Не собирается на Mandriva 2006!
Не получается собрать на Mandriva 2006
вот сообщения компилятора
  Цитата
[root@inet-srv stargazer]# ./build
      Building STG 2.4 for Linux
Makeing stg_logger.lib
cp stg_logger.h ../../include/
cp libstg_logger.a ../../lib/
Makeing crypto.lib
cp ag_md5.h blowfish.h ../../include/
cp libcrypto.a ../../lib/
Makeing common.lib
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c common.cpp
ar rc libstg_common.a debug.o stg_error.o common.o
ranlib libstg_common.a
cp debug.h stg_error.h common.h ../../include/
cp libstg_common.a ../../lib/
Makeing script_executer.lib
g++ -g -Wall -I ../../include/ -I ./ -DLINUX -DSTG_TIME -c script_executer.cpp
ar rc libscript_executer.a script_executer.o
ranlib libscript_executer.a
cp script_executer.h ../../include/
cp libscript_executer.a ../../lib/
Makeing conffiles.lib
cp conffiles.h ../../include/
cp libconffiles.a ../../lib/
Makeing hostallow.lib
cp hostallow.h ../../include/
cp libhostallow.a ../../lib/
Makeing pinger.lib
cp pinger.h ../../include/
cp libstg_pinger.a ../../lib/
Makeing dotconfpp.lib
cp dotconfpp.h mempool.h ../../include/
cp libdotconfpp.a ../../lib/
Makefile:103: deps: No such file or directory
g++ -c admin.cpp -g3 -Wall -I ../../include -DLINUX
../../include/base_store.h:25: warning: 'class BASE_STORE' has virtual functions but non-virtual destructor
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/stl_construct.h: In function 'void std::_Destroy(_ForwardIterator, _ForwardIterator, _Allocator) [with _ForwardIterator = RESETABLE<std::string>*, _Allocator = std::allocator<RESETABLE<std::string> >]':
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/stl_vector.h:273:  instantiated from 'std::vector<_Tp, _Alloc>::~vector() [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]'
../../include/user_conf.h:74:  instantiated from here
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/stl_construct.h:174: error: no matching function for call to 'std::allocator<RESETABLE<std::string> >::destroy(std::string*)'
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/ext/new_allocator.h:107: note: candidates are: void __gnu_cxx::new_allocator<_Tp>::destroy(_Tp*) [with _Tp = RESETABLE<std::string>]
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/stl_construct.h: In function 'void std::_Destroy(_ForwardIterator, _ForwardIterator, _Allocator) [with _ForwardIterator = __gnu_cxx::__normal_iterator<RESETABLE<std::string>*, std::vector<RESETABLE<std::string>, std::allocator<RESETABLE<std::string> > > >, _Allocator = std::allocator<RESETABLE<std::string> >]':
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/vector.tcc:125:  instantiated from 'typename std::vector<_Tp, _Alloc>::iterator std::vector<_Tp, _Alloc>::erase(__gnu_cxx::__normal_iterator<typename _Alloc::pointer, std::vector<_Tp, _Alloc> >, __gnu_cxx::__normal_iterator<typename _Alloc::pointer, std::vector<_Tp, _Alloc> >) [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]'
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/stl_vector.h:425:  instantiated from 'void std::vector<_Tp, _Alloc>::resize(size_t, const _Tp&) [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]'
/usr/lib/gcc/i586-mandriva-linux-gnu/4.0.1/../../../../include/c++/4.0.1/bits/stl_vector.h:442:  instantiated from 'void std::vector<_Tp, _Alloc>::resize(size_t) [with _Tp = RESETABLE<std::string>, _Alloc = std::allocator<RESETABLE<std::string> >]'
../../include/user_conf.h:75:  instantiated from here
gmake: *** [admin.o] Ошибка 1
stargazer stg-2.402.9.7
gcc version 4.0.1 (4.0.1-5mdk for Mandriva Linux release 2006.0)
Уважаемый разработчики, подскажите что можно сделать, в changelog укзано, что ошибки сборки на gcc4 исправлены!
To XoRe:
Я бы посоветовал посмотреть, есть ли такая папка/файла в каталоге с сырцами стг.
Попробовал собрать на другой системе
[root@ns stargazer]#
gcc -vns stargazer]#
Reading specs from /usr/lib/gcc-lib/i586-mandrake-linux-gnu/3.3.1/specs
Configured with: ../configure --prefix=/usr --libdir=/usr/lib --with-slibdir=/lib --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --enable-long-long --enable-__cxa_atexit --enable-languages=c,c++,ada,f77,objc,java,pascal --host=i586-mandrake-linux-gnu --with-system-zlib
Thread model: posix
gcc version 3.3.1 (Mandrake Linux 9.2 3.3.1-2mdk)
все собралось прекрасно, так что, имхо, дело не в этом.
И у меня почти так же. Только файлы все находит, но спотыкается тоже на этих строках:
[root@z stargazer]#
Неужели тоже из-за 64 бит? Или в версии gcc? У меня gcc 4.0.1-5mdk . Как это решается?
Попробуйте обновить ГСС до последней или скомпилить где нить на машине 32-х битной можно даже с ГСС = 3.х.х. На 64 битах компиляция может не проходить.
