MA5608T Port state Offline
Буду благодарен за подсказку куда рыть в этой ситуации:
MA5608T(config)#interface gpon 0/0
MA5608T(config-if-gpon-0/0)#display port state 0
  Port Information
  F/S/P                        0/0/0
  Port state                   Offline
  Optical Module State
  Optical Module status        Online
почему Offline ?
По этой же причине, видимо:
MA5608T(config)#display service-port 1
  Index               : 1
  State               : down
Спасайте, кто может.
  • Відповіді 83
  • Створено
  • Остання відповідь
Добавлю полную картину:
  Port Information
  F/S/P                        0/0/0
  Port state                   Offline
  Last down cause              -
  Last up time                 -
  Last down time               -
  Port energy-saving flag      No
  xPON MAC chipset state       Normal
  Signal detect                Failed
  Available bandwidth(Kbps)    1238420
  Illegal rogue ONT            Inexistent
  Laser state                  Normal
  TX fault                     Normal
  Temperature(C)               30
  TX Bias current(mA)          12
  Supply Voltage(V)            3.24
  TX power(dBm)                5.69
  Optical Module Manufacturer Information
  Vendor name                  NEOPHOTONICS
  Vendor rev                   1.0
  Vendor OUI                   Unspecified
  Vendor PN                    38J0-6537E-KC+
  Vendor SN                    A1015081050
  Date Code                    15-10-21
  Vendor specific              00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Optical Module Static Information
  Module type                  GPON
  Module sub-type              CLASS C+
  Used type                    OLT
  Encapsulation Type           SFP
  SFF-8472 Compliance          Includes functionality described in Rev 9.5
  Max Distance(Km)             60
  Max rate(Kbps)               2500000
  Rate Identifier              Unspecified(0x0)
  Wave length(nm)              1490
  Fiber type                   Single Mode
  Identifier                   SFP or SFP Plus
  Ext.Identifier               GBIC/SFP function is defined by two-wire
                               interface ID only
  Connector                    SC
  Encoding                     NRZ
  Length(9��m)(km)             -
  Length(50��m)(m)             -
  Length(62.5��m)(m)           -
  Length(copper)(m)            -
  Length(50��m,OM3)(m)         -
  BR,max                       Unspecified
  BR,min                       Unspecified
  Diagnostic Monitoring Type   Digital diagnostic monitoring
                               Externally Calibrated
                               Power measurement type: Average Power
  Options                      TX_DISABLE,and disables the serial output
                               TX_FAULT
                               LOS(signal inverted from standard definition)
  Enhanced Options             Alarm/warning flags
                               TX_DISABLE control and monitoring
                               TX_FAULT monitoring
  OTDR capability              Not support
  Cc_base                      0x01(Correct)
  CC_EXT                       0x96(Correct)
  Optical Module Threshold Parameter
  Rx power warning
  threshold(dBm)               [-32.2,-12.0]
  Rx power alarm
  threshold(dBm)               [-34.0,-11.0]
  Tx power warning
  threshold(dBm)               [2.5,7.0]
  Tx power alarm
  threshold(dBm)               [2.0,7.5]
  Tx bias warning
  threshold(mA)                [0.000,70.000]
  Tx bias alarm
  threshold(mA)                [0.000,90.000]
  Supply voltage warning
  threshold(V)                 [3.100,3.500]
  Supply voltage alarm
  threshold(V)                 [3.000,3.600]
  Temperature warning
  threshold(C)                 [0,75]
  Temperature alarm
  threshold(C)                 [-4,79]
состояние второго порта:
MA5608T(config-if-gpon-0/0)#display port state 1
  Port Information
  F/S/P                        0/0/1
  Port state                   Offline
  Last down cause              -
  Last up time                 -
  Last down time               -
