Sgconf
BSD 6.2
Обновил gmake
проблема таже
../Makefile.in:74: deps: No such file or directory
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD5 -c list.cpp
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD5 -c netunit.cpp
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD5 -c parser.cpp
g++ -g -Wall -I ../../include/ -I ./ -DFREE_BSD5 -c servconf.cpp
servconf.cpp: In function `int AnsRecv(void*, SLIST*)':
servconf.cpp:38: warning: int format, XML_Size arg (arg 3)
ar rc libsrvconf.a list.o netunit.o parser.o servconf.o
ranlib libsrvconf.a
cp servconf.h netunit.h list.h ../../include/
cp libsrvconf.a ../../lib/
deps:1: *** missing separator. Stop.
  • 6 months later...
Подскажите где её искать:
main.cpp:28: getopt.h: No such file or directory
gmake: *** [main.o] Error 1
фря4.10
старая вресия sgconf компилилась, и новый stg2.403 компилится.
так и не могу побороть sgconf.
Пожалуйста, подскажите, как? (стг2404, фря4.10, gcc 3.4.6)
ситуёвина такая:
g++ -c main.cpp -O2 -Wall -I /usr/home/napTu/stg-2.404.9.7-wo_netflow_patch/projects/sgconf_xml/../../include -DFREE_BSD
In file included from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++//i386-portbld-freebsd4.10/bits/gthr-default.h:44,
from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++//i386-portbld-freebsd4.10/bits/gthr.h:96,
from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++//i386-portbld-freebsd4.10/bits/c++io.h:37,
from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++/iosfwd:47,
from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++/bits/stl_algobase.h:70,
from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++/bits/char_traits.h:46,
from /usr/local/lib/gcc/i386-portbld-freebsd4.10/3.4.6/include/c++/string:47,
from request.h:33,
from main.cpp:36:
/usr/include/unistd.h:112: error: declaration of C function `int getopt(int, char* const*, const char*)' conflicts with
/usr/local/include/getopt.h:115: error: previous declaration `int getopt()' here
gmake: *** [main.o] Ошибка 1
