Stargazer + Ipfw + Squid. Возможно или нет?
FreeBSD + stargazer + ipfw + squid. Подскажите возможно ли настроить такую связку?
почему бы и нет? ))) возможно...
ipfw:
#!/bin/sh
fwcmd="/sbin/ipfw -q"
natdcmd="/sbin/natd"
int_if="sk0"
ext_if="vr0"
${fwcmd} -f flush
${natdcmd} -s -m -u -a 192.168.1.3
#${natdcmd} -s -m -u -a 127.0.0.1
${fwcmd} add 10 allow icmp from any to any
#${fwcmd} add 11 allow ip from any to any in via lo0
#${fwcmd} add 12 fwd 127.0.01,3128 tcp from 192.168.0.0/24 to any
#${fwcmd} add 13 allow tcp from any to any
#${fwcmd} add 14 allow udp from any to any
${fwcmd} add 15 pass udp from 192.168.0.0/24 to 192.168.0.0/24 53
${fwcmd} add 16 pass udp from 192.168.0.0/24 53 to 192.168.0.0/24
${fwcmd} add 17 pass tcp from any to any 23
${fwcmd} add 18 pass tcp from any 23 to any
${fwcmd} add 19 pass tcp from 192.168.0.0/24 to 192.168.0.0/24 445
${fwcmd} add 20 pass tcp from 192.168.0.0/24 445 to 192.168.0.0/24
#${fwcmd} add 304 deny ip from any to 192.168.0.0/16 out via ${ext_if}
#${fwcmd} add 305 deny ip from any to 10.0.0.0/16 out via ${ext_if}
#${fwcmd} add 306 deny ip from any to 172.16.0.0/16 out via ${ext_if}
${fwcmd} add 207 allow udp from any to 192.168.0.1 5555, 8888 via ${int_if}
${fwcmd} add 208 allow udp from 192.168.0.1 to any via ${int_if}
${fwcmd} add 220 pass tcp from any to any 139 via ${int_if}
${fwcmd} add 221 pass tcp from any 139 to any via ${int_if}
${fwcmd} add 222 pass udp from any to any 138 via ${int_if}
${fwcmd} add 223 pass udp from any 138 to any via ${int_if}
${fwcmd} add 224 pass udp from any to any 137 via ${int_if}
${fwcmd} add 225 pass udp from any 137 to any via ${int_if}
${fwcmd} add 308 allow ip from 192.168.0.0/24 1000-10000 to 192.168.0.1 via ${int_if}
${fwcmd} add 310 allow tcp from 192.168.0.0/24 to 192.168.0.1 22 via ${int_if}
${fwcmd} add 312 allow tcp from 192.168.0.1 to any via ${int_if}
${fwcmd} add 320 deny log ip from 192.168.1.0/24 to 192.168.1.3 via ${int_if}
${fwcmd} add 321 deny log ip from 192.168.0.0/24 to 192.168.0.1 via ${int_if}
${fwcmd} add 50024 divert natd all from any to any via ${ext_if}
${fwcmd} add 50029 allow tcp from any to any out via ${ext_if} setup
${fwcmd} add 50030 allow tcp from any to any via ${ext_if} established
${fwcmd} add 50031 allow udp from any to any out via ${ext_if}
${fwcmd} add 50032 allow udp from any 53 to any in via ${ext_if}
${fwcmd} add 50063 allow tcp from any 192.168.1.3 22 via ${ext_if}
${fwcmd} add 65534 deny log ip from any to any
OnConnect:
#!/bin/sh
int_if="sk0"
#${fwcmd} -f flush
# Login
LOGIN=$1
#user IP
IP=$2
#cash
CASH=$3
#user ID
ID=$4
${fwcmd} delete `expr ${ID} '*' 10 + 29000`
${fwcmd} delete `expr ${ID} '*' 10 + 29002`
${fwcmd} delete `expr ${ID} '*' 10 + 29003`
${fwcmd} add `expr ${ID} '*' 10 + 29000` allow icmp from ${IP} to any out via ${int_if} icmptype 0,3,4,11,12
${fwcmd} add `expr ${ID} '*' 10 + 29002` allow ip from ${IP} to any
${fwcmd} add `expr ${ID} '*' 10 + 29003` allow ip from any to ${IP}
echo "C `date +%Y.%m.%d-%H.%M.%S` ${IP} ${CASH}" >> /var/stargazer/users/${LOGIN}/connect.log
OnDisconnect:
#!/bin/sh
# Login
LOGIN=$1
#user IP
IP=$2
#cash
CASH=$3
#user ID
ID=$4
echo "D `date +%Y.%m.%d-%H.%M.%S` ${IP} ${CASH}" >> /var/stargazer/users/${LOGIN}/connect.log
Когда в ipfw раскоментируеш 13 и 14 строку всё работает. Соответственно и без Stargazera
Подскажите что нибудь чтоб заработало.
Заранее спасибо.