  Signal detect                Normal
  Available bandwidth(Kbps)    1238731
  Laser state                  Normal
  TX fault                     Normal
  Temperature(C)               27
  TX Bias current(mA)          10
  TX power(dBm)                5.45
  Vendor rev                   1.0
  Vendor SN                    A1015081776
  Date Code                    15-10-20
  Module type                  GPON
  Used type                    OLT
  Max Distance(Km)             60
                               interface ID only
  Connector                    SC
  Encoding                     NRZ
  Length(9��m)(km)             -
  Length(50��m)(m)             -
  Length(copper)(m)            -
  BR,max                       Unspecified
  BR,min                       Unspecified
                               TX_FAULT
                               TX_FAULT monitoring
  CC_EXT                       0xa4(Correct)
  Rx power warning
  Rx power alarm
  Tx power warning
  Tx power alarm
  threshold(dBm)               [2.1,7.6]
  Tx bias warning
  Tx bias alarm
  Temperature warning
  threshold(C)                 [0,75]
  Temperature alarm
Відредаговано Darth Vader2
MA5608T(config)#display board 0/0
Board Name : H806GPBD
Board Status : Normal
Power Status Power-off cause Power-off Time
POWER-ON - -
Port Port min-distance max-distance Optical-module
type (km) (km) status
0 GPON 0 20 Online
1 GPON 0 20 Online
2 GPON 0 20 Online
3 GPON 0 20 Online
4 GPON 0 20 Online
5 GPON 0 20 Online
6 GPON 0 20 Online
7 GPON 0 20 Online
F/S/P ONT SN Control Run Config Match Protect
ID flag state state state side
0/ 0/0 1 414C434CF2104182 active offline initial initial no
F/S/P ONT-ID Description
0/ 0/0 1 test2
In port 0/ 0/0 , the total of ONTs are: 1, online: 0
0/ 0/1 1 414C434CF2104162 active offline initial initial no
0/ 0/1 1 test2
In port 0/ 0/1 , the total of ONTs are: 1, online: 0
In port 0/ 0/2 , the total of ONTs are: 0, online: 0
In port 0/ 0/3 , the total of ONTs are: 0, online: 0
In port 0/ 0/4 , the total of ONTs are: 0, online: 0
In port 0/ 0/5 , the total of ONTs are: 0, online: 0
In port 0/ 0/6 , the total of ONTs are: 0, online: 0
In port 0/ 0/7 , the total of ONTs are: 0, online: 0
ону сама gpon, не epon?
http://local.com.ua/forum/topic/86420-%D0%BF%D1%80%D0%BE%D0%B4%D0%B0%D0%BC-gpon-onu-alcatel-luccent-i-010g-v/
Не видит онушку, на ней los горит?
Это займет время, за 3 км от меня находится.
Прибил ONT, чтобы увидеть найденную:
MA5608T(config-if-gpon-0/0)#display ont autofind 1
   Number              : 1
   F/S/P               : 0/0/1
   Ont SN              : 414C434CF2104162 (ALCL-F2104162)
   Password            : 0x64656661756C74000000(default)
   Loid                :
   Checkcode           :
   VendorID            : ALCL
   Ont Version         : 3FE54906AAAA01��
   Ont SoftwareVersion : 3FE55344AOTD15
   Ont EquipmentID     : __________I-010G-V__
   Ont autofind time   : 2016-05-30 17:25:48+08:00
Других ONT пока нет. Вижу странности на портах, в частности:
  Port Information
  F/S/P                        0/0/0
  Port state                   Offline
  Port Information
  F/S/P                        0/0/1
  Port state                   Offline
Я поскипал лишнее, чтобы не мешало. По сути два порта, на каждом по одной ONT и смущает разница в Signal detect  и значение Port state, Значение Port state  устанавливается руками или по событию? Если по событию, то по какому?
  Port Information
  F/S/P                        0/0/0
  Port state                   Offline
почему Offline ?
  Index               : 1
  State               : down
Это говорит о том что на оптическом порту (шасси-0/слот-0/порт-0) нет подключенных/зарегестрированных онтишек.
Соответственно сервис-порт(любой номер) по указанному выше оптическому порту будет в дауне. Причина в первой строке.
Я вот также мучался с привезенными DPN-5402...но частично заставил их работать.
Вопрос по регистрации. Достаточно вот такой команды, для регистрации ONT?
ont add 0 0 sn-auth "номер" omci ont-lineprofile-id 12 ont-srvprofile-id 12 desc "PON-TEST"
Для последователей.
