Рестарт mpd5 при пропадании интернета
Від veca16
Есть сервер под Freebsd 10.0 и Nodeny+ клиенты подключаются по pppoe через mpd5. Недавно начали жаловаться клиенты, что иногда обрываются сессии только как то хаотично, то могут через каждый час, то два раза в день. Проверил логи, только в mpd5 нашел странность но не могу разобраться почему. Вот часть лога как раз во время обрыва связи:
Oct 7 20:00:04 server mpd: [em1-261] LCP: no reply to 7 echo request(s)
Oct 7 20:00:04 server mpd: [em1-261] LCP: peer not responding to echo requests
Oct 7 20:00:04 server mpd: [em1-261] LCP: state change Opened --> Stopping
Oct 7 20:00:04 server mpd: [em1-261] Link: Leave bundle "B-72"
Oct 7 20:00:04 server mpd: [em1-261] RADIUS: Accounting user 'login' (Type: 2)
Oct 7 20:00:04 server mpd: [b-72] Bundle: Status update: up 0 links, total bandwidth 9600 bps
Oct 7 20:00:04 server mpd: [b-72] IPCP: Close event
Oct 7 20:00:04 server mpd: [b-72] IPCP: state change Opened --> Closing
Oct 7 20:00:04 server mpd: [b-72] IPCP: SendTerminateReq #3
Oct 7 20:00:04 server mpd: [b-72] IPCP: LayerDown
Oct 7 20:00:04 server mpd: [b-72] IFACE: Down event
Oct 7 20:00:04 server mpd: [b-72] IPCP: Down event
Oct 7 20:00:04 server mpd: [b-72] IPCP: LayerFinish
Oct 7 20:00:04 server mpd: [b-72] Bundle: No NCPs left. Closing links...
Oct 7 20:00:04 server mpd: [b-72] IPCP: state change Closing --> Initial
Oct 7 20:00:04 server mpd: [b-72] Bundle: Shutdown
Oct 7 20:00:04 server mpd: [em1-261] RADIUS: Rec'd RAD_ACCOUNTING_RESPONSE for user 'login'
Oct 7 20:00:04 server mpd: [em1-261] LCP: SendTerminateReq #4
Oct 7 20:00:04 server mpd: [em1-261] LCP: LayerDown
Oct 7 20:00:05 server mpd: Incoming PPPoE connection request via vlan0: for service "" from 04:18:d6:2c:f2:d3
Oct 7 20:00:05 server mpd: [vlan0-151] Accepting PPPoE connection
Oct 7 20:00:05 server mpd: [vlan0-151] Link: OPEN event
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: Open event
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: state change Initial --> Starting
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: LayerStart
Oct 7 20:00:05 server mpd: [vlan0-151] PPPoE: connection successful
Oct 7 20:00:05 server mpd: [vlan0-151] Link: UP event
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: Up event
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: state change Starting --> Req-Sent
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: SendConfigReq #1
Oct 7 20:00:05 server mpd: [vlan0-151] PROTOCOMP
Oct 7 20:00:05 server mpd: [vlan0-151] MRU 1492
Oct 7 20:00:05 server mpd: [vlan0-151] MAGICNUM ec170e67
Oct 7 20:00:05 server mpd: [vlan0-151] AUTHPROTO PAP
Oct 7 20:00:05 server mpd: [vlan0-151] MP MRRU 2048
Oct 7 20:00:05 server mpd: [vlan0-151] MP SHORTSEQ
Oct 7 20:00:05 server mpd: [vlan0-151] ENDPOINTDISC [802.1] 00 26 55 d0 d7 4c
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: rec'd Configure Request #134 (Req-Sent)
Oct 7 20:00:05 server mpd: [vlan0-151] MAGICNUM 70a7dde2
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: SendConfigAck #134
Oct 7 20:00:05 server mpd: [vlan0-151] LCP: state change Req-Sent --> Ack-Sent
Может кто сталкивался? Подскажите что это может быть? Заранее спасибо!
Від North76Storm
Уважаемые Гуру, помогите с проблемой!
Имеется сервер с mpd5 и абоненты с роутерами TP-Link. До определенного момента все работало без нареканий, но в один прекрасный день посыпались хаотические постоянные обрывы сессий.
В логах по биллингу пишет: ACCT_TERMINATE_CAUSE 1 : User-Request.
