 loopback detect
      interface EPON0/2:4
      description morsk_63
      Основной конфиг во вл.
      sw 33463
      ONU исключительно P1501C1 и P1004C1
          conf.txt
    • Від InterStar
      Продам ONU BDCOM P1501C1 новые 2 шт
      850 грн за 1 шт
    • Від temamjk
      У абонента установлено оборудование BDCOM P1501C1,
      абонент звонит и говорит, что Интернета нет,
      в Zabbix пишет проблема, захожу на голову BDCOM P3310B
      MAC-адрес на интерфейсе ONU присутствует,
      но на вышестоящий коммутатор MAC-адрес не приходит,
      IP-адрес ONU не пингуется, IP-адрес абонента не пингуется.
      По словам абонента все лампочки горят зеленые.
      Через несколько минут всё пингуется,
      Zabbix пишет проблема решена,
      Интернет у абонента появился.
      Уважаемые специалисты подскажите куда копать,
      Как правильно продиагностировать ONU удаленно.
      Может есть какие инструкции.
      Спасибо за внимание, перерыл весь интернет, может чего упустил.
