патч-корди, 8 проводів.
Від Alina1989
Hey, fellows, our S6865-56YC switch is a high-performance and high-density uplink switch with 25Gigabit Downlink & 100Gigabit Uplink, which is designed and developed by our company independently. The whole switch adopts advanced hardware structure design and pluggable power redundancy design.
It can support a maximum of 48 *25Gigabit ports, 8*100G uplink ports, provide full port L2/L3 line speed forwarding capability, and support IPV6. This device provides rich service features and powerful functions, such as ACL policies, flexible Q-in-Q, and network security protection.
Meanwhile, the product has the highest 10 Gigabit port density and the largest switching capacity of the same grade equipment in the industry, and supports full-port line speed forwarding. The elastic stack function virtualizes multiple devices into a logical entity, which can expand port and switching capacity, manage, upgrade, and maintain multiple devices in a unified manner.
To meet the requirements of large data traffic and non-blocking transmission in data centers, the product provides powerful cache capabilities and supports advanced cache scheduling mechanisms to ensure the maximum effective utilization of the device's cache capabilities. It is designed to meet the requirements of high-density and high-bandwidth network applications in next-generation enterprise networks, data centers and metropolitan area networks.
It can be applied to the Ethernet aggregation layer or access layer of network operators or campuses, as well as the access layer of data centers and the core layer of small and medium-sized enterprises, and provides rich server access solutions for data centers.
S6865-56YC (1+1 modular redundant power supply)
More details, contact me directly!
Whatsapp/ Viber/ Wehcat : +86 18086327779
Skype: alinaquan14@hotmail.com
Від yama
подскажите по фото как к одной ONU подключено два роутера по ethernet ?
Gpon приходит , а на выходе подключено два роутера по ethernet
свича/комутатора не вижу ... что за фантастика ...
Как я понимаю по фото : 8 парний кабель разделили на два 4 парн. и завели двум абонентам у каждого по роутеру ... но как ? ведь из ONU один выход ethernet или бывает два???
Від SalePON
За деталями обращайтесь в отдел продаж:
(098) 117-85-57
(067) 435-14-14
(099) 435-14-14
(093) 435-14-14
Від Meriamon
Продам свитч HUAWEI Quidway S3928P-E1 (+шнур питания), б/у, так как был лишним, использовался значительно меньше, чем лежал на полке. Не ремонтировался! Цена - 1650 грн.
Від 2_Vedra_Interneta
Помогите решить одну проблему. Вопросы по EPON, но только за их Ethernet порты. Есть непонятка, для лучшего понимания которой я даже нарисовал часть сети в приложенном файле. Дом я кому я живу был присоединен к свичу №4, что показано красной штриховой линией. Я решил пробросить себе связь напрямую к свичу №1, после чего свич №2 перестал отвечать, причем физический связь присутствует, порты линкуються на 1 гигабите. Свичи № 3 и №4 и некоторые другие, не указанные на рисунке, отвечают исправно. Все свичи находятся в одном управляющему влане, соответственно я ничего из настроек не менял, только взял себе свободный Ethernet порт на свиче №1, прописал туда нужные мне вланы и физически туда втыкнул кабель.
Я не мог ошибиться с настройками вланов, иначе бы не отвечали все остальные свичи. Начал разбираться - просто перезагрузка свича не помогла, а если вытянуть СФП с патчкором с свича №2 и запихнуть в свич №5 то данный свич (№5) пингуеться без проблем, что свидетельствует об исправности СФП и настроек. Если воткнуть все назад, то опять ничего не отвечает. Забрал свич домой, нашел еще один управляющий тэговай порт, подключился через него и начал смотреть что там. Не подумал сначала залезть в логи посмотреть, а сразу попробовал выключить и включить аплинк, но результата не дало. Вспомнил что когда настраивал что-то по защите от петель, но забыл как это проверить и полез гуглить и пока гуглил, аплин странным делом начал отвечать на пинги. Я удивился, но не было времени детально разбираться время позднее, поэтому я на всякий случай просто перегрузил еще раз ссвич и посмотрел чтоб поднялся. Все работало исправно, поэтому я списал все на глюк и поехал ставить свечей на место. И соответственно когда я его запустил на месте он дальше перестал отвечать на пинги.
Что может быть, кто-то может подсказать? Меня не интересуют подсказки такого типа - "просто используй другой порт" или "почему не подключишь свич №2 после свича №5", меня интересует данный случай.
Если надо какой-то конфиг, скину без проблем, но что-то я подозреваю что дело не в нем.
