Darth Vader2 34 Опубликовано: 2016-04-06 10:42:26 Share Опубликовано: 2016-04-06 10:42:26 (відредаговано) GPON OLT - FD1508GS http://www.cdatatec.com/FD1508GS%208PON%20Port%20GPON%20OLT.html Кто что знает об этом звере, поделитесь инфой. Может применяет кто, может есть негативный/позитивный опыт использования? под спойлером описание: C-DATA presents the industry's leading GPON solution of FD1508GS, which complies with the relevant standards of ITU G.984.x and FSAN. FD1508GS is 1U Rack mount equipment, 8pon ports, 8 GE uplink optic ports, 8 GE uplink electric ports. The maximum optical coupling ratio of 1:128, up to 1024 GPON ONTs. The down link band width is 2.5Gbps and uplink bandwidth is 1.25Gbps. The product is in compact design and convenient for flexible using, easy to deploy with high performance. It can meet the requirements of equipment performance and compact volume of the room environment. It can also satisfy the requirements of the access network and enterprise network that enhancing the network function, improving the reliability and reducing power consumption. The product is suitable for the "triple play" service, the resident of optical access network, video surveillance network, enterprise network and the Internet of the network applications. Product Features Comply with ITU-T G.984/G.988 standards and China's Telecom industry GPON standards Support OMCI remote management of ONT/ONU, compatible with ITU-984.4 OMCI protocol Standalone 1U 8PON compact design of OLT products FD1508GS provides 8 GPON ports, 8 uplink GE optical ports + 8 uplink GE electric ports, 10 Gigabit card expansion slot provides 2*10Gigabit SFP+ uplink port. Each PON port supports 128 ONT, total 1024 ONT for one chassis. Support dual power supply redundancy, 220VAC and -48VDC mixed. The complete layer 2 switching function OLT is with powerful layer 2 switching capacity and complete layer 2 protocol. Supporting with the exchange, isolation and One By One working mode. Supporting port aggregation, VLAN, port speed, queue technology, flow control technology and ACL rich two layer function. Offering the technical support for the development of the multi-service fusion. The QOS security GPON products is with complete DBA function and excellent ability of QoS service. DBA provides a variety of QoS for the GPON system by means of four types of bandwidth and five types of T-CONT. It can meet different business flow of time delay, jitter and packet loss rate of different QoS requirements. Easy-to-use management system Support CLI and SNMP management. complying with OMCI standard. Realizing the business management through OMCI channel protocol, including the ONT function parameters, type and number of T-CONT business, QoS parameter, configuration request information and performance statistics, automatic notification running event system, the realization of OLT on ONT configuration, fault diagnosis, performance and security management. Відредаговано 2016-04-06 10:46:17 Darth Vader2 Ссылка на сообщение Поделиться на других сайтах
CJIABA 23 Опубліковано: 2016-04-06 16:23:26 Share Опубліковано: 2016-04-06 16:23:26 Я общался с ихним представителем по поводу 2-х портовой головы, но тоже отзывов не нашел. Скорее всего придется брать на свой страх и риск. Кста, при покупке 1000 онушек (по 18 у.е.) обещали подарить 4-х портовую голову Ссылка на сообщение Поделиться на других сайтах
