Zolks 24 Опубликовано: 2015-02-11 07:41:15 Share Опубликовано: 2015-02-11 07:41:15 (відредаговано) Собственно похоже столкнулся с проблемой на одном из олтов (с онушками FORA) #sh epon active-onu int epon 0/4 Interface EPON0/4 has bound 31 active ONUs: IntfName MAC Address Status OAM Status Distance(m) RTT(TQ) LastRegTime LastDeregTime LastDeregReason Alivetime ---------- -------------- --------------- ------------ ----------- ------- ------------------- ------------------- ----------------- ------------ EPON0/4:1 fcfa.f7c5.0fd2 auto_configured ctc oam oper 1656 1071 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:3 fcfa.f7c5.5b8f auto_configured ctc oam oper 3600 2286 2015.02.11.10:30:11 2015.02.11.10:30:10 wire down 0.00:03:07 EPON0/4:4 fcfa.f7c5.5544 auto_configured ctc oam oper 3792 2406 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:6 fcfa.f7c5.4d5c auto_configured ctc oam oper 3387 2153 2015.02.11.10:30:11 2015.02.11.10:30:11 wire down 0.00:03:07 EPON0/4:8 fcfa.f7c5.68a1 auto_configured ctc oam oper 3768 2391 2015.02.11.10:30:11 2015.02.11.10:30:10 wire down 0.00:03:07 EPON0/4:11 fcfa.f7c5.5cd6 auto_configured ctc oam oper 3836 2434 2015.02.11.10:30:11 2015.02.11.10:30:11 wire down 0.00:03:07 EPON0/4:12 fcfa.f7c5.5fe2 auto_configured ctc oam oper 3216 2046 2015.02.11.10:30:11 2015.02.11.10:30:11 wire down 0.00:03:07 EPON0/4:13 fcfa.f7c6.177b auto_configured ctc oam oper 3795 2408 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:14 fcfa.f7c6.2f28 auto_configured ctc oam oper 3432 2181 2015.02.11.10:30:11 2015.02.11.10:30:11 wire down 0.00:03:07 EPON0/4:15 fcfa.f7c6.2f2b auto_configured ctc oam oper 3048 1941 2015.02.11.10:30:11 2015.02.11.10:30:11 wire down 0.00:03:07 EPON0/4:16 fcfa.f7c6.1781 auto_configured ctc oam oper 3363 2138 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:17 fcfa.f7c6.2bbc auto_configured ctc oam oper 3459 2198 2015.02.11.10:30:11 2015.02.11.10:30:11 wire down 0.00:03:07 EPON0/4:18 fcfa.f7c6.261f auto_configured ctc oam oper 3424 2176 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:20 fcfa.f796.341e auto_configured ctc oam oper 1758 1135 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:21 fcfa.f7c5.0c6b auto_configured ctc oam oper 1398 910 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:22 fcfa.f79d.0572 auto_configured ctc oam oper 1768 1141 1970.01.01.03:00:26 1970.01.01.03:00:22 unknow 16477.07:32:52 EPON0/4:23 fcfa.f796.3320 auto_configured ctc oam oper 1414 920 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:24 fcfa.f796.32cf auto_configured ctc oam oper 1396 909 2015.02.11.10:30:52 2015.02.11.10:30:11 power off 0.00:02:26 EPON0/4:25 fcfa.f796.395c auto_configured ctc oam oper 1331 868 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:26 fcfa.f796.384e auto_configured ctc oam oper 1465 952 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:27 fcfa.f796.4f1b auto_configured ctc oam oper 1873 1207 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:28 fcfa.f796.395a auto_configured ctc oam oper 1414 920 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:30 fcfa.f796.2d4c auto_configured ctc oam oper 1499 973 1970.01.01.03:00:26 1970.01.01.03:00:22 unknow 16477.07:32:52 EPON0/4:31 fcfa.f7c5.0d25 auto_configured ctc oam oper 1793 1157 2015.02.11.10:31:14 2015.02.11.10:31:00 wire down 0.00:02:04 EPON0/4:32 fcfa.f796.3833 auto_configured ctc oam oper 1817 1172 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:33 fcfa.f796.3462 auto_configured ctc oam oper 1352 881 1970.01.01.03:00:25 1970.01.01.03:00:22 unknow 16477.07:32:53 EPON0/4:35 fcfa.f796.3b86 auto_configured ctc oam oper 1292 844 1970.01.01.03:00:26 1970.01.01.03:00:22 unknow 16477.07:32:52 EPON0/4:39 