masterzep 9 Опубликовано: 2017-11-04 20:32:44 Share Опубликовано: 2017-11-04 20:32:44 Здравствуйте! Пытаюсь получить мультиплекс Т2 с помощью карты TBS6205, но не получается. Памажите люды добрые ) # astra4 --analyze "dvb://#adapter=5&type=t2&frequency=538" Nov 04 19:41:55: INFO: Starting Astra 4.4.182 Nov 04 19:41:56: INFO: Bitrate: 0 Kbit/s Nov 04 19:41:57: INFO: Bitrate: 0 Kbit/s Nov 04 19:41:58: INFO: Bitrate: 0 Kbit/s Nov 04 19:41:59: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:00: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:01: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:01: WARNING: [dvb_input 5:0] fe has no lock. status:_____ Nov 04 19:42:02: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:03: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:04: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:05: INFO: Bitrate: 0 Kbit/s Nov 04 19:42:06: INFO: Bitrate: 0 Kbit/s # dmesg | grep frontend [ 4.493405] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.558356] SAA716x Budget 0000:03:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)... [ 4.632877] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.766777] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.848457] SAA716x Budget 0000:03:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)... [ 4.898651] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... # lspci -vvv 02:00.0 Multimedia controller: Device 544d:6178 Subsystem: Device 6205:0001 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 47 Region 0: Memory at dfec0000 (32-bit, non-prefetchable) [size=256K] Capabilities: [50] Power Management version 3 Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-) Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME- Capabilities: [70] MSI: Enable+ Count=1/1 Maskable- 64bit+ Address: 00000000fee0300c Data: 4152 Capabilities: [90] Express (v1) Endpoint, MSI 00 DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported- RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- MaxPayload 128 bytes, MaxReadReq 512 bytes DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend- LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us ClockPM- Surprise- LLActRep- BwNot- LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+ ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt- LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt- Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00 Kernel driver in use: TBSECP3 driver # modinfo tbsecp3 filename: /lib/modules/3.16.0-4-amd64/kernel/drivers/media/pci/tbsecp3/tbsecp3.ko license: GPL description: TBS ECP3 driver author: Luis Alves <ljalvs@gmail.com> alias: pci:v0000544Dd00006178sv00006301sd*bc*sc*i* alias: pci:v0000544Dd00006178sv0000690Asd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006514sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006814sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006209sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006704sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006281sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006290sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006590sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006528sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006910sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006909sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006908sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006905sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006904sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006903sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006902sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006522sd*bc*sc*i* alias: pci:v0000544Dd00006178sv00006205sd*bc*sc*i* depends: dvb-core,i2c-core,tas2101 vermagic: 3.16.0-4-amd64 SMP mod_unload modversions parm: adapter_nr:DVB adapter numbers (array of short) parm: dma_pkts:DMA buffer size in TS packets (16-256), default 128 (array of int) parm: enable_msi:use an msi interrupt if available (bool) Под Windows прием есть, все исправно. Спасибо! Ссылка на сообщение Поделиться на других сайтах
LV10 282 Опубликовано: 2017-11-04 22:01:24 Share Опубликовано: 2017-11-04 22:01:24 https://github.com/tbsdtv/linux_media/wiki Ссылка на сообщение Поделиться на других сайтах
masterzep 9 Опубликовано: 2017-11-05 07:09:13 Автор Share Опубликовано: 2017-11-05 07:09:13 Как раз эти драйверы стоят. Только что старые удалил, новые по вашей ссылке собрал - ничего не изменилось. Может еще есть идеи? Ссылка на сообщение Поделиться на других сайтах
