Продам замки "Титан" врезной бабочка
Продам замки "Титан" в комплекте 3 ключа.
Состояние новое.
Количество 13 шт.
Цена 100 грн\шт.
Торг уместен.
    • Автор: Barseg
      Продаю остатки биометрических систем контроля доступа.
      Врезной замок Shepherd 260 (правый).    цена 2000грн.
      Description    Stand alone, Five-latch mortise lock.   Come with automatic lock deadbolt.
        Three ways to unlock: fingerprint, PIN or key.
        Recognizes up to 50 users.
        Set up 30 PIN number.
        Two level user management.    European standard  Mortise.
        LED display/simple buttons for operation.
        Fingerprint won't lose even batteries are dead.
        Door can be left unlocked when needed.
        Emergency key override.
        Operating temperature: 32° to 113° F.
        One year limited manufacturer's warranty.    Specifications    CMOS Optical sensor.   Verification Type: 1 to N.
        Scanning time: < 0.4s.
        Recognition time <0.2 second/user.
        FAR: <4/100000.
        FRR: <3/100.
        Translation tolerance: ±3mm.
        Rotation tolerance: < ±15°.
        Translation tolerance: ±0.1".
        Working humidity 10%--85%.
        Door thickness: 1 1/2" - 2 1/8".         Биометрический контроллер Door Guard DG 110    цена 2500грн.   The basic function is the same as DG100. The additional functions as follows. This model is mainly designed for bank. When emergency happens, like someone robs the bank, working staff can give the alert though matching the registered fingerprint. For this model, it is optional between wireless and wired communication. More importantly, this model realizes the control of authorized time. People can get access only within the described time.   Fingerprint Management Unit
         FP Scanning Mode: CMOS optical sensor
      Capacity: 1000 users
      Matching Mode: 1:N 1:10 1:1
      Scanning Time: <1 second
      Recognition Time: <0.2 second /a fingerprint
      FAR: <0.004%
      FRR: <3%
      Translation Tolerance: ± 3mm
      Rotation Tolerance: <±15°
      Power Supply: 9V constant-voltage power supply 6 AA alkaline cells
      Contour Size (mm): 222×150×83
      Net Weight: 8 lb
      Controllable Amount of Door Locks: 1:8
      Distance of Wireless Operation: 0.5 ~ 15 M (opening distance)
      Receptor
         Power supply: AC220V/50Hz, 0.1A
      Output: 6V~12V/2A
      Built-In Rechargeable Battery: 6V~12V 1200mAH
      Contour Size (mm): 170×112×45
      Net Weight: 2 lb
      Environment Requirement
      Working temperature: -15?C - 55?C
      Связь ЛС, тел. О63 642-2восемь-3восемь. Владимир.
      260manual.pdf
