Проблема с Ericsson Redback Smartedge SE100 отваливаются интерфейсы
Отпадают все интерфейсы на Ericsson Redback Smartedge SE100. После того, как появилась данная проблема - открыли устройство пропылесосили, посмотрели вздутых конденсаторов нет на плате и т.п. На вид выглядит нормально, в лог пишет:
May 17 20:38:53: %PM-1-ALERT: Process IPPA IPC SLOT 2, pid 0x80020023, is not responding.
May 17 20:38:56: %SYSMON-5-GEN_FTP: Core file /ata0/p01/ppa/crashSlot02Ippa.gz FTPed to /md/ successfully
May 17 20:39:00: %CSM-6-PORT: ethernet 2/1 link state DOWN service state DOWN, overall admin is UP
May 17 20:39:00: %CSM-6-PORT: ethernet 2/1 link state down, trigger source: Hardware removed
May 17 20:39:00: %CSM-6-PORT: ethernet 2/2 link state DOWN service state DOWN, overall admin is UP
May 17 20:39:00: %CSM-6-PORT: ethernet 2/2 link state down, trigger source: Hardware removed
May 17 20:39:00: %CSM-6-PORT: ethernet 2/3 link state DOWN service state DOWN, overall admin is UP
May 17 20:39:00: %CSM-6-PORT: ethernet 2/3 link state down, trigger source: Hardware removed
May 17 20:39:00: %CSM-6-PORT: ethernet 2/4 link state DOWN service state DOWN, overall admin is UP
May 17 20:39:00: %CSM-6-PORT: ethernet 2/4 link state down, trigger source: Hardware removed
May 17 20:39:00: %CSM-6-PORT: ethernet 2/15 link state DOWN service state DOWN, overall admin is UP
May 17 20:39:00: %CSM-6-PORT: ethernet 2/15 link state down, trigger source: Hardware removed
May 17 20:39:00: %CSM-6-PORT: ethernet 2/16 link state DOWN service state DOWN, overall admin is UP
May 17 20:39:00: %CSM-6-PORT: ethernet 2/16 link state down, trigger source: Hardware removed
May 17 20:39:00: %CSM-6-CARD: card carrier REMOVED from slot 2
May 17 20:39:02: %PM-1-ALERT: Process EPPA IPC SLOT 2, pid 0x81020021, is not responding.
May 17 20:39:02: [0002]: %DHCP-5-MRKG_SV_DEAD: Marking server: 192.168.11.1 in context: inet dead
May 17 20:39:02: %LG-3-GRP_LOG: link-group LACP_SE100 state: DOWN
May 17 20:39:02: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:300 state: DOWN
May 17 20:39:02: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:301 state: DOWN
May 17 20:39:02: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:302 state: DOWN
May 17 20:39:02: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:333 state: DOWN
May 17 20:39:02: %LG-3-GRP_LOG: link-group LACP_local2 state: DOWN
May 17 20:39:10: %CSM-6-CARD: card carrier INSERTED in slot 2
May 17 20:39:15: %PUBSUB-3-ERR: SNMPD [rbn_pubsub_cache_attr_read]: Instance(20) out of range(0..18) for data id(128)
May 17 20:39:15: %PUBSUB-3-ERR: SNMPD [rbos_pubsub_data_get]: rbn_pubsub_cache_attr_read failed (-1), instance (20), id (128)
May 17 20:39:15: %PUBSUB-3-ERR: SNMPD [rbn_pubsub_cache_attr_read]: Instance(21) out of range(0..18) for data id(128)
May 17 20:39:15: %PUBSUB-3-ERR: SNMPD [rbos_pubsub_data_get]: rbn_pubsub_cache_attr_read failed (-1), instance (21), id (128)
May 17 20:39:17: %CSM-6-CARD: MIC number 1 ge-2-port REMOVED from slot 2
May 17 20:39:17: %SNMP-6-INFO: The last entity configuration change notification was sent out2.00 (less than 5.00) seconds before. Suppressing this one.
May 17 20:39:19: %CSM-6-CARD: MIC number 2 ge-2-port REMOVED from slot 2
May 17 20:39:19: %SNMP-6-INFO: The last entity configuration change notification was sent out4.00 (less than 5.00) seconds before. Suppressing this one.
