ZTE C320 статус платы UNAUTHORIZED
Доброго времени суток, подскажите кто сталкивался с таким в статусе платы и как это побороть?
Rack Shelf Slot CfgType RealType Port    HardVer SoftVer         Status
1    1     2    GTGO    GTGOG    8       120301  V1.2.5P3        UNAUTHORIZED
1    1     3    PRAM    PRAM     3               V1.01           INSERVICE
1    1     4    SMXA    SMXA     3       131201  V1.2.5P3        INSERVICE
Edited by Zura
    • By kolorom
      Вітаю, взяв на свою голову з Китаю, хочу завести його у КС, підтримка каже тільки виклик майстра, але маю сумнів, що майстер зможе.
      Тепер граюсь, але безрезультатно.
      display deviceInfo
      *************** device information ***************
      Manufacturer     = Huawei Technologies Co., Ltd
      ManufacturerOUI  = 00259E
      ModelName        = EG8145X6
      Description      = EG8145X6 GPON Terminal (CLASS B+/PRODUCT ID:2150083448AGJ2898254)
      ManufactureInfo  = 2150083448AGJ2898254.C402
      ProductClass     = EG8145X6
      SpecVersion      = 1.0
      ProvisioningCode =
      UpTime           = 0 day(s) 01:05:16
      ReleaseTime      = 2022-09-02_23:26:14
      UpPort mode      = 1
      DeviceAlias      =
      TotalMemory      = 512 Mbytes
      TotalFlash       = 256 Mbytes
      HardwareInfo     = GPON 4*GE + 2.4G(2X2 11ax)/5G(2X2 11ax) Wi-Fi + 1USB
      display optic
      LinkStatus  : ok
      Voltage      : 3376 (mV)
      Bias         : 9 (mA)
      Temperature  : 44 (C)
      RxPower      : -23.28 (dBm)
      TxPower      : 1.98  (dBm)
      RfRxPower    : -- (dBm)
      RfOutputPower: -- (dBmV)
      VendorName   : HUAWEI
      VendorSN     : 2133T002613XX
      VendorRev    :
      VendorPN     : HW-BOB-0008
      DateCode     : 210916
      display lanmac
      lan mac = E8:68:19:19:62:XX
      display version
      hardware version          = 22AD.A
      main software version     = V5R021C10S225
      standby software version  = V5R021C00S050
      uboot version             = 2020.01
      ONT Registration Status:  Successfully registered the ONT with the OLT.
      OLT Service Configuration Status Failed to obtain the status because the OLT version does not match.
      EMS Configuration Status:  No XML configurations applied.
      Huawei ONT is used with an OLT and NMS of a required version. If the versions are not the required ones, the ONT may not work.
      If required, contact your internet service provider to obtain the correct ONT firmware or software.
      Може хтось може допомогти бо в інтернеті пишуть як на нього лити olt але який і звідки його взяти і що всі питання до провайдера)))
      Дякую!
    • By tadesky
      Продам б/в BDCOM P3616-2TE OLT .
      Повністю робочий, без нюансів, знятий після модерну.  Комплектований резервним БЖ.
      Оціночна вартість 40 тис. грн.
      За потреби можна комплектувати SFP Picotel EPON SFP PX++ = 600 грн/шт.
      Пишіть в особисті.
    • By g-shock
    • By Vens
    • By mch412
      Вітаю товариство!
      Маємо проблему не піднімається DMVPN для всіх Абонентів підключених до PON OLT ZTE C300 v1.2.5p3.
      Головне пакети 1520 з тестового ноута через ПОН пролазать без проблем, а DMVPN не піднімається.
