Wireless-G Networking Solution
The Compact All-In-One Wireless-G Networking Solution
<P>The Linksys Compact Wireless-G Broadband Router is really three devices in one small box. First, there's the Wireless Access Point, which lets you connect both screaming fast Wireless-G (802.11g at 54Mbps) and Wireless-B (802.11b at 11Mbps) devices to the network. There's also a built-in 4-port full-duplex 10/100 Switch to connect your wired-Ethernet devices together. Connect four PCs directly, or attach more hubs and switches to create as big a network as you need. Finally, the Router function ties it all together and lets your whole network share a high-speed cable or DSL Internet connection. </P>
<P>Once your computers are connected to the Router and the Internet, they can communicate with each other too, sharing a printer, digital music, picture and document files, and multi-player or on-line games. </P>
<P><IMG alt="Linksys WRT54GC" border=0 height=214 hspace=0 src="http://www.linksys.com/products/image180/wrt54gc.jpg" width=170></P>
<P>To protect your data and privacy, the Wireless-G Broadband Router can encode all wireless transmissions with WEP or industrial-strength WPA Personal encryption. The Router can serve as a DHCP Server, has a powerful SPI firewall to protect your PCs against intruders and most known Internet attacks, and supports VPN pass-through. Configuration is a snap with the web browser-based configuration utility. And the tiny form factor fits any home or desktop. </P>
<P>With the Linksys Compact Wireless-G Broadband Router at the center of your home or office network, you can share a high-speed Internet connection, files, printers, and multi-player games with the flexibility, speed, and security you need! </P>
You should to log in
loading