Проблема в прошивке, поставщики уже третьи сутки бьются в неравной схватке с Писькенштрассе, фашысты пока побеждают с неравным счетом 4:0 в их пользу. Я наблюдаю со стороны ехидно потирая потные рученки.
Совет: подумайте дважды, прежде чем наступать на мои грабли.
В силу того, что у меня в личных сообщениях есть вопросы касающиеся этой темы и чтобы закрыть вопрос о проблеме хочу осветить некоторые детали моих усилий мучений.
Очень кратко.
MA5608T#display ont autofind all
   Number              : 1
   F/S/P               : 0/0/0
   Ont SN              : 414C434CF2104182
   Loid                :
   Checkcode           :
   VendorID            : ALCL
   Ont autofind time   : 2016-06-21 07:09:37+08:00
   The number of GPON autofind ONT is 1
MA5608T#config
MA5608T(config-if-gpon-0/0)#ont add 0 sn-auth 414C434CF2104182 omci ont-lineprofile-id 100 ont-srvprofile-id 100 d
esc new_link
  Number of ONTs that can be added: 1, success: 1
  PortID :0, ONTID :0
на этом этапе ONT добавлена, теперь  сразу посмотрим её статус:
MA5608T(config-if-gpon-0/0)#display ont info 0 0
  F/S/P                   : 0/0/0
  ONT-ID                  : 0
  Control flag            : active
  Run state               : offline
  Config state            : initial
  Match state             : initial
  Reason of offline       : insufficient license for third-party ONTs
  DBA type                : -
  ONT distance(m)         : -
  ONT battery state       : -
  Memory occupation       : -
  CPU occupation          : -
  Temperature             : -
  Authentic type          : SN-auth
  SN                      : 414C434CF2104182 (ALCL-F2104182)
  Management mode         : OMCI
  Software work mode      : normal
  Isolation state         : normal
  Description             : new_link
  Last down cause         : -
  Last up time            : -
  Last down time          : -
  Last dying gasp time    : -
  ONT online duration     : -
  Type C support          : -
  Interoperability-mode   : Unknown
  VoIP configure method   : Default
  Line profile ID      : 100
  Line profile name    : ONU
  FEC upstream switch :Disable
  OMCC encrypt switch :Off
  Qos mode            :PQ
  Mapping mode        :VLAN
  TR069 management    :Disable
  TR069 IP index      :0
  Notes: * indicates Discrete TCONT(TCONT Unbound)
  <T-CONT   0>          DBA Profile-ID:1
  <T-CONT   4>          DBA Profile-ID:10
   <Gem Index 1>
   |Serv-Type:ETH |Encrypt:off |Cascade:off |GEM-CAR:-            |
   |Upstream-priority-queue:0  |Downstream-priority-queue:-       |
    Mapping VLAN  Priority Port    Port  Bundle  Flow  Transparent
    index                  type    ID    ID      CAR
    1       101   -        -       -     -       -     -
  Notes: Run the display traffic table ip command to query
         traffic table configuration
  Service profile ID   : 100
  Service profile name : ALL
  Port-type     Port-number
  POTS          0
  ETH           1
  TDM           0
  MOCA          0
  CATV          0
  TDM port type                     : E1
  TDM service type                  : TDMoGem
  MAC learning function switch      : Enable
  ONT transparent function switch   : Disable
  Ring check switch                 : Disable
  Ring port auto-shutdown           : Enable
  Ring detect frequency             : 8 (pps)
  Ring resume interval              : 300 (s)
  Multicast forward mode            : Untag
  Multicast forward VLAN            : -
  Multicast mode                    : Olt-Control
  Upstream IGMP packet forward mode : Unconcern
  Upstream IGMP packet forward VLAN : -
  Upstream IGMP packet priority     : -
  Native VLAN option                : Concern
  Upstream PQ color policy          : -
  Downstream PQ color policy        : -
  Port-type Port-ID QinQmode  PriorityPolicy Inbound     Outbound
  ETH       1       unconcern unconcern      unconcern   unconcern
  Notes: * indicates the discretely configured traffic profile,
         run the display traffic table ip command to query
         traffic table configuration.
