Mедленная регистрация onu
pimpim
Hi,
Ону регистрируется через 5 - 10 минут. Где может быть проблема?
Журнал ничего не говорит.
Onu: ZTEF601, F660, F623
OLT: ZTE320
Спасибо за совет!
 An alarm 36610 level minor occurred at 08.14.2018-16:05:15-utc cleared at 08.14.2018-16:05:20-utc  %s <gpon-onu_1/2/4:30> uni:2 ONU ETH UNI LAN LOS
 An alarm 35125 level minor occurred at 08.14.2018-16:05:37-utc cleared at 08.14.2018-16:05:43-utc  %s GPON alarm link olt loami: shelf 1 slot 2 olt 4 onu 10 level 2
 An alarm 35125 level minor occurred at 08.14.2018-16:07:16-utc cleared at 08.14.2018-16:07:22-utc  %s GPON alarm link olt loami: shelf 1 slot 2 olt 4 onu 10 level 2
 An alarm 35114 level major occurred at 08.14.2018-16:07:22-utc cleared at 08.14.2018-16:15:35-utc  %s GPON alarm link olt lofi: shelf 1 slot 2 olt 4 onu 10 level 1
 An alarm 35114 level major occurred at 08.14.2018-16:12:05-utc cleared at 08.14.2018-16:15:17-utc  %s GPON alarm link olt lofi: shelf 1 slot 2 olt 4 onu 13 level 1
 An alarm 35121 level major occurred at 08.14.2018-16:14:21-utc cleared at 08.14.2018-16:15:42-utc  %s GPON alarm link olt sufi: shelf 1 slot 2 olt 3 onu 2 level 1
 An alarm 35121 level major occurred at 08.14.2018-16:15:26-utc cleared at 08.14.2018-16:15:42-utc  %s GPON alarm link olt sufi: shelf 1 slot 2 olt 4 onu 13 level 1
 An alarm 35124 level major occurred at 08.14.2018-16:15:35-utc cleared at 08.14.2018-16:16:41-utc  %s GPON alarm link olt dgi: shelf 1 slot 2 olt 4 onu 10 level 1
 An alarm 35123 level minor occurred at 08.14.2018-16:15:47-utc cleared at 08.14.2018-16:15:50-utc  %s GPON alarm link olt loai: shelf 1 slot 2 olt 4 onu 13 level 2
 An alarm 35114 level major occurred at 08.14.2018-16:15:51-utc cleared at 08.14.2018-16:16:28-utc  %s GPON alarm link olt lofi: shelf 1 slot 2 olt 4 onu 13 level 1
 An alarm 36610 level minor occurred at 08.14.2018-16:20:53-utc  %s <gpon-onu_1/2/4:14> uni:1 ONU ETH UNI LAN LOS
 An alarm 36610 level minor occurred at 08.14.2018-16:21:20-utc  %s <gpon-onu_1/2/4:37> uni:1 ONU ETH UNI LAN LOS
Відредаговано pimpim
  • 2 years later...
у нас еще на 1 голове с версией 2.1 и платой GTGOE бывают чудеса  ближе к вечеру 19-22 часа, начинаются валиться ошибки такого плана
An alarm 35124 level major occurred at 18:25:15  Fri  Aug 28  2020  moskow cleared at 18:26:01  Fri  Aug 28  2020  moskow  %s GPON alarm link olt dgi: shelf 1 slot 2 olt 6 onu 1 level 1
и порт уходит в аут. На порту 5-10 онушек, причем хаотично  3-4 порта так колбасит. Сигналы везде у онушек 14-17. Никто не сталкивался с такой проблемой?
Перезагрузка порте по reset не помагает - только ребут платы или олта в целом вылечивает такую беду..и так до следующего вечера. Вчера подкинули на проблемную группу другую плату GTGK посмотрим..как поведут себя. Но глюк за неделю ..напрягает капитально. Уже не знаем как лечить.
    • Від xelapsi
      Всем привет, поднимал кто нибудь ону елтекс роутером на zte c320 с использованием внешнего ацс сервера? Поделитесь конфигом на zte320
    • Від Misha Kozykhar
      Доброго дня! У мене виникла проблема відвал карти на ZTE OLT C320
      GTGO
      ZXAN#show card slotno 2
      Config-Type   : GTGO      Status              : HWONLINE
      Real-Type     :           Serial-Number       :
      Port-Number   : 8         BootROM-VER         :
      PCB-VER       :           Software-VER        :
      Cpld-VER      :
      Last restart reason: Power-off
      Uptime        : 0 Day , 0 Hours , 0 Minutes , 0 Second
      ZXAN#
      Хоча при цьому абони продовжують працювати. Але доступу немаю щоб подивится які сигнали.
      Допомагає в даній ситуації перезавантаження по живленню.
      ZXAN#show patch-running
      Loc    FileName                       PatchTag   OperateTime         PatchState
      1/1/4 smxav125p3t13_r0.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r1.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r2.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r3.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r4.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r5.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r6.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r7.pat           2.0        2023-09-13 17:38:36 ACTIVE
      1/1/4 smxav125p3t13_r10.pat          2.0        2023-09-13 17:38:36 ACTIVE
      ZXAN#
    • Від Allison
      Всім доброго дня.
      Маю потребу в системі моніторингу і керуванні мережою ПОН
      З заліза маю:
      ZTE c320
      ZTE c220
      З плюсів було б непогано мати легку реєстрацію клієнтських ОНУ, щоб цим могли займатись навіть найнижчі ланки сапортів підтримки
      Хто може що порадити, можливо на власних прикладах використання. Розглядаю як платні, так і безкоштовні варіанти, з можливістю масштабування надалі
    • Від Андрей_Варконский
      На сети GPON используется OLT ZTE-C320 v.2.1.0 , также к ним подключаю в основном абонентские терминалы ZTE-F601.
      Имеются терминалы с прошивками V6.0.1P1T11, V6.0.1P1T12 и V6.0.1P1T13 , но по какой-то причине при обновлении с V6.0.1P1T11 на более новую, в подавляющем большинстве терминал превращается в киприч.
      Обновление происходит с головы.
      В текущий момент на тестовом стенде залил файл:
      TEST-PON#show file version-ru
      Directory of version-ru:
      attribute   size       date         time       name
      -rw-        5016320    Oct-06-2022  16:20:20   f601_v6.0.1p1t13_upgrade_bootldr.bin
      При попытке обновления терминала с версии V6.0.1P1T11 на V6.0.1P1T13 я так понимаю что окирпичил его, т.к. горит только индикатор power.
      Возможно имеются какие-то нюансы, хотелось бы выяснить этот вопрос.
      Заранее благодарю!
    • Від dj_uise
      Здравствуйте, года 2 назад брали новый OLT ZTE  и там в плате были установлены SFP OLT ZTE Class ++  - в последнее время они начали выходить из строя ( сигнал с них выходит а вот onu он не видит). От осени 21 года уже испортилось 3 модуля с периодичности 2+ месяца между каждым. На первом модуле сигналы были разные у абонентом и до -26 , грешили на это . На следующих двух модулях сигнал от -11 до -23. OLT подключено через UPS . Не могу понять в чем может быть причина ???