fcfa.f796.32ec auto_configured ctc oam oper 1352 881 1970.01.01.03:00:26 1970.01.01.03:00:22 unknow 16477.07:32:52 EPON0/4:40 fcfa.f796.4d36 auto_configured ctc oam oper 1886 1215 1970.01.01.03:00:23 1970.01.01.03:00:22 unknow 16477.07:32:55 EPON0/4:42 a0c6.ec00.fdcf authenticated notready 1988 1279 2015.02.11.10:33:12 2015.02.11.10:33:12 wire down 0.00:00:06 EPON0/4:43 a0c6.ec00.fdd6 authenticated notready 1988 1279 2015.02.11.10:33:12 2015.02.11.10:33:12 wire down 0.00:00:06 Только подключили двух абонентов. В начале зарегистрировались нормально. Проблема началась спустя 30-60 минут. Онушки постоянно перерегистрируются. Клиентский мак за ОНУ не видно. Очень долго отвечает на запрос уровня сигнала. Версия прошивки на олте последняя (только что перепрошил, на всякий случай) До этого был такой же случай (на том же ОЛТе) - разбираться не стали, заменили ОНУ на БДком и все полетело, Фора встала в другом районе и тоже работает нормально. так же в это время sh epon interface epon 0/4:42 onu ctc optical-transceiver-diagnosis ничего не показывает Відредаговано 2015-02-11 07:45:50 Zolks Ссылка на сообщение Поделиться на других сайтах
Reanemator_ua 21 Опубліковано: 2015-02-11 07:53:33 Share Опубліковано: 2015-02-11 07:53:33 Насколько мне стало известно на текущий момент из всех проданных FOR проблемными считаются около 5%. Конечно, это можно спихнуть на брак, но суть в том, что при перемещении ONU в другую ветку или на другую голову она может начать благополучно работать. В настоящий момент китайцы делают новую прошивку, которая будет сохранять на флэш память ONU отладочную информацию. Как только эта прошивка появится, я выложу её на наш Дропбокс. Ссылка на сообщение Поделиться на других сайтах
Zolks 24 Опубліковано: 2015-02-11 07:53:40 Автор Share Опубліковано: 2015-02-11 07:53:40 проверил олт в другом районе. EPON0/4:27 fcfa.f7c6.26b7 auto_configured ctc oam oper 4513 2857 2015.02.08.20:18:45 2015.02.08.20:18:23 power off 2.14:33:48 EPON0/4:28 fcfa.f7c6.2596 auto_configured ctc oam oper 3694 2345 1970.01.01.03:00:21 1970.01.01.03:00:20 unknow 16477.07:52:12 EPON0/4:30 fcfa.f7c6.25b1 auto_configured ctc oam oper 3875 2458 2015.02.09.15:17:50 2015.02.09.15:17:35 power off 1.19:34:43 EPON0/4:31 fcfa.f7c6.259e auto_configured ctc oam oper 4001 2537 2015.02.09.20:51:55 2015.02.09.20:51:41 power off 1.14:00:38 EPON0/4:32 a0c6.ec00.fddc auto_configured linkfault 3844 2439 2015.02.10.20:29:11 2015.02.10.20:27:46 wire down 0.14:23:22 EPON0/4:33 a0c6.ec00.feeb auto_configured linkfault 3760 2386 2015.02.11.02:43:59 2015.02.11.02:43:24 wire down 0.08:08:34 но при этом клиенты работают. Ссылка на сообщение Поделиться на других сайтах
Reanemator_ua 21 Опубліковано: 2015-02-11 08:33:19 Share Опубліковано: 2015-02-11 08:33:19 проверил олт в другом районе. EPON0/4:27 fcfa.f7c6.26b7 auto_configured ctc oam oper 4513 2857 2015.02.08.20:18:45 2015.02.08.20:18:23 power off 2.14:33:48 EPON0/4:28 fcfa.f7c6.2596 auto_configured ctc oam oper 3694 2345 1970.01.01.03:00:21 1970.01.01.03:00:20 unknow 16477.07:52:12 EPON0/4:30 fcfa.f7c6.25b1 auto_configured ctc oam oper 3875 2458 2015.02.09.15:17:50 2015.02.09.15:17:35 power off 1.19:34:43 EPON0/4:31 fcfa.f7c6.259e auto_configured ctc oam oper 4001 2537 2015.02.09.20:51:55 2015.02.09.20:51:41 power off 1.14:00:38 EPON0/4:32 a0c6.ec00.fddc auto_configured linkfault 3844 2439 2015.02.10.20:29:11 2015.02.10.20:27:46 wire down 0.14:23:22 EPON0/4:33 a0c6.ec00.feeb auto_configured linkfault 3760 2386 2015.02.11.02:43:59 2015.02.11.02:43:24 wire down 0.08:08:34 но при этом клиенты работают. Вы скорость у них проверьте. Как вариант они работают на критически низкой скорости с огромным пингом. Ссылка на сообщение Поделиться на других сайтах