  Port-type Port-ID  DownstreamMode  MismatchPolicy
  ETH             1  operation       discard
  Port-type Port-ID Dscp-mapping-table-index
  ETH       1       0
  IPHOST    1       0
  Port-type  Port-ID    IGMP-mode         IGMP-VLAN  IGMP-PRI  Max-MAC-Count
  ETH              1    -                         -         -      Unlimited
  Alarm policy profile ID      : 0
  Alarm policy profile name    : alarm-policy_0
во всей колбасе выше интересны только две строки:
 Run state               : offline
финита ля комедия. Дальше можно не мучить зверушку - не будет работать.
Прошивка результата не дала. У продавана ONT завелись, пока доехала до нас новые уже не заводились, а когда снесли старые - то и старые не стали уже заводиться. Завтра с утра отправляем OLT обратно с наилучшими пожеланиями.
p.s. если кто-то может подсказать адекватных поставщиков и адекватную техподдержку (второе важнее первого) буду благодарен за информацию.
ОЛТ пошить не пробывали?
ОЛТ не наш, есть обязательства перед поставщиками. В частности, категорически запретили прошивать в сопроводительной записке. Мы люди ответственные и обязательные, что просили - все выполняем в точности. Однако, от ссылки на прошивку не откажусь.
Скиньте полностью конфиг
Это можно выполнить. Сделаю прямо сейчас.
[MA5600V800R013: 5900]
[sysmode]
<sysmode>
switch adsl mode to rfc2662 vdsl mode to tr129
xpon mode switch-to profile-mode
voice-spec set vag-num 8
voice-spec set sip-account-num 2048
protocol support h248
system ex-mode backup
router mode basic
[global-config]
<global-config>
undo traffic table ip index 1
undo traffic table ip index 2
undo traffic table ip index 3
undo traffic table ip index 4
undo traffic table ip index 5
undo traffic table ip index 6
event output eventid 0x0a30a0ea
event eventlevel 0x0a30a0ea major
alarm output alarmid 0x64110001
alarm output alarmid 0x64120001
trap filter event condition id 0x0a300013
trap filter event condition id 0x0a300015
resource threshold mem 94
dba-profile add profile-id 10 profile-name "200Mb" type4 max 204800
dba-profile add profile-id 11 profile-name "1G" type4 max 1024000
ont-srvprofile gpon profile-id 100 profile-name "ALL"
ont-port eth 1
multicast-forward untag
multicast mode olt-control
commit
ont-lineprofile gpon profile-id 0 profile-name "line-profile_default_0"
tcont 0 dba-profile-id 2
tcont 1 dba-profile-id 0
commit
quit
ont-lineprofile gpon profile-id 100 profile-name "ONU"
tcont 4 dba-profile-id 10
gem add 1 eth tcont 4
gem mapping 1 1 vlan 101
commit
quit
ont-lineprofile gpon profile-id 101 profile-name "SWITCH"
tcont 4 dba-profile-id 11
gem add 2 eth tcont 4
gem add 3 eth tcont 4
gem add 4 eth tcont 4
gem add 5 eth tcont 4
gem mapping 1 0 vlan 54
gem mapping 2 0 vlan 12
commit
quit
[device-config]
<device-config>
board add 0/0 H806GPBD
board add 0/4 H801MPWC
[public-config]
<public-config>
snmp-agent local-engineid 800007DB03249EAB9768899E
[vlan-config]
<vlan-config>
vlan 5 smart
vlan 12 smart
vlan 54 smart
port vlan 5 0/2 0
port vlan 5 0/2 1
port vlan 5 0/2 2
port vlan 5 0/2 3
port vlan 12 0/2 0
port vlan 12 0/2 1
port vlan 12 0/2 2
port vlan 12 0/2 3
port vlan 54 0/2 0
port vlan 54 0/2 1
port vlan 54 0/2 2
port vlan 54 0/2 3
[mcu]
<mcu-0/2>
interface mcu 0/2
speed 0 1000
speed 1 1000
speed 2 1000
speed 3 1000