masterzep 9 Опубликовано: 2017-11-05 07:28:21 Автор Share Опубликовано: 2017-11-05 07:28:21 (изменено) В логах обнаружил # dmesg | grep -i dvb [ 4.220300] dvbdev: DVB: registering new adapter (SAA716x dvb adapter) [ 4.263371] TBSECP3 driver 0000:02:00.0: TurboSight TBS 6205 DVB-T/T2/C [ 4.265122] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.439094] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.439186] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.516365] SAA716x Budget 0000:03:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)... [ 4.516524] dvbdev: DVB: registering new adapter (SAA716x dvb adapter) [ 4.571685] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.571954] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.706432] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.706496] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.808464] SAA716x Budget 0000:03:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)... [ 4.838460] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.838523] TBSECP3 driver 0000:02:00.0: TurboSight TBS 6205 DVB-T/T2/C : PCI 0000:02:00.0, IRQ 47, MMIO 0xdfec0000 [ 104.044045] si2168 6-0064: firmware: failed to load dvb-demod-si2168-b40-01.fw (-2) [ 104.045175] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 104.045710] si2168 6-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 126.635969] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 126.637225] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 126.637706] si2168 6-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 383.987181] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 383.988574] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 383.989160] si2168 6-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 553.330371] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 553.331519] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 553.332709] si2168 6-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 762.079817] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 762.080962] si2168 6-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 762.081465] si2168 6-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 813.882869] si2168 7-0064: firmware: failed to load dvb-demod-si2168-b40-01.fw (-2) [ 813.883995] si2168 7-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 813.885267] si2168 7-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 832.055531] si2168 8-0064: firmware: failed to load dvb-demod-si2168-b40-01.fw (-2) [ 832.056629] si2168 8-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 832.057714] si2168 8-0064: firmware file 'dvb-demod-si2168-02.fw' not found [ 851.010296] si2168 9-0064: firmware: failed to load dvb-demod-si2168-b40-01.fw (-2) [ 851.011417] si2168 9-0064: firmware: failed to load dvb-demod-si2168-02.fw (-2) [ 851.011984] si2168 9-0064: firmware file 'dvb-demod-si2168-02.fw' not found Скачал архив с фирмварем. Ошибки ушли, но приема нет # dmesg | grep -i dvb [ 4.056204] dvbdev: DVB: registering new adapter (SAA716x dvb adapter) [ 4.104598] TBSECP3 driver 0000:02:00.0: TurboSight TBS 6205 DVB-T/T2/C [ 4.105730] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.269800] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.280782] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.351219] SAA716x Budget 0000:03:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)... [ 4.351393] dvbdev: DVB: registering new adapter (SAA716x dvb adapter) [ 4.415728] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.415819] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.550329] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.550418] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter) [ 4.640452] SAA716x Budget 0000:03:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)... [ 4.682412] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6205 DVB-T/T2/C )... [ 4.682473] TBSECP3 driver 0000:02:00.0: TurboSight TBS 6205 DVB-T/T2/C : PCI 0000:02:00.0, IRQ 47, MMIO 0xdfec0000 [ 72.384938] si2168 6-0064: firmware: direct-loading firmware dvb-demod-si2168-b40-01.fw [ 72.384947] si2168 6-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw' [ 400.435309] si2168 6-0064: firmware: direct-loading firmware dvb-demod-si2168-b40-01.fw [ 400.435317] si2168 6-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw' [ 431.847735] si2168 6-0064: firmware: direct-loading firmware dvb-demod-si2168-b40-01.fw [ 431.847743] si2168 6-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw' [ 465.681375] si2168 9-0064: firmware: direct-loading firmware dvb-demod-si2168-b40-01.fw [ 465.681384] si2168 9-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw' [ 487.606536] si2168 9-0064: firmware: direct-loading firmware dvb-demod-si2168-b40-01.fw [ 487.606543] si2168 9-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw' Заработало! Ошибся в Астре синтаксисом параметра bandwidth # astra4 --analyze "dvb://#adapter=5&type=t2&frequency=538&bandwidth=8mhz" Изменено 2017-11-05 07:55:22 пользователем masterzep Ссылка на сообщение Поделиться на других сайтах
