Пролдам свитч Foundry BigIron 4000.
Модуль XENPAK — SFP.
Модуль XENPAK 10G 2 волокна 10 км.
Верой и правдой отработал 5 лет.
Поддержка BGPv4 - до 400000 маршрутов.
Порты:
16 портов 10/100/1000 BaseT
16 портов 1GE SFP
2 порта 10GE XENPAK
Карточки (модули):
J-BxGMR4 JetCore Management Module
J-BxG JetCore Gig Fiber Module
J-BxGC16 JetCore Gig Copper Module
B2x10G Fiber Switch Module
2 Блока питания.
Прошу 1200 у.е.
master arbitrate : become primary arbitrator.
BOOT INFO: Become active CPU module
M2 BI Boot Code Version 07.06.03
Enter 'b' to go to boot monitor ...
BOOT INFO: load from primary copy
BOOT INFO: bootparam at 3fffffe0, mp_flash_size = 003ad9fc
BOOT INFO: code decompression completed
BOOT INFO: branch to 20000104
Reset all modules ...
Init Management module 1 ...
Init JetCore ASIC 1.2.
Init module 2 ...
Init module 3 ...
Init JetCore ASIC 1.2.3.4.
Init module 4 ...
Init 10G FPGA's.......Finished programming 10G FPGA's
Init DMA 1...2...
Parsing Config Data ...
Load config data from flash memory...
Key is successfully generated!
SSH host key is loaded
  SW: Version 08.0.01tT53 Copyright © 1996-2004 Foundry Networks, Inc.
      Compiled on Mar 04 2009 at 22:12:06 labeled as B2R08001t
      (3856892 bytes) from Primary B2R08001t.bin
  HW: BigIron 4000 Router, SYSIF version 21, Serial #: Non-exist
SL 1: J-BxGMR4 JetCore Management Module, SYSIF 2 (Mini GBIC), M4, ACTIVE
      Serial #:   CH52020778
 4096 KB BRAM, JetCore ASIC IGC version 47, BIA version 89
32768 KB PRAM and 2M-Bit*1 CAM for IGC  0, version 0447
32768 KB PRAM and 2M-Bit*1 CAM for IGC  1, version 0447
SL 2: J-BxG JetCore Gig Fiber Module, SYSIF 2 (Mini GBIC)
      Serial #:   CH07040270
 4096 KB BRAM, JetCore ASIC IGC version 49, BIA version 8a
32768 KB PRAM and 2M-Bit*1 CAM for IGC  4, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  5, version 0449
SL 3: J-BxGC16 JetCore Gig Copper Module, SYSIF 2
      Serial #:   PR22025104
 4096 KB BRAM, JetCore ASIC IGC version 49, BIA version 89
32768 KB PRAM and 2M-Bit*1 CAM for IGC  8, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  9, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC 10, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC 11, version 0449
SL 4: B2x10G Fiber Switch Module, SYSIF 2
      Serial #:   US05000247
32768 KB BRAM, XPP version 88, XTM version 89
 4096 KB PRAM(4096K+0K) and 65536*1 CAM entries for DMA 12, version 0158
 4096 KB PRAM(4096K+0K) and 65536*1 CAM entries for DMA 13, version 0158
Active management module:
  466 MHz Power PC processor 750 (version 8/8302) 66 MHz bus
  512 KB boot flash memory
16384 KB code flash memory
  256 KB SRAM
  512 MB DRAM
The system : started=cold start
FSecure SSH is included in this product
BigIron Router>
