Продам маршрутизатор CISCO 3845 Integrated Services Router.
Продам б/у маршрутизатор CISCO 3845 Integrated Services Router.
Цена: 8500грн
Порты:
2xGigabit Ethernet (одни смежный с SFP)
1xConsole
1xAUX
1xPower Supply
Оперативная память: 512mb
Постоянная память (flash): 128mb
Bootlog:
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2006 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB
c3845 platform with 524288 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Cisco 3845 (revision 1.0) with 487423K/36864K bytes of memory.
Processor board ID FCZ14157044
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126976K bytes of ATA System CompactFlash (Read/Write)
#show diag
3845 Backplane EEPROM:Hardware Revision        : 1.0
Top Assy. Part Number    : 800-23093-02
Board Revision           : C0
Deviation Number         : 100612
Fab Version              : 04
PCB Serial Number        : FOC141222CA
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Part Number              : 73-8639-05
CLEI Code                : IPMNX00DRB
Chassis Serial Number    : FCZ14157044
Product (FRU) Number     : CISCO3845
Version Identifier       : V05
Hardware date code       : 20100320
EEPROM format version 4
EEPROM contents (hex):
 0x00: 04 FF 40 04 2B 41 01 00 C0 46 03 20 00 5A 35 02
 0x10: 42 43 30 88 00 01 89 04 02 04 C1 8B 46 4F 43 31
 0x20: 34 31 32 32 32 43 41 03 00 81 00 00 00 00 04 00
 0x30: 82 49 21 BF 05 C6 8A 49 50 4D 4E 58 30 30 44 52
 0x40: 42 C2 8B 46 43 5A 31 34 31 35 37 30 34 34 CB 92
 0x50: 43 49 53 43 4F 33 38 34 35 20 20 20 20 20 20 20
          0x60: 20 20 89 56 30 35 20 83 01 32 B4 E0 FF FF FF FF
 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
       Backplane Registers
   Backplane Revision:              00BE
   Power Supply Status:             F50F
   -48V PS and Env Status:          FFFF
   -48V Isolation Control:          0007
   Backplane Cookie:                000C
   ENM/Backplane FPGA Revision:     00BE
   ENM/Backplane FPGA Int0 Status:  FFFF
   ENM/Backplane FPGA Int2 Status:  00FF
   ENM/Backplane FPGA Int4 Status : EF00
   ENM Interrupt Mask:              0000
   ENM/BP FPGA Interrupt 4 Mask:    0040
   ENM1 Test Port:                  00C3
   ENM2 Test Port:                  00C3
   ENM3 Test Port:                  00C3
   ENM LED Control:                 0000
   ENM OIR Control:                 0000
   ENM OIR Status:                  9999
   ENM PCI Speed Status             000F
   Backplane FPGA Diag Int Control: FFFF
   ENM1 OIR State Machine Status:   4141
   ENM2 OIR State Machine Status:   4141
   ENM3 OIR State Machine Status:   0000
   ENM4 OIR State Machine Status:   0000
   Backplane Voltage Margin:        0000
Slot 0:
C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 1w3d ago
Onboard VPN : FW ver01100200
EEPROM contents at hardware discovery:
PCB Serial Number        : FOC14095G8J
Hardware Revision        : 1.4
Top Assy. Part Number    : 800-23616-07
Board Revision           : C0
Deviation Number         : 102138
Fab Version              : 05
RMA History              : 00
        Processor type           : 69
Product (FRU) Number     : CISCO3845-MB
Version Identifier       : V07
Chassis MAC Address      : ec44.76bb.1a70
MAC Address block size   : 48
Part Number              : 73-8799-10
Hardware date code       : 20100322
 0x00: 04 FF C1 8B 46 4F 43 31 34 30 39 35 47 38 4A 40
 0x10: 04 2C 41 01 04 C0 46 03 20 00 5C 40 07 42 43 30
 0x20: 88 00 01 8E FA 02 05 03 00 81 00 00 00 00 04 00
 0x30: 09 69 C6 8A 49 50 4D 4E 58 30 30 44 52 42 CB 8C
 0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 37
 0x50: 20 D9 02 40 C1 C3 06 EC 44 76 BB 1A 70 43 00 30
 0x60: 82 49 22 5F 0A 83 01 32 B4 E2 C2 8B 46 43 5A 31
 0x70: 34 31 35 37 30 34 34 FF FF FF FF FF FF FF FF FF
#environment
SYS PS1 is present.
Fan status: Normal
Input Voltage status: Normal
DC Output Voltage status: Normal
Type: AC
Thermal status: Normal
 SYS PS2 is absent.
 AUX(-48V) PS1 is absent.
 AUX(-48V) PS2 is absent.
 Fan  1 OK
 Fan  2 OK
 Fan  3 OK
 Fan Speed Setting: Normal
 Alert settings:
 Intake temperature warning: Enabled, Threshold: 55
 Core temperature warning: Enabled, Threshold: 70 (CPU: 90)
 Board Temperature: Normal
 Internal-ambient temperature = 34, Normal
 CPU temperature = 45, Normal
 Intake temperature = 27, Normal
 Backplane temperature = 25, Normal
 Voltage 1(3300) is Normal, Current voltage = 3300 mV
 Voltage 2(5150) is Normal, Current voltage = 5153 mV
 Voltage 3(2500) is Normal, Current voltage = 2549 mV
 Voltage 4(1200) is Normal, Current voltage = 1215 mV
 Nominal frequency
    • Від rusol
      ПРОДАМ Cisco 7206VXR/NPE-G1
      Комплект:
      шассі
      npe/g1
      блок живлення
      блок живлення
      $500
    • Від Oleh B
      Ціна 8900 грн за 1 шт с 2 БЖ.
      Можемо зробити сервери
    • Від krim852
      Добрий день, може хто знає як побороти флуд від роутерів тотолінк N350R?
    • Від xserver
      Software
      BIOS: version 07.69
      BIOS compile time: 04/07/2021
    • Від Drader
