Postfix разборка логов
Gmen
Народ постфикс как-то странно себя ведет, не пойму:
Nov 21 10:53:20 ... postfix/qmgr[3565]: warning: connect to transport amavis: No such file or directory
Nov 21 10:54:21 ... postfix/qmgr[3565]: warning: connect to transport amavis: No such file or directory
Что бы это значило?
И еще помогите мне правильно настроить его, постоянно ругань от него:
master.cf
smtp      inet  n       -       n       -       -       smtpd
cleanup   unix  n       -       -       -       0       cleanup
       -o mime_header_checks=
       -o nested_header_checks=
       -o body_checks=
       -o header_checks=
127.0.0.1:10025 inet    n       -       -       -       -       smtpd
       -o content_filter=
       -o local_recipient_maps=
       -o relay_recipient_maps=
       -o smtpd_restriction_classes=
       -o smtpd_client_restrictions=
       -o smtpd_helo_restrictions=
       -o smtpd_sender_restrictions=
       -o smtpd_recipient_restrictions=permit_mynetworks,reject
       -o strict_rfc821_envelopes=yes
       -o mynetworks=127.0.0.0/8
       -o smtpd_error_sleep_time=0
       -o smtpd_soft_error_limit=1001
       -o smtpd_hard_error_limit=1001
pickup    fifo  n       -       n       60      1       pickup
cleanup   unix  n       -       n       -       0       cleanup
qmgr      fifo  n       -       n       300     1       qmgr
#qmgr     fifo  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       n       1000?   1       tlsmgr
rewrite   unix  -       -       n       -       -       trivial-rewrite
bounce    unix  -       -       n       -       0       bounce
defer     unix  -       -       n       -       0       bounce
trace     unix  -       -       n       -       0       bounce
verify    unix  -       -       n       -       1       verify
flush     unix  n       -       n       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
maildrop  unix  -       n       n       -       -       pipe
  flags=Rhu user=vmail argv=/usr/local/bin/maildrop -w 90 -d ${recipient}
relay     unix  -       -       n       -       -       smtp
       -o fallback_relay=
showq     unix  n       -       n       -       -       showq
error     unix  -       -       n       -       -       error
discard   unix  -       -       n       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       n       -       -       lmtp
anvil     unix  -       -       n       -       1       anvil
scache    unix  -       -       n       -       1       scache
old-cyrus unix  -       n       n       -       -       pipe
 flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user}
smtp-amavis     unix    -       -       n       -       2       smtp
       -o smtp_data_done_timeout=1200
       -o smtp_send_xforward_command=yes
       -o disable_dns_lookups=yes
 user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user}
uucp      unix  -       n       n       -       -       pipe
 flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
ifmail    unix  -       n       n       -       -       pipe
 flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
 flags=Fq. user=foo argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
Еще процесс непонятный появляеться:
1865 postfix     1  96    0  3372K  2400K select   0:00  0.00% trivial-rewrite
С ним не работает отправка и прием...
Если я его убиваю, то он опять появляеться... как быть?
Если кто сможет мне по шелу приконнектится и разобраться, давайте свои аськи =)
