Куплю память для Cisco 3845
Гость
    • Від backorder
      Продам б/у маршрутизатор CISCO 3845 Integrated Services Router.
      Цена: 8500грн
      Порты:
      2xGigabit Ethernet (одни смежный с SFP)
      1xConsole
      1xAUX
      1xPower Supply
      Оперативная память: 512mb
      Постоянная память (flash): 128mb
      Bootlog:
      System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 2006 by cisco Systems, Inc. System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 2008 by cisco Systems, Inc. Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB c3845 platform with 524288 Kbytes of main memory Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled ... Cisco 3845 (revision 1.0) with 487423K/36864K bytes of memory. Processor board ID FCZ14157044 2 Gigabit Ethernet interfaces DRAM configuration is 64 bits wide with parity enabled. 479K bytes of NVRAM. 126976K bytes of ATA System CompactFlash (Read/Write) #show diag
      3845 Backplane EEPROM:Hardware Revision        : 1.0 Top Assy. Part Number    : 800-23093-02 Board Revision           : C0 Deviation Number         : 100612 Fab Version              : 04 PCB Serial Number        : FOC141222CA RMA Test History         : 00 RMA Number               : 0-0-0-0 RMA History              : 00 Part Number              : 73-8639-05 CLEI Code                : IPMNX00DRB Chassis Serial Number    : FCZ14157044 Product (FRU) Number     : CISCO3845 Version Identifier       : V05 Hardware date code       : 20100320 EEPROM format version 4 EEPROM contents (hex):  0x00: 04 FF 40 04 2B 41 01 00 C0 46 03 20 00 5A 35 02  0x10: 42 43 30 88 00 01 89 04 02 04 C1 8B 46 4F 43 31  0x20: 34 31 32 32 32 43 41 03 00 81 00 00 00 00 04 00  0x30: 82 49 21 BF 05 C6 8A 49 50 4D 4E 58 30 30 44 52  0x40: 42 C2 8B 46 43 5A 31 34 31 35 37 30 34 34 CB 92  0x50: 43 49 53 43 4F 33 38 34 35 20 20 20 20 20 20 20           0x60: 20 20 89 56 30 35 20 83 01 32 B4 E0 FF FF FF FF  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF        Backplane Registers        -------------------    Backplane Revision:              00BE    Power Supply Status:             F50F    -48V PS and Env Status:          FFFF    -48V Isolation Control:          0007    Backplane Cookie:                000C    ENM/Backplane FPGA Revision:     00BE    ENM/Backplane FPGA Int0 Status:  FFFF    ENM/Backplane FPGA Int2 Status:  00FF    ENM/Backplane FPGA Int4 Status : EF00    ENM Interrupt Mask:              0000    ENM/BP FPGA Interrupt 4 Mask:    0040    ENM1 Test Port:                  00C3    ENM2 Test Port:                  00C3    ENM3 Test Port:                  00C3    ENM3 Test Port:                  00C3    ENM LED Control:                 0000    ENM OIR Control:                 0000    ENM OIR Status:                  9999    ENM PCI Speed Status             000F    Backplane FPGA Diag Int Control: FFFF    ENM1 OIR State Machine Status:   4141    ENM2 OIR State Machine Status:   4141    ENM3 OIR State Machine Status:   0000    ENM4 OIR State Machine Status:   0000    Backplane Voltage Margin:        0000 Slot 0: C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time 1w3d ago Onboard VPN : FW ver01100200 EEPROM contents at hardware discovery: PCB Serial Number        : FOC14095G8J Hardware Revision        : 1.4 Top Assy. Part Number    : 800-23616-07 Board Revision           : C0 Deviation Number         : 102138 Fab Version              : 05 RMA Test History         : 00 RMA Number               : 0-0-0-0 RMA History              : 00         Processor type           : 69 CLEI Code                : IPMNX00DRB Product (FRU) Number     : CISCO3845-MB Version Identifier       : V07 Chassis MAC Address      : ec44.76bb.1a70 MAC Address block size   : 48 Part Number              : 73-8799-10 Hardware date code       : 20100322 Chassis Serial Number    : FCZ14157044 EEPROM format version 4 EEPROM contents (hex):  0x00: 04 FF C1 8B 46 4F 43 31 34 30 39 35 47 38 4A 40  0x10: 04 2C 41 01 04 C0 46 03 20 00 5C 40 07 42 43 30  0x20: 88 00 01 8E FA 02 05 03 00 81 00 00 00 00 04 00  0x30: 09 69 C6 8A 49 50 4D 4E 58 30 30 44 52 42 CB 8C  0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 37  0x50: 20 D9 02 40 C1 C3 06 EC 44 76 BB 1A 70 43 00 30  0x60: 82 49 22 5F 0A 83 01 32 B4 E2 C2 8B 46 43 5A 31  0x70: 34 31 35 37 30 34 34 FF FF FF FF FF FF FF FF FF #environment
      SYS PS1 is present. Fan status: Normal Input Voltage status: Normal DC Output Voltage status: Normal Type: AC Thermal status: Normal  SYS PS2 is absent.  AUX(-48V) PS1 is absent.  AUX(-48V) PS2 is absent.  Fan  1 OK  Fan  2 OK  Fan  3 OK  Fan Speed Setting: Normal  Alert settings:  Intake temperature warning: Enabled, Threshold: 55  Core temperature warning: Enabled, Threshold: 70 (CPU: 90)  Board Temperature: Normal  Internal-ambient temperature = 34, Normal  CPU temperature = 45, Normal  Intake temperature = 27, Normal  Backplane temperature = 25, Normal  Voltage 1(3300) is Normal, Current voltage = 3300 mV  Voltage 2(5150) is Normal, Current voltage = 5153 mV  Voltage 3(2500) is Normal, Current voltage = 2549 mV  Voltage 4(1200) is Normal, Current voltage = 1215 mV  Nominal frequency
    • Від dr_r00t
      Продам:   1. Cisco 7304  - 700$
      2. Cisco 3845-MB - 600 $
      3. VWIC 1MFT-G703 - 70 $
      4. VWIC 2MFT-G703 - 150$
      5. NM-2CE1T1-PRI - 150 $ (есть 2 шт.)
      6. Cisco Catalyst 3650G -24TS-S - 1000 $ 7. Cisco SFP GLC-LH-SM - 30$ ( есть 2 шт) 8. Cisco SFP GLC-SX-MM - 20$ (есть 3 шт)
      9. Juniper M20  - 1500$ (есть 4 шт)
      Даные по Juniper:
      Chassis                                             M20
      Backplane        REV 04   710-002334   CT1609            M20 Backplane
      Power Supply A   Rev 02   740-007222   108325            DC Power Supply
      Power Supply B   Rev 02   740-007222   108346            DC Power Supply
      Display          REV 04   710-001519   CV0275            M20 FPM Board
      Routing Engine 0 REV 19   740-005022   P12040706683      RE-3.0
      SSB 0            REV 04   710-011129   CT5673            Internet Processor IIv2
      FPC 0            REV 02   710-011724   CV0146            EP-FPC
        PIC 0          REV 17   750-007443   CV2337            1x CHSTM1 IQ SDH, SMIR
        PIC 1          REV 06   750-011208   CS8506            Adaptive Services-II
        PIC 2          REV 06   750-010239   CT8921            1x G/E SFP, 1000 BASE
          Xcvr 0       REV 01   740-013111   7272483           SFP-T
        PIC 3          REV 06   750-010239   CT9111            1x G/E SFP, 1000 BASE
      FPC 1            REV 02   710-011724   CV0170            EP-FPC
        PIC 0          REV 08   750-004177   CS7112            12x FE, 100 BASE-TX
        PIC 1          REV 06   750-010239   CT8968            1x G/E SFP, 1000 BASE
        PIC 2          REV 06   750-010239   CT8941            1x G/E SFP, 1000 BASE
        PIC 3          REV 07   750-010239   RF1676            1x G/E SFP, 1000 BASE
      Fan Tray 0                                               Front Upper Fan Tray
      Fan Tray 1                                               Front Middle Fan Tray
      Fan Tray 2                                               Front Bottom Fan Tray
      Fan Tray 3                                               Rear Fan Tray
      Все б/у, рабочие.