В логах роутера в момент разрыва:
49 Oct 23 06:26:04 PPP ПРИМЕЧАНИЕ Standard authentication... и далее успешное подключение.
48 Oct 23 06:25:45 PPP ИНФО rcvd [LCP TermAck] 47 Oct 23 06:25:45 PPP ИНФО sent [LCP TermReq] 46 Oct 23 06:25:45 PPP ПРЕДУПРЕЖДЕНИЕ LCP down 45 Oct 23 06:25:45 PPP ОШИБКА LCP down 44 Oct 23 06:25:45 PPP ОШИБКА User request 43 Oct 23 06:25:45 PPP ПРЕДУПРЕЖДЕНИЕ PPPoE link down 42 Oct 23 05:53:20 PPP ПРИМЕЧАНИЕ PPPoE connected
Такая ситуация продолжается около 3-х недель, "Танкисты" разрывают уже...
Что делать, куда копать???
P.S. Я сам немного далек от этого, так что просьба сильно не пинать, ну или хотя бы не по голове))) -
Від l1ght
Шановні підкажіть - є така проблемка.
Є тачка з FreeBSD 9.3 x64
FreeBSD 9.3-RELEASE FreeBSD 9.3-RELEASE #0 r268512: Thu Jul 10 23:44:39 UTC 2014 root@snap.freebsd.org:/usr/obj/usr/src/sys/GENERIC amd64 На ній підняті фаєр,днс (бінд), дхцп сервер, апач, усе працює нормально, але для певної діагностики потрібно підняти пптп сервер - ну то не в перше для мене, конфіг доволі стандартний в мпд
startup: set user admin admin # configure the console set console self 127.0.0.1 5005 set console open # configure the web server set web self 127.0.0.1 5006 set web open default: load pptp_server pptp_server: set ippool add pool1 10.10.10.5 10.10.10.250 create bundle template B1 set iface disable proxy-arp set iface idle 0 set iface enable tcpmssfix set ipcp yes vjcomp set ipcp ranges 172.16.1.1 ippool pool1 set ipcp dns 10.0.0.1 #Enable Microsoft Point-to-Point encryption (MPPE) set bundle enable compression set ccp yes mppc set mppc yes e40 set mppc yes e56 set mppc yes e128 set mppc yes stateless set mppc yes compress # Create clonable link template named L create link template L10 pptp # Set bundle template to use set link action bundle B1 # Multilink adds some overhead, but gives full 1500 MTU set link enable multilink set link yes acfcomp protocomp set link no pap chap eap set link enable pap set link enable chap set link enable chap-msv1 set link enable chap-msv2 # We reducing link mtu to avoid GRE packet fragmentation. set link mtu 1460 set link keep-alive 10 60 # Configure PPTP and open link set pptp self хх.хх.хх.хх # Allow to accept calls set link enable incoming Проблема в тому, що коли я з'єднуюсь із цим сервером - то вмирає нат, як би то дивно не було. Тобто усі сервіси працюють, маршрутизація працює, а от нат не хоче (ipfw nat). Лікується тільки ребутом системи.
В логах чисто - ядро не перезбирав, усе модулями завантажується.
Підкажіть, куди копати?
Від tivi
Обращаюсь ко всем за помощью. Идеи закончились...
Имеем:
Бордер, принимающий по bgp каналы от двух аплинков и отдающий все это дело на сервера доступа (под freebsd + mpd5).
Отрубили питание. узел продержался на упсах порядка 12 часов, запустить генератор не успели.
После подачи напряжения все понимается. сервера видят биллинг (через радиус).
а вот дальше начинаются непонятности.
более 50-55 клиентов не все три сервера доступа суммарно не садится.
(всего порядка 4к абонентов)
хоть на один сервер доступа (проверяли все), хоть на два...
ваершарком слушали трафик - PADI запросы от клиентов прут, а вот ответы от серверов доступа - 1-2 в минуту.
все чисто, ничего подозрительного нет.
грешили на коммутатор, на котором все это "собрано" воедино.
поменяли на новый из коробки - та же фигня.
причем, если "откинуть" все сегменты "локалки" и подключиться просто ноутбуком - авторизаци проходит все время без задержек.
как только возвращаем "все обратно" - начинаются проблемы.
колец нет - loopdetect включен как на коммутаторе где все это "приземляется", так и на точках аггрегации районов.
будем признательны (не только спасибо, а вполне готовы принять не безвозмездную помощь) за любую подсказку/помощь.
Від 0TshEL_n1ck
Доброго времени суток, подскажите пожалуйста как побороть.
Есть em0 - смотрит внутрь, раздаёт по DHCP
есть em1 - смотрит наружу, получает всё по DHCP
В такой связке всё хорошо работает и т д.
Поднимаю mpd5 на em1 - с сервера всё пингуется отлично, но нету связки em0 c em1, тоисть пользователи интернет не видят. Подскажите пожалуйста куда копать...
freebsd 9.2 + Ubilling: 0.5.8 rev 3790