native-vlan 0 vlan 54
[gpon]
<gpon-0/0>
interface gpon 0/0
port 0 ont-auto-find enable
port 1 ont-auto-find enable
port 2 ont-auto-find enable
port 3 ont-auto-find enable
port 4 ont-auto-find enable
port 5 ont-auto-find enable
port 6 ont-auto-find enable
port 7 ont-auto-find enable
ont add 0 0 sn-auth "414C434CF2104182" omci ont-lineprofile-id 100
ont-srvprofile-id 100 desc "new_link"
ont first 0 0
ont add 0 1 sn-auth "414C434CF2104162" omci ont-lineprofile-id 100
ont-srvprofile-id 100 desc "ONT_NO_DESCRIPTION"
ont first 0 1
[emu-config]
<emu-config>
emu add 0 fan 0 1 "H831FCBB"
[abs-config]
<abs-config>
raio-format pitp-pmode cid xpon "anid xpon frame/slot/port:ontid"
raio-format dhcp-option82 cid xpon "anid/frame/slot/port/ontid/gemport/xci"
raio-mode user-defined pitp-pmode
raio-mode user-defined dhcp-option82
raio-anid "E468A3A96BAF"
pitp enable pmode
[dhcp-config]
<dhcp-config>
dhcp mode layer-3 standard
dhcp option82 enable
[config]
<config>
mpls label start 8192
[dhcp]
<dhcp>
dhcp-server 1 ip *.*.*.*
dhcp relay-interface src-ip send
dhcp relay-interface relay-agent send
[prevlanif]
<prevlanif>
interface vlanif5
interface vlanif12
interface vlanif54
[vlanif]
<vlanif5>
interface vlanif5
ip address *.*.*.* 255.255.255.0 description "mgmt"
<vlanif12>
interface vlanif12
dhcp-server 1
<vlanif54>
interface vlanif54
[meth]
<meth0>
interface meth0
[null]
<null0>
interface null0
[aaa]
<aaa>
aaa
authentication-scheme "default"
authorization-scheme "default"
accounting-scheme "default"
domain "default"
[post-system]
<post-system>
ip route-static 0.0.0.0 0.0.0.0 *.*.*.* tag 54 description uprav
ip route-static *.*.*.* 255.255.255.0 *.*.*.* tag 54 description uprav
return
а где эти строки в Вашем конфиге ?
 ont port native-vlan 0 0 eth 1 vlan 101 priority 0
 ont port native-vlan 0 1 eth 1 vlan 101 priority 0
где указан  service-port ?
это откуда взялось - ont first 0 0?
Для проверки статуса ONT добавлять ont port и service-port не обязательно. Значения не имеет, не становились онлайн и при указании этих параметров - только время терял.
ont first 0 0 добавляется если подтверждать ont confirm 0 all, подтверждал и персонально каждую и скопом - как угодно. И посмотрите выше, там указано как добавлялась последняя :  ont add 0 sn-auth то есть id добавляет olt исходя из текущего значения, не руками. Можно конечно и так ont add 0  1 sn-auth
Их нету в открытом доступе, тут только перепрошивка олта и поможет.
Так как настраивали почти любой зоопарк то по опыту скажу либо оригинальные хуа, либо тп-линк, остальное все нестабильный гемморой, либо программно либо аппаратно
Как ответили выше данные строки вообще не нужны в этом случае.
  И что вы думаете? Нами была сброшена конфигурация OLT, уже практически отправили Новой Почтой, как раздается звонок от продавана "я еду к вам настраивать". Хорошо, забираем, приезжает и настраивает. И о чудо! Все ONT онлайн и при тех же манипуляциях нет никаких проблем - все поднимается! На вопрос что было вчера и почему не работало ответа не получили. Конфиг текущий ниже, прошу коллективно посмотреть и найти отличия (ясное дело не по данным регистрации ONT, они могут отличатся, скорее интересуют магические скрытые символы в глобальной конфигурации OLT) с тем конфигом, который есть в этой теме несколькими постами ранее.
