Продам остатки по минимальной цене OLT ZTE C320 комплект и отдельные платы расширения GTGO/8
ZTE ZXA10 C320 10GE-AC-GTGH OLT комплект (PRAM + SMXA/3(10G) + GTGH C++)  -  2864 у.е.  осталась 1 шт
ZTE GTGO/8 модуль расширения  GPON +  8 SFP C++  -  440 у.е. , осталось 2 шт.
    • Від Y-Mouse
      Гарного всiм дня,
      Маю такий блок живлення - ZXDU48 B60 (з RS232).
       Цiкавить досвiд по монiторингу/керуванню ZXDU48 B600 через цей RS232.
      Там якийсь свiй протокол обмiну?
    • Від AdiT
      Hi all
      Is there a way to completely erase the control board SCXM on a C300. I want to synchronize it with a working one but not all files are copied
    • Від AdiT
      I'm having problems with one SCXM
      I have deleted all existing patches
      - delete patch
      ZXAN#delete patch *
      Confirm to delete?[yes/no]:yes
      Start deleting file
      deleting etghgv125p3t13_r0.pat..
      [Successfully]
      deleting etghgv125p3t13_r1.pat..
      [Successfully]
      deleting etghkv125p3t29_r0.pat..
      [Successfully]
      - verify
      ZXAN#dir patch
      Directory of /flash/patch/
      attribute   size       date         time       name
      -rwx        2          JAN-05-2024  09:42:54   patchCfgForOam.txt
      -rwx        1032       JAN-05-2024  08:17:32   patchCfg.txt
      -rwx        516        DEC-29-2023  10:07:40   patchCfgNext.txt
      -rwx        1296       DEC-29-2023  10:07:42   patchCfgLast.txt
      -rwx        7740       JAN-05-2024  10:09:20   patchCfgForNp.txt
      -rwx        516        JAN-05-2024  10:09:14   patchCfgForNpNext.txt
      -rwx        2592       JAN-05-2024  10:09:14   patchCfgForNpLast.txt
      Current directory 7 files total
      Total disk size: 126664704 bytes (40484864 bytes free)
      - Reboot
      - Verify after reboot
      ZXAN#sho patch-saved
      Patch infomation on master board
      Loc    FileName                       PatchTag    BuildTime           PatchLen AdminState
      ZXAN#
      - Download patches
      ZXAN#download patch ETGHGV125P3T13_r0.pat ftp ipaddress x.x.x.x user xxx password xxx
      Downloading from host(x.x.x.x)
      Transfering file /ETGHGV125P3T13_r0.pat ...
      .......[Successfully]
      ZXAN#download patch ETGHGV125P3T13_r1.pat ftp ipaddress x.x.x.x user xxx password xxx
      Transfering file /ETGHGV125P3T13_r1.pat ...
      ZXAN#download patch ETGHKV125P3T29_r0.pat ftp ipaddress x.x.x.x user xxx password xxx
      Transfering file /ETGHKV125P3T29_r0.pat ...
      ZXAN#download patch ETGOV125P3T13_r0.pat fftp ipaddress x.x.x.x user xxx password xxx
      Transfering file /ETGOV125P3T13_r0.pat ...
      ........[Successfully]
      - Verify after download (no patches saved after successfully downloading  )
      ZXAN#
      - Verifying directory patch ( files have been copied ? )
      ZXAN#dir patch
      -rwx        2          JAN-05-2024  10:22:56   patchCfgForOam.txt
      -rwx        6382       JAN-05-2024  10:16:36   etghgv125p3t13_r0.pat
      -rwx        8260       JAN-05-2024  10:16:42   etghgv125p3t13_r1.pat
      -rwx        7300       JAN-05-2024  10:16:50   etghkv125p3t29_r0.pat
      -rwx        23803      JAN-05-2024  10:16:58   etgov125p3t13_r0.pat
      -rwx        8024       JAN-05-2024  10:17:04   etgov125p3t17_r0.pat
      -rwx        89760      JAN-05-2024  10:17:12   etgov125p3t17_r8.pat
      Current directory 13 files total
      Total disk size: 126664704 bytes (40329216 bytes free)
      - Trying write + Reboot
      - Verify after reboot (again no patches saved  )
      ZXAN#
       - Verifying directory patch after reboot ( files still there ? )
      ZXAN#dir patch
      Can someone pls help. The patch files are copied successfully to the patch directory but are not shown as saved and cannot be activated
    • Від Андрей_Варконский
      На сети GPON используется OLT ZTE-C320 v.2.1.0 , также к ним подключаю в основном абонентские терминалы ZTE-F601.
      Имеются терминалы с прошивками V6.0.1P1T11, V6.0.1P1T12 и V6.0.1P1T13 , но по какой-то причине при обновлении с V6.0.1P1T11 на более новую, в подавляющем большинстве терминал превращается в киприч.
      Обновление происходит с головы.
      В текущий момент на тестовом стенде залил файл:
      TEST-PON#show file version-ru
      Directory of version-ru:
      -rw-        5016320    Oct-06-2022  16:20:20   f601_v6.0.1p1t13_upgrade_bootldr.bin
      При попытке обновления терминала с версии V6.0.1P1T11 на V6.0.1P1T13 я так понимаю что окирпичил его, т.к. горит только индикатор power.
      Возможно имеются какие-то нюансы, хотелось бы выяснить этот вопрос.
      Заранее благодарю!
    • Від ky0sh1da
      На днях у нас появился новый ONT F663nva, до них есть уже введённая в OLT профилем рабочая F660. OLT без проблем принял новый профиль и регистрирует серийник нового ONT у себя, но при этом не поднимается авторизация на Brass и нет никаких маков от этой ONT.
      Конфига такая же, что и на F660 и на ней все поднимается без проблем.