May 17 20:39:19: %CSM-6-CARD: MIC number 1 ge-2-port INSERTED in slot 2
May 17 20:39:19: %PUBSUB-3-ERR: SNMPD [rbn_pubsub_cache_attr_read]: Instance(20) out of range(0..18) for data id(128)
May 17 20:39:19: %PUBSUB-3-ERR: SNMPD [rbos_pubsub_data_get]: rbn_pubsub_cache_attr_read failed (-1), instance (20), id (128)
May 17 20:39:19: %PUBSUB-3-ERR: SNMPD [rbn_pubsub_cache_attr_read]: Instance(21) out of range(0..18) for data id(128)
May 17 20:39:19: %PUBSUB-3-ERR: SNMPD [rbos_pubsub_data_get]: rbn_pubsub_cache_attr_read failed (-1), instance (21), id (128)
May 17 20:39:20: %CSM-6-CARD: MIC number 2 ge-2-port INSERTED in slot 2
May 17 20:39:20: %PUBSUB-3-ERR: SNMPD [rbn_pubsub_cache_attr_read]: Instance(32) out of range(0..18) for data id(128)
May 17 20:39:20: %PUBSUB-3-ERR: SNMPD [rbos_pubsub_data_get]: rbn_pubsub_cache_attr_read failed (-1), instance (32), id (128)
May 17 20:39:20: %PUBSUB-3-ERR: SNMPD [rbn_pubsub_cache_attr_read]: Instance(33) out of range(0..18) for data id(128)
May 17 20:39:20: %PUBSUB-3-ERR: SNMPD [rbos_pubsub_data_get]: rbn_pubsub_cache_attr_read failed (-1), instance (33), id (128)
May 17 20:39:25: %QOS-6-INFO: qos info: PPA just reborn 0
May 17 20:39:25: %PPAINFRA-6-ISTART_INFO: 42e04e7e/0000000002/925500000:02/IPPA/EU00:Ready to receive packets
May 17 20:39:25: %QOS-6-INFO: qos info: iPPA reg on slot 2
May 17 20:39:25: %CSM-6-CARD: card carrier INSERTED in slot 2 READY
May 17 20:39:26: %PPAINFRA-6-ISTART_INFO: 4d2375be/0000000003/390800000:02/EPPA/EU00:Ready to receive packets
May 17 20:39:26: %CSM-6-PORT: ethernet 2/4 link state UP service state UP, overall admin is UP
May 17 20:39:26: %CSM-6-CARD: Card in slot 2 entering In Service state.
May 17 20:39:26: %CSM-6-PORT: ethernet 2/3 link state UP service state UP, overall admin is UP
May 17 20:39:26: %CSM-6-PORT: ethernet 2/15 link state UP service state UP, overall admin is UP
May 17 20:39:26: %CSM-6-PORT: ethernet 2/16 link state UP service state UP, overall admin is UP
May 17 20:39:26: %PPAINFRA-6-IFACE_INFO: 588d172e/0000000003/908300000:02/IPPA/EU00:ROUTING_READY sent to CSM
May 17 20:39:26: %QOS-6-INFO: qos info: PPA just reborn 0
May 17 20:39:26: %QOS-6-INFO: qos info: ePPA reg on slot 2
May 17 20:39:28: %CSM-6-PORT: ethernet 2/1 link state UP service state UP, overall admin is UP
May 17 20:39:28: %CSM-6-PORT: ethernet 2/2 link state UP service state UP, overall admin is UP
May 17 20:39:30: %LG-3-GRP_LOG: link-group LACP_SE100 state: UP
May 17 20:39:30: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:300 state: UP
May 17 20:39:30: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:301 state: UP
May 17 20:39:30: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:302 state: UP
May 17 20:39:30: %LG-3-GRP_LOG: link-group LACP_SE100 PVC:333 state: UP
May 17 20:39:37: %PM-1-ALERT: Process IPPA IPC SLOT 2, pid 0x80020025, is not responding.
May 17 20:39:37: %NAT-3-INT_ERR: work thread: failed to send UNBIND POLICY to EPPA, pol_grid 1
May 17 20:39:38: %NAT-3-INT_ERR: work thread: failed to send UNBIND POLICY to EPPA, pol_grid 1
May 17 20:39:38: %NAT-3-INT_ERR: work thread: failed to send UNBIND POLIC..
Из-за чего может быть проблема?
    • Від Bandalen
      Ericsson SE100 - цена 3000 у.е. / шт.
      В состав входит:
      Шасси Ericsson SE100 с блоком питания переменного тока, 2 комбо-порта 1000BaseT/SFP; Модуль на 2 порта 1000Base-X (SFP) (2шт); Лицензия на 8000 активных подписчиков; Комплект крепления в стойку; Compact Flash карта с SmartEdge OS текущей версии.
      Контакт - 044 359 0770