Спасибо всем кто согласится помочь.
MA5608T#display current-configuration
{ <cr>|ont<K>|port<K>|section<K>|service-port<K>|simple<K>||<K> }:
  Command:
[sysmode]
  <sysmode>
 router mode basic
[global-config]
  <global-config>
 dba-profile add profile-id 10 profile-name "200m" type4 max 204800
 dba-profile add profile-id 11 profile-name "1g" type4 max 1024000
 ont-srvprofile gpon profile-id 100 profile-name "all"
  ont-port eth 1
  commit
  commit
  quit
 ont-lineprofile gpon profile-id 100 profile-name "onu"
  commit
  quit
 ont-lineprofile gpon profile-id 101 profile-name "switch"
  gem add 6 eth tcont 4
  gem add 7 eth tcont 4
  commit
  quit
[device-config]
  <device-config>
[public-config]
  <public-config>
 snmp-agent local-engineid 800007DB03249EAB97688980
[vlan-config]
  <vlan-config>
 vlan 54 smart
 port vlan 54 0/2 0
[mcu]
  <mcu-0/2>
interface mcu 0/2
 speed 0 1000
 speed 1 1000
 speed 2 1000
 speed 3 1000
[gpon]
  <gpon-0/0>
 interface gpon 0/0
 ont add 0 2 sn-auth "414C434CF210416B" omci ont-lineprofile-id 100
 ont add 1 0 sn-auth "54504C47D87F5EAF" omci ont-lineprofile-id 100
[emu-config]
  <emu-config>
[config]
  <config>
[prevlanif]
  <prevlanif>
 interface vlanif54
[vlanif]
  <vlanif54>
interface vlanif54
[meth]
  <meth0>
interface meth0
[null]
  <null0>
interface null0
[aaa]
  <aaa>
aaa
 domain "default"
[post-system]
  <post-system>
return
    • Від barabashka77
      Продам плати Huawei:
      GPFD (16 GPON, модулі C++ в комплекті) - 950$
      MCUD1 (10G) - 750$
      MCUD (1G) - 200$
    • Від ollegh
      Продам оптичний комутатор Huawei MA5608T, що включає плати EPFD, GPBD ,MCUD, MPWD.
      Основні характеристики:
      Модель: Huawei MA5608T
      Плати: EPFD, GPBD, MCUD, Power.
      Система контролю: 1, гаряча резерва
      Ємність: до 64/128/256 PON портів
      Підтримка протоколів: GPON, EPON, XG-PON1, XGS-PON
      Максимальна пропускна здатність: 3.2Tbps
      Гнізда розширення: до 4 слотів для сервісних плат
      Переваги Huawei MA5608T:
      Висока надійність та стабільність роботи
      Модульна система зручна для розширення та обслуговування
      Гнучке управління трафіком та ресурсами
      Енергоефективність та екологічність
      Комутатор Huawei MA5608T знаходиться у відмінному стані та повністю готовий до використання. Пристрій пройшов тестування знятий з робочої мережі, щоб гарантувати його працездатність.
      Ціна: 100тис грн.
      Для отримання додаткової інформації або у разі зацікавленості, будь ласка, зв'яжіться з нами за контактними даними нижче:
      Телефон 0969872187
    • Від Optic
      Куплю шасси Huawei MA5608T в такой комплектации:
      1) MA5608T - шасси 1шт.
      2) FCBB - блок охлаждения, 1 шт.
      3) MPWD - плата питания 220/48В - 1 шт.
      4) MCUD1 - (2x10G, 2x1G) - 1 шт.
      Также ищу сетевую плату Huawei X2CS для MA5600T/MA5603T - 1 шт.
      Предложения - прошу в ЛС.
      Всем добра!
    • Від electro_
      Huawei OLT MA5608T (mcud1, mpwd1, 1gpbd C+) , 8-GPON портов C+, 3550$ , новый, гарантия, не понадобился, в работе не был. Счет от ФОП. Детали в вайбер чат 0674114728
    • Від Турист
      Куплю Huawei MA5608T / MCUD / MPWD / GPBD C+
